Question about Sanyo PLC-XF46N LCD Projector
Sanyo PLCXF46NProjector On and Shut down immediately
My Sanyo PLC-XF46NProjector On and Shutdown immedately
Pls help
    New Friend:
  • 12 Answers
Check ur fan and fan rpm sensor
Posted on Aug 09, 2012
SOURCE: Sanyo PLC-XT16
The problem is faulty capacitor on one of the control pcb's . needs to go to a technician for repair
Posted on Jul 04, 2008
SOURCE: Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Posted on Jul 07, 2008
SOURCE: sanyo plc sw30 help
i had a sanyo plc sw30 wich had the same problem and it turned out to be the bulb replaced it with new one and this seemed to solve the problem. Theres a few places to get new ones but they are not cheap looking at between £150 to £180 hope this helps
Posted on Nov 02, 2008
JOHNSONELECT
  • 113 Answers
SOURCE: Sanyo PLC XU105 Will shut down in 10 to 15 seconds
YOU HAVE A BAD LAMP OR THE LAMP DRIVER BOARD BAD
Posted on Aug 24, 2009
  • 43 Answers
SOURCE: i need instructions for my sanyo plc-sw35
Hi There,
I Have a plc-sw35, Gave me many issues (switching off etc..) Ive managed to repair it, and made the manual available. http://www.entwan.netau.net/1_8_Repair-Schematics.html
My repair story is there also.
Posted on Sep 18, 2009
Sanyo plc-sw30 i have a problem when i power on the projector , there is no power lamp on a very slow light is visible and the projector shut down and the fan are in very high power
The uProcessor thinks that it has overheated and is frantically trying to cool down what it thinks is a hot lamp.
This condition has many causes from an exhausted lamp to lamp ballast fault or even a power supply fault or a heat sensor/fan fault.
Mar 30, 2011 | Sanyo PLC-SW30 Multimedia Projector
Sanyo PLC-XU33 multimedia projector. Starts up, goes through countdown, stays on for a minuit after that, then bulb goes out and it goes into shutdown?????? Rob,
hi,
check the video inputs. if there is no video input then the projector will goes off after count down.
also check that is the lamp replace light lights up or not. if its lights then you have to change the lamp and then reset the lamp hour.
ok
Jan 19, 2011 | Sanyo PLC XU33 Multimedia Projector
After lamp replacing on Sanyo PLC-XP46 the projector starts up and immediately shuts down. Lamp counter was reset.
Check the iris door, it opens and closes freely. If dust has clogged it up, it will not stay on. Also check the air filter and the fan, if they are dirty, it will shut down as well. If your manual does not show any diagrams of the unit, post a comment and I will look it up. Hope this helps.
Jan 11, 2011 | Sanyo PLC XP46 Multimedia Projector
We are having one sanyo plc xu 78 projector.when it began to switch it on the count down screen will displays when the count down timing is coming to 0 then its directly going to stand by mode. its not...
The countdown shows while the unit is going through its internal circuit testing. Usually if a problem is found, there will be indications with the standby lights and lamp/temp lights. Are there any other indications here or just the unit going into standby?
Dan
Jul 08, 2010 | Sanyo PLC XU35 Multimedia Projector
I have a model PLC-XT11 and when I turn the power on the temp light and green ready light begin to flash. The red lamp light is on steady. I replace the lamp but no luck.
one or more of the fans may not be working right. also, the temp sensor may be shot. if the last time you used it it wasn't shut down properly, it may still be in cool-down mode.
Nov 06, 2009 | Sanyo PLC-XT11 Multimedia Projector
2 projectors that have blown their lamps
My guess is with them so high in the air, no one seems to clean the air filter often enough. Also, the projector is at 840 hours which is just a few hundred below the normal lamp expectancy. Also, I would wonder how they are shut down. Do they actually go through their normal shutdown process as requested by the manufacturer, or has someone that programmed the shutdown to just kill the power to the circuit. That would definately be worth checking.
Nov 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo plc sw30 help
Nov 02, 2008 | Sanyo PLC-SW30 Multimedia Projector
Sanyo PLC-XF46N LCD Projector Logo
138 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
