Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Dishes not being washed clean in dishwasher
Lately, the dishes are not being washed clean in the dishwasher. rinse aid and salt levels have been checked and filter basket has been cleaned. what else should we be doing/checking
  • 115 Answers
Check your water temp it has to be at least 125 degrees if it aint that then check your water heater
Posted on Jan 02, 2009
How much salt goes in dish washer
You don't put salt in a dishwasher unless you want to ruin it.
2. You ONLY use a detergent specifically for dishwasher use as the cleaning agent and you 3/4 fill the soap dispenser in the washer (normally fitted into the door on the inside) with the dishwasher powder.
3. If there is a separate small compartment in your dish washer for a "rinse aid" solution to be used, you can use a rinse aid product designed for dishwasher use only. If there is no rinse aid compartment (this is also normally fitted to the inside of the door - if fitted on your machine) then you cannot use a rinse aid in your washer.
4. Don't use any other product in the dish washer.
Jan 30, 2016 | Dishwashers
Built in water softener
really don't know have you got the manual. Normally you have to test the water ph level and then adjust the dish washer to that ph level and then fill the salt reservoir. Not sure on your model of dish washer . However you could add a water softener to the water inlet to the dish washer . Just search for
Water softener device
see
http://www.uvguard.com/hwc-home-series/
Oct 29, 2017 | Magic Chef CDB6100 Built-in Dishwasher
All my clean dishes have a coating of salt
Check that you rinse aid and dish washing salt is full, it could be that you didn't pack the unit correctly and that one of the propellers got hooked on a dish or something, if not put it on full heat and put only a few items in and see what happens
Oct 08, 2013 | Kenwood KDW12SL3A Portable Dishwasher
My dishwasher won't clean the dishes properly - very poor cleaning results with residue left on the dishes.
Check The Salt-Level ? Dishwashers rely, On salt and cleaning Fluids/Rinse Aids et,c. Also check for Any Blockages or Obstructions/Kinks/Bends et,c. in The External Outlet/Waste pipe.
Mike.
Jun 02, 2011 | Hotpoint 24 in. FDW60 Free-standing...
After a cycle the dishes have goop on them, almost like caramel. it doesn't smell and the goop is about the size of a pin head or smaller. We tried changing detergent but it persists. What is it and what...
If it is a lime scale deposit, check your inlet water quality.
If the dish water support salt for softening water add the salt in the
correct compartment provided in the machine.
Check rinse aid for dispensing! Check the level and refill
rinse aid liquid.
Run a empty cycle and clean the machine.
Sep 06, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
White film on dishes and still dirty.
Check rinse aid is actually dispensing - turn it up to max for a while to clear it, and check level is going down after a week.
If you suffer with hard water - your heating element may need replacing as it is probably furred up.
Jun 06, 2010 | Miele G892SC SS Dishwasher
Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
May 19, 2010 | Dishwashers
Dibris on glasses afterwash. Dishes not coming clean
First check salt level is ok, the next thing may be it's having problems pumping out after the primary wash.
Try running a hot cycle with a dishwasher cleaner or 2 cups of washing soda, then pull out outlet hose and check it's clear.
Check all filters are clear and in good condition with no cracks.
Aug 05, 2009 | Thermador DW44Z Built-in Dishwasher
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Aug 04, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwasher not cleaning
The dishwasher salt response is acceptable for Europeans, but U.S. dishwashers do not have a salt dispenser, nor is dishwasher salt sold in U.S. stores. U.S. consumers should descale their dishwasher using Dishwasher Magic, Lemi-Clean, Lime-A-Way, CLR, or vinegar until scale is removed from the machine, then add a rinse aid to the dispenser, which should prevent future problems. For very hard water, regular, periodic descaling treatments should be done. For the vinegar cleaning, place a full cup (8 oz) of vinegar in the top rack of the dishwasher. This way the vinegar is release throughout the wash cycles, performing a more thorough cleaning.
Sep 13, 2007 | Dishwashers
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
