Question about Ascaso Dream Espresso Machine
Overheating ascaso dream, and too much steam
My ascaso dream, is making too much steam, even with the steam button turned off. Pressure emits from the coffee head, resulting in burnt coffee.
    Habit-Forming:
  • Ascaso Expert
  • 55 Answers
You need to descale the machine and replace the group spring valve. It is available in a kit . Ascaso Dream gasket kit versitale version There are a number ok kits for different machnes
Posted on May 07, 2017
Benimur
  • 6966 Answers
SOURCE: No steam on the Dream
Initially, pls check for steam leaks. This model has been known to have issues with leaks preventing it from reaching the correct pressure/temperature. Since the leak could be visually checked, it would be a matter of determining at what point/component would the steam be coming out other than designated point. Often, it would be a joint with a rubber seal or a tubing entry point.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 03, 2008
SOURCE: Ascaso, Innova, Dream Heater not working
If you are confident that your heating element is dead and are filling adventurous enough to replace it- you can get one at:
http://www.1st-line.net/cgi-bin/category.cgi?category=review&item=i365&type=store
I saved myself shipping and repair costs by having it replaced by a friend. He took pictures and marked wires & connectors before removing the broken heater.
Yeah,, this looks to be systematic failure with this machine. Very disappointing- for this kind of money, one would expect the machine to work a bit longer after warranty expires.
Posted on Jun 22, 2009
  • 1089 Answers
SOURCE: Ascaso Dream water leak & bad shots
Hi
Sounds like you have a leak in the system. If your handy, you can remove the top. Remove everything. Water tank included. Unplug the machine. Now turn the machine upside down on a towel. There are 2 screws behind the brew head. Remove them, then lift the machine off the top and set it right side up. Now you can see the inside of the machine where the boiler is. Do not touch anything inside the machine. Replace everything and plug the machine in. Now turn the machine on and try to make a shot the same way. This should show you where your trouble is. Once you see where the trouble is, unplug the machine. Contact seattlecoffeegear.com, or 1st-line.com. They can help.
Posted on Jul 29, 2009
  • 1089 Answers
SOURCE: I think the pump is going out on my Ascaso Dream
Hi Pumps are easy to replace in your machine. there is one that will work in your machine on ebay.
Posted on Feb 07, 2010
  • 10 Answers
SOURCE: Acaso Dream espresso machine no crema
Are you getting enough atmospheric bars of pressure? Should be around 9 or so. if not that may be your problem... also if your portafilter is pressurized (there will be a plastic disc under the screen) try removing it and see if you are getting crema then... Helped alot with mine. I also shaved the bottom to make it bottomless but that may be alot further than you want to go.
Posted on Apr 09, 2010
Won't turn on
Hi Sab, you need to replace the thermal fuse on the ascaso dream. Ascaso dream safety fuse
Mar 17, 2014 | Ascaso Dream Espresso Machine
I purchased an Ascaso Dream espresso machine on ebay without reading the fine print that it was not working by not heating up. Is it merely the heating unit/part that needs to be replaced? Also it only...
If when you switch on the machine and the water is cold then, you should replace the boiler element.
There are a number of ascaso boiler elements, depending on the year. Dream Arc Basic Ellipse Page 2
It it works and you get steam , then the boiler is fine.
It may be that wires are loose inside?
Mar 05, 2014 | Ascaso Dream Espresso Machine
Ascaso Dream
If your steam wand is leaking then you may need to replace steam wand o rings. These can be found at Ascaso gasket kit Dream Arc Basic . Available in a kit with easy to follow instructions.
Try Dream Arc Basic Ellipse 150 Products
Feb 16, 2014 | Ascaso Dream Espresso Machine
Very hot weak bitter coffee
Ascaso dream temperaturegauge
It should be between 80°C/180°F degrees for the coffee and 100°C 212°F degrees for the steam.
You may have to replace the thermostats.Use thermal paste for correct fit.
Ascaso boiler thermostats 2
Feb 05, 2014 | Ascaso Dream Espresso Machine
Ascaso dream wand wont heat or steam
You should descale the machine, as you may have a blockage in the steam tap.
When descaling make sure that the descaled water goes through the steam wand as well as the group. JURA descaling tablets
Mar 26, 2017 | Ascaso Dream Espresso Machine
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
Cant make hot milk or foam ascaso dream the wand doesnt work it just stopped. also my coffee is not hot, only lukewarm ive opened it up and everything looks ok, its all just electrics all of which look...
Hi Mike,
You may have 2 issues.
Steam wand may be blocked;
Try descaling the machine 1st before you do any thing else.
1.Try removing the steam tip, if you don't get steam with tip removed, try removing wand, if you don't get steam then the steam pin may be blocked.
If after descaling coffee is still jst warm you could replace thermostats http://www.bluestarcoffee.eu/ascaso--boiler-thermostats-x-2-193-p.asp
If you still don't have steam after descaling and replacing thermostats then you may need to replace the o rings on steam pin.
http://www.bluestarcoffee.eu/ascaso-gasket-kit-dream-arc-basic-114-p.asp
Ascaso descale sachets 10
Mar 31, 2011 | Ascaso Dream Espresso Machine
Ascaso Dream Leaking Water
Correct, inside the grouphead their is a gasket which is the same diameter as the filterholter which make the perfect fit so the presure of the water will not leak out. So now either the gasket is damage in one point so you have the leak from that point. Second the gasket have become hard so it can not make perfect fit with filter holder. In both above case you have to replace the gasket. Finally their is aposibility that the gasket is dirty with coffee remains and again we can not have a perfect fit. You can use a hard brash with the water running so you can clean the gasket.
With this case you can unsrew also the shower from the grouphead and clean it also for better coffe results
May 05, 2010 | Ascaso Dream Espresso Machine
Innova Dream espresso machine
Hi Jah510,
My espresso machine turns on but it doesn't heat up..
You may need to replace the ascaso boiler element, if machine is between 3-6 years old then it probably is the element.There are a few of these, you just need the the manu date under the machine. Dream Arc Basic Ellipse 150 Products
Apr 04, 2017 | Ascaso Dream Espresso Machine
Ascaso Dream Espresso Machine Logo
318 people viewed this question
Top Ascaso Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you an Ascaso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
