Question about Sony SCD-XE680 CD Player
Centre channel not working on SACDs
I bought the Sony SCD XE-680 second - hand a few days ago and connected it to my Kenwood Audio Visual Sound Receiver KRF - V505D using the DVD/6Ch setting.I connected it via 5 phono leads ( I do not have a subwoofer, but have the front L, R , the Centre, and the back L and R speakers set up and already working with my DVD Dolby -Digital and DTS Player. The trouble is I set the SACD up to test the speakers , they all hiss accordingly including the Centre, and then when I play the SACDs i have , the Centre channel is utterly silent and various bits of the music are missing.I think I have tried every combination of buttons to get it to work , but have hit a brick wall. Help would be gratefully appreciated! Kind regards Nagimud
Thanks for linking me to some help pages, but I have already tried all what was listed, about multichannel, etc, both on the Amp and on the Sony SACD player. It seems the brick wall will never break down.
Posted on Jun 07, 2007
Http://www.retrevo.com/search?q=Sony+SCD-XE670%2C+center+channel
Posted on May 23, 2007
SOURCE:
Kenwood vr606 reciever shutting off subwoofer and centre speaker simultaneously after few minutes/seconds of powering on. WHat's the cause?
The receiver's out put sections are grouped in pairs. Front left and right in one output, rear left and right in second output, and center channel and sub output on the third. Sounds like a semiconductor or semiconductors have gone bad in the center & sub output.
Nov 19, 2015 | Kenwood VR-606 Receiver
I bought a second hand vehicle with a kenwood car audio,it needs a code to open it.
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your vehicle manufacturer's servicecentre and get them to enter this code for you.
Jun 27, 2012 | Kenwood Car Audio & Video
Sony STR-DE875 receiver has no sound from right channel front or back. Checked for loose connections & blew out dust, no change
Hy all. I bought a receiver at last week. But the front speakers not working. The rele is jumping just.
i repaired them ! the rele colour is blue. Three percent . left first -Center, between -Surround, between(right Hand)-Front.
I moved the front channel's rele(right hand) .Katt -it sad. Working, volume is back. Rele specification is (colour Blue) Deg Greatings-Ranger of Hungary.10_26_2012_6_50_16_am.jpg
Aug 23, 2010 | Sony STR-DE875 Receiver
Just bought a used Sony Trinitron - need to adjust audio/visual
You can purchase in most cases at Kmart, Walmart or places like that universal Sony remotes which should allow you access to those features.
Oct 17, 2009 | Televison & Video
I've problem getting any Sub sound from Sony STR DB840. The sub is ok and I've correct setting on my reciever with sub enabled. When performing tone test... I can hear sound from all connected speaker...
make sure sub is working .Power it up , remove sub RCA jacks from receiver .Gently tap on RCA with fingers.You should here a hum when touched .You can also try audio from TAPE REC OUT .If you dont get audio .Check setting at sub .If it working okay check setting at receiver and or sub level at receiver
Jul 20, 2009 | Sony STR-DB840 Receiver
Centre speaker
The controls I would check are speaker set-up and configuration for a multi-channel sound, be sure to enable center channel YES/NO option and trim center channel level output.
Feb 15, 2009 | Kenwood VR-406 Receiver
Kenwood 9102d wont power on
YOu might have burned out the inner fuse. Better yet the source connect...
Nov 06, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Sony SCD-XE680 CD Player Logo
159 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
