Desktop will restart when the current is off
My desktop system will restart when the current is off intervally
  • Anonymous Feb 18, 2009
    my system it use to restar when am working on it some time it will just on without display on destop
    Sergeant:
    Champion:
  • 214 Answers
The best is you reset the bios to default
Posted on Jan 05, 2009
  • 42 Answers
It is most likely in the bios. You probably have a setting to start when the mouse is moved, a key hit on the keyboard or even the ethernet or wireless sending a ping signal to your pc to restart if you have that setup. All of these settings should be in the Bios under power options and UPS controls. It will not be the UPS itself I wouldn't believe.
Dale
Posted on Jan 04, 2009
    Problem Solver:
  • 11 Answers
Check in your BIOS, normally there is a setting to restart after power outages.
Posted on Jan 03, 2009
Screen zoomed in zoom out
this is likely a virus, trojan issue... have you done a thorough virus scan with current software???
superantispyyware.com... free
Aug 17, 2013 | Sony Computers & Internet
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
How can i change my wallpaper in samsung n150
It all depends on the Operating System that you are using! if you are running Windows7, this is how your proceed
One the current Wallpaper, or on the desktop,
  • Right click your desktop in the Blank space.
  • Single Click on Personalize
  • > > From there you can Pick a different Theme, or get more themes online!
  • Click on Desktop Background
  • Select from there whichever is the best for you or browse another Location.
  • click select all click Save Changes.
(You can also change the time interval between your wallpaper picture)
Attached are the the above steps!
Hope this helps you!
Dec 23, 2010 | Samsung N150 Atom N450...
My computer keeps crashing does microsoft have a registry cleaner available online?
If the issue repeats in frequent intervals means, i would suggest the below steps.
  • May be due to system infected, kindly install antivirus like avast 4.8 or 5.0 version and configure the boot scan and restart the machine, to clean all the malwares and Trojans from the system files.
  • If the above didnt resolve your isssue, i would suggest to repair the system files with operating system boot CD buy pressing `r` as more symptoms are related to corruption of system files
Oct 15, 2010 | Computers & Internet
How to access bios on Dell Inspiron 546
As soon as you turn your computer on, and see the Dell logo, start tapping the F2 key.
If you miss this window of opportunity, wait until Windows has fully loaded, then restart your computer. Try again.
(The Dell logo comes up pretty fast. If you miss entering BIOS Setup, {System Setup is Dell's term}, then as soon as you press the Power On button, start tapping on the F2 key. Tap in 2 second intervals)
http://support.dell.com/support/edocs/systems/xlob/dtg/en/systemse.htm#wp1211139
Jan 23, 2010 | Dell Inspiron 546 MT PC Desktop
Emachine hesitates when typing to fast
go into the bios and change the typmatic rate setting to a shorter interval. Usually the BIOS is accessable by tapping the "del" key as the system starts or another key combination as flashed on your screen during startup. If you get to the "starting windows" screen you will have to restart and try again.
Apr 01, 2009 | Computers & Internet
Computer started restarting at random
its software related issue if you fdisk format and reinstall it should fix the problem just to double check if yu have another HDD with a OS already on it and plug it into your system it won't keep restarting
Mar 26, 2009 | ASUS Computers & Internet
My dell optiplex sx 270 restarts
Hello!
Here are other possible reasons why computer restart
-- Sometimes this can be caused by an overheating situation wherein some programs require a lot of processing power which can cause the processor or hard drive to get hot
--If you determine that overheating is not the problem, the most likely suspect is bad memory. Trying to access a bad spot in your system memory (RAM) can cause the computer to freak out and restart.
-- Make sure that the Automatically Restart in the System failure section is uncheck
--This can also be a virus or spyware problem. go through your Control Panel / Add or Remove Programs list and remove any programs you don't need, then run thorough anti-virus and anti-spyware scans.
-- Failing or under-rated power supplies can also cause your computer to restart at seemingly random intervals.
May 09, 2008 | Dell OptiPlex SX270 PC Desktop
Sony vaio Pcv v300g tv tuner device failed to open
Install the Driver manually, the automatic installation of the driver is not installing the drivers properly, that is why when you restart the system it is not able to identify the device. for this uninstall the driver restart your system then install the driver manually.
Feb 12, 2008 | Sony VAIO PCV-V200G PC Desktop
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
