Question about Video Game Consoles & Games
Cannot connect psp slim into the internet
I have router at home and when im scanning for my router there is a message saying "An internal error has occurred. (00000001)......plz help
  • 50 Answers
Its a Common Problem found in FIrmware verison 3.7x... Please update your psp to the latest version .. and it will be fine
Posted on Jan 04, 2009
My psp slim has a message "DSN Error" when I try
Hi, claytly!
Sadly a DSN Error means that your system/game didn't pass the online authentification process. Are you using full retail copies of the games? This issues are more common when using modded firmware or backed up games. The way to fix it is by using the latest PSP firmwre and retail copies of the game.
I hope this helped you and i apologize for the inconvinience.
-Luchen
Mar 07, 2011 | Sony PlayStation Portable (PSP) Slim...
My psp 3004 internet connection not supported what would i do
Hi yashb22,
Connecting to the internet using your psp is almost the same as connecting through your laptop. If you're having connectivity issue please try to check the error. One of the common error is WLAN switch is off, so make sure that it's properly toggled to the right. If you've already checked and still can't connect try doing the following steps below:
1. Make sure to turn on your PSP as well as the wireless/WLAN switch.
2. Then Navigate to " Network Setting".
3. Select "Infrastructure Mode".
4. Now Select "New Connection" and Name this connection.
5. Navigate to "WLAN Settings" Select "Scan".
6. Your router should now be listed.
7. Please go to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None".
8. But if you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA.
9. Then navigate to "Address Settings". Select "Easy".
10. Go to "Setting List". Verify that your settings are correct.
11. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X.
12. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
From this point you already established a connection.
Hope this information will be helpful.
Thank you for using FixYa.
Jan 16, 2011 | Sony PlayStation Portable (PSP) Slim...
I have a new psp 3000. I can't get internet access. It finds the SSID, good reception=75%. WLAN on, but its saying "a connection error occurred. Connection point could not be established. Check...
Hi stagedoorste,
You may notice that sometimes connecting your PSP to your network seems like a hard thing to do. But if you're aware of the basic configuration you can say that it's not a complicated thing. If your experiencing hard time connecting to the internet please make sure to check on the error. Based on what you have mentioned it says that you need to check the security setting. You may try following the steps below for the basic configuration on how to connect your PSP to your router.
1. First step is to make sure to turn on your PSP as well as the wireless/WLAN switch. 2. Then Navigate to " Network Setting". 3. Select "Infrastructure Mode". 4. Now Select "New Connection" and Name this connection as you deem appropriate. 5. Navigate to "WLAN Settings" Select "Scan". 6. Your router should now be listed. 7. Please go to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None" 8. But if you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA. 9. Then navigate to "Address Settings". Select "Easy" 10. Go to "Setting List". Verify that your settings are correct. 11. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X. 12. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
From this point you already established a connection and using your PSP you can now browse the net.
Jan 09, 2011 | Sony PlayStation Portable (PSP) Slim...
Im trying to get my psp on the internet, it scans with the WLAN and finds my home network, but says it does not support the security.
Hi torying01,
Based on your concern, I suggest trying the following steps:
1. Turn your PSP on.
2. Make sure that your WLAN switch is turned on.
3. Perform a factory reset.
--> To do this, select "Settings", then select "Restore Default Settings". You will not lose any information or data by performing this step.
However, you may need to reset your wallpapers. Set your name, date, time, etc...
4. Power down your PSP then wait 10 seconds, then power it on.
5. Navigate to "Network Settings".
a. Select "Infrastructure Mode"
b. Select "New Connection" Name this connection as you deem appropriate.
c. Navigate to "WLAN Settings" Select "Scan".
d. Your router should now be listed.
e. Navigate to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None"
f. If you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA..
g. Navigate to "Address Settings". Select "Easy"
h. Navigate to "Setting List". Verify that your settings are correct.
i. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X.
j. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
Hope it helps,
Thank you for using Fixya.
Dec 27, 2010 | Sony PSP (Piano Black)
How do you get internet on a PSP?
Hi ana01,
Connecting your PSP to the internet is just like connecting your computer to a router. First to consider is having an access point. So what is an access point? Access point is your router. If you wanted to get started going online using your PSP I suggest trying the following steps below:
1. Just turn on your PSP as well as your WLAN/wiresless.
2. Use the left and right directional button to find "Network Setting".
3. Now look for "Infrastracture Mode".
4. Please select "New Connection" and name it.
5. Go to "WLAN Settings" then select "Scan".
6. Your PSP will now detect your router.
7. Navigate to "WLAN security setting". Just leave the option "NONE", If you dont have an encryption in your Router set up.
8. But if have an encryption in your Router. Then put your WEP or WPA security key.
9. Go to "Address Settings". Select "Easy".
10. Navigate to "Setting List". Check if your setting is correct.
11. Go to the next page then save your setting by pressing x. Then press x again once you get a message that says "Save Completed. Test Connection".
12. Next message would say "connecting to access point." The next should say "obtaining IP address".
You already established a connection and you can now browse the net using your PSP.
Hope it helps.
Nov 15, 2010 | Sony PlayStation Portable (PSP) Slim...
My PSP internet connection not supported to my access point.
The SSID is the NAME of your Routers connection. So you need to know your WiFi connections Name, That's the "Access point" Security, Is IF you assigned a WEP/WAP KEY, when the router was first setup. If NO Key is set, that is what it means "Unsecured",
You need to get a Netgear router manual, for your exact model, it shows all in pictures how to do it.
Apr 25, 2010 | Sony PlayStation Portable (PSP) Slim...
How do you get online with an psp slim please help.
you can get online with ur psp slim with the help of wifi u need a intertnet router goto ur psp internet menu scan connection and if it is asecured conection enter wep verify the other settings
Sep 24, 2009 | Sony PlayStation Portable (PSP) Slim...
Connection failed... (PSP)
go to Network update- new connection- scan -enter connect name (SSID)-correct password /up lower casing.
Aug 20, 2009 | Sony PlayStation Portable (PSP) Console
Psp no connection to internet
Why can't I connect to the internet on my psp I tried over & over nothing it says the connection to the acces point has timed out..
i still can't connect even with wireless router
Jan 27, 2008 | Sony PlayStation Portable (PSP) Console
Internal Error on PSP
were you near an internet connection at the time?
Nov 09, 2007 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
