Question about Toshiba Satellite A100-S8111TD Notebook
Media test fail,check cable
My laptop toshiba a100 ,,,is behaving normal,,but i wanted to use product recovery cd to clean up,,,but when i boot it comes MERDIATEST FAIL,,CHECK CABLE,,,after this message my laptop starts normally and behaves ok,
but i wanted to use my product recovery cd,,,
please help me
Toshiba laptop media test failure
yeah but what if you accidentally used the recovery wizard and deleted everything, partitions and all? No recovery partition left to use, and now getting... checking media [Fail]... followed by No bootable device--please restart system- I have bootable windows cd's but it won't read them for some reason, not even on a usb . this toshiba laptop is only 1 month old and daughter got virus.
Jun 19, 2013 | Computers & Internet
I want Recovery for toshiba satellite a665-s6056
If you made recovery media for the laptop then you can recover the laptop using the CD or DVDs you created when you bought it. Failing that Toshiba may have included a recovery utility so try pressing R on boot or F10/F11.
If they haven't, contact Toshiba and you should be able to buy recovery DVDs for your laptop.
Jul 24, 2011 | Computers & Internet
I have a toshiba laptop that on the bottom of the laptop it shows it to be an A105-S4184, model PSAA8U-SK7034, to my knowledge there has been no hardware changes but i did reload an operating system when a...
You need to make a bootable CD, put theToshiba DMI utility on the bootable CD; Boot from that CD, then run DMI utility to set the machine to match the designation on your recovery disks. That'll do it.
Jan 29, 2011 | Toshiba Satellite A105 Notebook
Downloaded The Recovery CD's Went To Boot Up Laptop, Realtek Fast Ethernet Network Atdapter come's Up, Then Media Test Failure,Check Cable. Keep's Repeating, Even When I Shut It Down & Reboot It.
Hello sir, hi, this error could be several, so check this one by one:
  1. make sure your pc boots on the hard drive, not floppy, or other boot devices.
  2. If you are setting up windows boot from the CD drive.
  3. check your HARD DRIVE, this may be due to failure, format it using a low level format utility like disk manager.
  4. re-seat Hard Drive cables. use another cable if necessary.
Sep 16, 2010 | Toshiba Satellite A205-S5879 Laptop
Reset toshiba satellite A100-TA2 to factory settings
try this link, at appears as if u can download the disks here
http://www.user-guides.co.uk/toshiba/toshibarecovery/toshiba.asp?keywords=toshiba+satellite+a100+ta2+recovery+discs+downloads&recor=121
Mar 18, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A215-S4747 does not start up.
Have you tried booting from a cd?
It sounds like you hard drive has failed.
Dec 31, 2009 | Computers & Internet
How to restore toshiba satellite factory settings
pls be more specific....
are you planing to format you machine....
what factory settings.....
Dec 10, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite 1805 s204 "media test failure, check cable"....
Did you install the windows system etc? If not boot from the system restore cd and it should work. If it will not boot from the cd-rom then more damage was done then was apparent and the unit would require factory qualified repair. Be sure of the cost before committing to repair since on laptops sometimes it is cheaper to replace the repair. Good Luck
Jul 21, 2009 | Toshiba Satellite A100-S8111TD Notebook
RESET
Just go through it and delete everything left behind.
if you want to do a complete format and reinstall then you can use any A100 system disc (borrow one?) download one from the link below.
http://www.recovery-cds.com/laptop/product.asp?product=5396&ph=search&keywords=toshiba,recovery,cd,get&recor=1&SearchFor=any&PT_ID=all
With some Toshiba models you an burn a recovery DVD from the XP software. Look in programs/ accessories,system tools or use the built in HELP for any info
Dec 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
159 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
