Question about Emulex NetQue Pro2 (NP02) Print Server
Changing the IP address
Is there a way to modify the existing IP address of my NetQue Pro2 print server.
    Problem Solver:
  • 20 Answers
Check with the manual of the server that it is having web based management. If yes make your computer ip and subnet mask as per the ip and subnet mask of print server. open the internet explorer type the url as specified in manual enter the username & password as per manual. there will be the setting page displayed where you van change th eip of the print server. if not please write me which type of management it uses to access the settings.
Posted on Jul 24, 2007
Hi sir how can i change ip address for Dlink printer server DP-301P+
Logon to the Print Server web configuration and begin managing the DP-301P+, simply launch the browser (e.g. Internet Explorer) and type dlink-xxxxxx, where xxxxxx are the last six digits of DP-301P+'s MAC address. The MAC address can be found on the bottom side of
the DP-301P+ device.
Default IP Address of DP-301P+ is set as automatically getting from DHCP server or Router with build-in DHCP server. Please note that the PC's IP Address must be in the same subnet as the print server's IP Address for the two devices to communicate. (For example, if print server's IP
Address is 192.168.0.10, with a subnet mask of 255.255.255.0, then your computer's IP Address should be 192.168.0.x, where x is a value between 1-254, excluding 10.)
For additional information, please refer to Dlink printer server DP-301P+ Product Manual
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 11, 2011 | D-Link DP 301P (DP-301P) Print Server
The segement of the print server you select is different from your computer" on Vista,
Meaning that the IP Address of the print server is different from the computer's IP Address.
If you're computer has a static IP Address, you need to assign a static IP Address for your Print Server. To assign a static IP for the print server, you need to open the PSAdmin utility on your computer, locate the TCP/IP and click the plus (+) sign. Double-click the IP Address and you may change it from there.
Make sure that the IP Address of your computer, router and print server are in the same IP range. And make sure that you could ping the IP of the print server.
Then configure the printer port settings and you should be able to print.
Have a great day!
Jul 03, 2009 | IOGear GPSU21 Print Server
I have a 30H4054 and need to change the IP address
After moving to a new location that had a new IP address, I found I was unable to change the IP address within the 30H4054 so we took the printer back to where it was installed and working before and someone changed the IP address there then brought it back to my new location. So ....have the IP address changed before you move.
Apr 14, 2009 | IBM (30H4054) Print Server
Hi, I have an airlink print server connect to a LAN wit both Wix XP and MAc 10.3 machines. The Win machine work fin e with soft ware and a IP connection, but when I try to print IPP from the MACs I get a...
Make sure you have your IP addresses properly configured. An IPv4 address is made up of four numbers fro 0 to 255 (eight-bit binary numbers) separated by periods, for example, 192.168.1.1. The first three numbers are the subnet address; for small networks, the factory default is usually 192.168.1. Every computer, router, print server, etc., on the subnet must have the same subnet address to communicate directly. (Generally, there is only one router on a subnet). Also, verify that everybody has the same subnet mask (usually 255.255.255.255).
Client computers on a network usually have addresses assigned automatically by the router using DHCP. Print servers and the router should have their addresses assigned manually so the other units on the network can find them at the same place after a restart. Routers typically get address 0 or 1 (e. g., 192.168.1.1). It is a good idea to configure the router to reserve the print server address (or make sure it is in the block of reserved addresses so it is never assigned to anything else since that would cause a conflict (server busy?). Use a high number for the print server address (e. g.,200-255, as in 192.168.1.254, which is the default address for the Airlink 101). On Windows, type <Windows-r> to get the run program <filename> dialog, then type "cmd" to get a command line window. Type "ipconfig /all" to read the IP address information. Type "ipconfig /renew" to get a new address. For information on using ipconfig to modify IP address parameters, type "ipconfig /?"
On each Mac, open the Network control panel, select IPv4, click on "Advanced", then click on "Renew IP lease." Verify that the computer gets an IP address in the correct range from the router, for example, IP address 192.168.1.14, subnet mask 255.255.255.255, default gateway 192.168.1.1. The DNS server will most likely be on a different subnet out on the Internet.
Now you should be able to find the print server using Rendezvous, LPR printiving via IP or AppleTalk.
http://www.airlink101.com/download_links/apsusb1_manual.pdf
The manual linked here is a bit old, but it covers Mac OS 10.3 configuration for a Airlink server. Your server may be a different model, but operation is probably similar unless AppleTalk and other older protocols have been removed.
Nov 19, 2017 | Computers & Internet
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
How to install pocket printer server
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
Aug 07, 2007 | Emulex NetQue Pro2 (NP02) Print Server
Contact
The following link will tell you how to connect a serial cable & set the address: http://205.200.75.226/support/printer/emulex.html
Aug 02, 2007 | Emulex NETQue Print Server
Emulex NetQue Pro2 Print Server how do I connect to it
Oct 04, 2006 | Emulex NetQue Pro2 (NP02) Print Server
Emulex NetQue Pro2 (NP02) Print Server Logo
417 people viewed this question
Top Emulex Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Emulex Computer and Internet Expert? Answer questions, earn points and help others
