Question about Toshiba Satellite A100-S8111TD Notebook
I have a TOSHIBA A 100 laptop, my lp doesnt haqve any problem...but i just wanted to use my Product recovery cd to clean up my hard drive....but when i boot ,,,,and select cd/dvd ....MEDIA TEST FAIL..CHECK CABLE... This message copmes...i dont know why its happening,,,after this messagfe my laptops staqrs normally,,behaves normal,,,but im unable to use my Prodct recovery cd to do the job its supposed to do
  • Roberta Smith
    Roberta Smith May 11, 2010
    do other cd's work in the drive ?
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
Where is the wireless on TOSHIBA SATELLITE 2805-S301
Hi just go this link below:
http://www.user-guides.co.uk/cddownload/Toshiba-Satellite-2805-S301-Windows-7-Driver-CD-Recovery-Restore-Disk-326243.html
Jun 19, 2011 | Toshiba Satellite 2805-S301 Notebook
Gooday Toshiba Experts, My 30MB hard drive HDD2181, has apparently a lot of bad sectors. I am able to format it with a recovery CD. Recovery process is aborted repeatedly. The laptop is Satellite...
With so many bad sectors preventing a format, I would recommend the purchase of a new hard drive. You will most likely need to buy an IDE 2.5" hard drive for your laptop. However, you should double check the manual to see if it uses IDE or SATA. You can get whatever size hard drive you want for it.
I wouldn't recommend any manufacturer over the others, they're all quite similar, almost some people have their own personal preferences. Just look for the correct drive type, space you want, at the price you want. Don't focus too much on the manufacture.
The new drive can be formatted with a recovery CD, however it would be easier to format with the Windows CD when you reinstall the operating system.
May 03, 2011 | Toshiba (HDD2181) (hdd2181-50pk) 30 GB...
I need a replacement hard drive with boot OS installed. Where and what do I buy?
First, are you still under warranty? If so you want to contact Toshiba.
You can get the replacement drive (Toshiba) for about $39 + shipping from newegg.com (They have other Toshiba models also). This drive should be available at other sites also.
This is just an example. I am assuming this is the drive model yours shipped with from looking at few sites, I cannot obviously be 100% sure without having looked at it:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822149127
As for the OS, Hopefully you have some recovery disks that shipped with the Unit or that you made. If not, you can contact Toshiba support.
http://recovery-disks.com/toshiba/toshiba-mini-notebook-nb205-n330bn.html
Looks like a set are $30 bucks. These DO NOT include a OS license, these are just the disks. You should already have the license.
Feb 27, 2011 | Toshiba mini NB205N330BN 101" Netbook ...
System restore factory settings no cd
Toshiba has built in system recovery partition in your hard drive
Make sure to back up important files in your Laptop to usb or portable hard disk before doing this.
Warning: In using System Recovery you files will be deleted, your laptop will be back to its factory settings
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
Feb 01, 2011 | Toshiba Satellite A45-S120 Notebook
Not able to recover windows on toshiba l300
You need to get disk for Vista from anyone and then use your windows product key mentioned on the sticker on back of your Toshiba Laptop to install Vista again on your computer. But as you had already formatted it so all data is lost now.
Jun 01, 2010 | Toshiba Satellite Pro L300 Notebook
How can i full recovery of my pc
You have a bad hard drive...probably. I hope it's a bad hard drive, the other possibility is a mobo and that's a whole lot pricier. Order this drive and swap it out with your current one. I can't be 100% sure, but in every laptop that I've seen with a write sector failure on reload, it results from a bad hd.
get this one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136114
Nov 10, 2009 | Toshiba Satellite A15-S129 Notebook
NO HDD RECOVERY AREA !
first boot pc, then right before windows would start, press either F2 or F8,, I think it's F2, this will bring you to bios settings, look for bootup device options, Set cd-rom as first bootup device, then Hard drive as second device, Then save settings, insert recover cd, then restart pc, it will immediately boot up your recover cd or windows disc
Oct 06, 2009 | Computers & Internet
REPLACING HEADS FROM LAPTOP HARD DRIVE
You will first need a 100% clean room and one of those white jumpsuits. Honestly you will definitely ruin your data if you try it yourself. Usually certified places charge 1000$ to 2000$ to do it. I know Ontrack Data Recovery is pretty reputable business if you want to get it done.
Nov 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Recovery disks aren't Windows XP
Have you tried booting the laptop with the recovery disk already in the CD drive. If the disk doesnt register and start to spin press F12. Should give you option to boot from CD
Mar 07, 2008 | Toshiba Satellite 1135-S125 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
