Question about KitchenAid KESC307 Electric Kitchen Range
Ceramic glass stovetop that keeps beeping...
Thanks for the posted answer. It does in fact have the control panel on the front.
Last night we cut the power to the range all night long and then turned it back on this morning. It seemed to work! I was able to heat up the oven and cook dinner tonight. All was going seemingly well. Now the beeping has started again. It appears that I could heat it up again, but something seems to be staying on, it just keeps beeping a 3 beeps at frequent intervals.
Also, I can't set the clock to the proper time. Don't know if that is related or not.
I am not sure of the model of Kitchenaid Range.
Thanks for any help.
  • Robert Artiaco May 11, 2010
    the model number should be inside the door or inthe drawer.. find it and it could help me out a little more.. are there any error codes that come up? does it say meat probe sensor? when it beeps can you push any buttons?
  • 130 Answers
SOURCE: Whirlpool 465 ceramic stovetop - Locks up in self-clean mode
Try this to get the oven door open. Turn off the power, take a coat hanger and bent at 90 degree angle about 2 inches long. Turn the wire side ways along the top of the door, 2 inches to the right of center, turn your wire so the bent piece is down. Now pull out on the door and move the wire to the left. This should unlock your door so you can get to dinner. What may have happened is that the broil got above 500 degrees at the oven sensor and locked the door for safety. That does happen
Posted on Feb 04, 2008
  • 1073 Answers
SOURCE: replace ceramic top on gas range
yes the part number that you need to order is 316251903
Posted on Apr 13, 2008
  • 2651 Answers
SOURCE: HELP! Stovetop elements don't work and oven burner doesn't work
sounds silll but check your circuit breakers make sure both of the 2 breakers fedding this unit ar in the on positoin , itts possible youve tripped half your circuit.
Posted on Oct 26, 2008
  • 2651 Answers
SOURCE: Replace cooktop
looking at the part breakdown for this unit, doesnt appear to be much a of a problem in replacing the top, teh gasket should come with the new top if not there is one available for purchase, but looks as if all you need to do is remove the frame(look as if 2 screws in either rear corner will release this)afeter that the glass should lift right up simply replace with new and re-secure the screws, be gentile however the new glass can be fragile, so make sure ut fully sits flat in the spot before trying to tighten back into place
Posted on Dec 15, 2008
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
I have a small Gemco coffee pot with no directions. It says "do not use on stovetop",but does not say micro on it either. How do I use it? Pls. help.
I can't answer your question but clearly if there is any metal in the construction of the coffee pot it should not be heated in the microwave oven.
Ceramic coffee pots aren't intended to be heated in order to make the coffee. The coffee is either made in them by adding hot water or made in another utensil and poured into the coffee pot for serving and perhaps kept on a gentle hotplate in the meanwhile. Glass coffee pots are treated in a similar way.
Metal coffee pots and jugs can be used on the stovetop even though it isn't a good idea except for "cowboy coffee" when dry ground coffee is scorched in the jug before pouring on boiling water; steel is best for this.
I have used all manner of glass, ceramic and metal coffee pots and jugs on the stovetop but always using a heat diffuser - two layers of perforated steel with an airspace in between.
A coffee maker is a different thing and must be heated fairly vigorously. I find an old electric percolator is still the superior method of making coffee.
Oct 24, 2016 | Coffee Makers & Espresso Machines
Hi I am just wondering is anyone knwos how to change the temperature on a schott ceran glass hob ? It works fine apart from the fact that once it reaches the required temperature it cuts out , cools down...
many ceramic glass units operate like this
check the user manual on the operation but it is that way to prevent the glass from overheating and stress cracking
Jun 16, 2017 | Cooktops
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
Just bought a house with a Kenmore ceramic top range. model is 790.9601. The red light on the top left of the panel that indicates that a burner is hot keeps blinking even though the range hasn't been...
Sorry to read about your problem, I hope this helps you out.
those are hot plate sensor's just to let you know, that glass maybe hot, they will turn off when the stovetop cools down.
now if you happen to put a hot pan on the cook-top, lets say from the oven. the lites will come on.
in your case I think is is defective and staying on
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Kenmore Kitchen Ranges
Hello. I have a Kenmore Ultra Bake, with push button control. After wiping down the panel it went crazy. The panel is now showing EO F2 and continuously beeping. I can use the stovetop, but can't turn...
Thanks for using FixYa. Error F2-E0 on your oven means that the keypad is shorted and to resolve this issue you'll have to replace the electronic range control/clock(ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Sep 15, 2010 | Kenmore Ovens
Went to start a load last night sound like it was going to run but after a min. the water had not started and then a f70 flash on the screen and now it just beeps when you push start no light just sound
Thanks for using FixYa. Error F70 is a communication error between the Central control unit (CCU) and the user interface. To start with you’ll need to check continuity of the user interface and then check the wire harness connecting the user interface & central control unit. If the drum is not moving then central control unit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a kitchenaid ceramic stovetop. recently I used the self cleaning oven and now it seems to not operate correctly. there is a frequent beeping noise....
is it the glasstop range with the oven control panel in the front? if so one of your over temperature thermostats is faulty.. it is probably causing an f-1 error.OR.. your temperature probe in the oven could be going bad.
Jan 01, 2009 | Crosley CE35111AA Electric Kitchen Range
Keeps beeping
stuck door switch or mis coommunicating control board
Dec 19, 2008 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Soup boiked over on stove top
I had some luck removing food and other stains with the new Vielda Glass Ceramic Scrung (its a sponge)
"Special scour sponge for cleaning glass ceramic cook tops without scratching. Eliminates burnt-in stains and greasy dirt film. Removes grease and loose dirt particles. Microfibre side will create a streak free finish."
I found mine at Walmart. It was a little pricey but if you just use the sponge for the stovetop then it will last a very long time.
Hope this helps.
Dec 17, 2008 | Kenmore 95592 / 95594 / 95595 / 95599...
KitchenAid KESC307 Electric Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
