Question about Epson Stylus CX3810 All-In-One InkJet Printer
I just replace my ink,,, it indicates i have no ink,,, and wont print.. i been on the phone for hours tryna have someone walk me through it,,, can you help?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
I replaced with a new black ink cartridge for my cannon 310 and i get a col ink volumn message and it wont print , the first sheet goes through with no print and the second sheet jams. What can I do
Jamming is surely not related to ink replacement, however the blank page may indicate there is dried ink blocking the stream of the new one since you are probably not able to clean the path of the ink i highly reccomend to call the local service technician or replace the related parts on your if you have possibility to do so.
Mar 28, 2017 | Cannon Office Equipment & Supplies
I replaced all the ink carts in my hp photosmart premium c309g printer know the blak wont print at all and all the color prints faded. What do i do?
The ink may not reach the printhead completely.
You could wait at least 1 hour before printing.
Also do a ink cleaning cycle.
Feb 03, 2011 | HP Photosmart Premium C309g multifunction...
Printing
You turna da printer upside down and shake a leedle. probly a rok or sumting fell in where da wheely ting is that pull the paper. sumtime just a ink pen or candy.
Apr 20, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Black ink cartridge not empty, but won't print black...
Try running the cleaning tool included with the HP diagnostic software for your model printer. If that doesn't work, try cleaning the ink jets on the black cartridge directly with an alcohol swab. If this still doesn't work and you're sure that you have the correct model HP cartridge installed properly in the printer, you may have to replace the black cartridge with a new one to see if the cartridge itself is defective.
Oct 02, 2017 | HP PhotoSmart C4480 All-in-One Printer ...
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Cannon mp830 prints all colors but yellow
Your print head is likely toast.
The only way to be sure is to test out your purge unit (aka capping assembly).
This assembly provides the suction when you use the cleaning function. One test is simply to install a new oem ink cartridge, do a bunch of cleanings and see that it is actually emptying the ink out of the cartridge (look in the cartridge and see that the ink is being used up).
Since you said you have tried several cartridges, I would hope this means you know 100% for sure that the ink level in the cartridge is going down (you cannot rely on the level indicator in your driver software).
Since your purge unit is working, then your print head is either so clogged that the purge unit isn't strong enough to clean it, or the print head is defective.
Remove the print head and inspect the bottom. Give the bottom surface (and no more) a rinse under very hot running water. Blot the bottom surface on paper towel and see if there is any yellow ink coming off in the paper towel. If you can find a tube that will fit over the yellow ink well in the print head (the part that contacts the ink cartridge) try and force water through the tube and see if a fine mist comes out the bottom of the print head. If yes, then the head is not clogged. If no, leave the print head to soak for several hours. A saucer with a small amount of water in it will do. Just let the bottom surface of the print head contact the water (the cap off of a can of spray paint usually works for this)
Let the print surface soak for a few hours, or even over night. Reinstall the print head and give it a deep clean. If it still does not work, call your local Canon repair shop and check the price of a replacement head.
Nov 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cannot print in color - HP C6180
hi,
below is the document that i would like you to follow. If still the document wont resolve your issue, please call 1-800-474-6836 for tech support. Also, check the warranty of the printer, and if the tech found out that its an ink problem, then they can go ahead and have it replace.
CLICK HERE ==>> DOCUMENT
thank you.
adonscott
Sep 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Replaced Original Black Ink Cartridge but still bad low ink prints and low ink indicator lit.
Sounds like the print head is dirty take some rubbing alcohol and qtip and clean the print head.
Dec 03, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Epson Stylus  CX3810 All-In-One InkJet Printer Logo
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
