Question about Dell Inspiron 2200 Notebook
Help me... dear expert, i've got a problem with connecting notebook with projector. there's only a display on the startup windows, but after login, there's no images shown. but then, when i connect desktop pc to the projector, its work???? could you please help me? i've try to change the resolution setting, but no works. regards.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, have you tried pressing Fn + F? keys on the notebook to cycle through the choices; notebook display, notebook display + external, external only. The F? key would be one of the function keys with the small monitor icon.
Additionally, you may want to lower not only the screen resolution but likewise with the screen refresh rates.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Jan 02, 2009
Short circuited laptop motherboard
get a new motherboard that is simplest and most effective
May 29, 2012 | Acer Computers & Internet
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
T30 cannot connect to projector/external monitor on windows 7.
You can connect your computer to a projector to give a presentation on a large screen.First make sure the projector is turned on, and then plug the display cable from the projector into a video port on your computer.
Then press Win Key+P or run DisplaySwitch.exe and choose your preferred display.
Note:1.You can use this same procedure to connect your computer to a monitor
2.This will have no effect if you’ve only one display connected
Nov 09, 2009 | IBM ThinkPad T30 2366 Notebook
No display on expantion vga port for projector
The problem might be related to your native screen resolution. The C702TU laptop has a resolution of 1280 x 800. Most projectors do not support this resolution and if you cloned the main display, your projector cannot sync at this resolution. Look for an option to output a second display )instead of cloning) within your display settings. If your projector is plugged into your VGA port and turned on, Windows usually detects the second display automatically. Change the resolution on the second screen to something like 1024x768 or 800x600. These resolutions are supported almost universally across projectors.
Jan 18, 2009 | Compaq Presario Notebook
I have a Gateway mx3422 notebook. I cannot get the display to clone when I hook it up to a projector. The notebook screen goes black and the display shows on the projection screen.
hi!!!
there is a setting in your desktop
try go into control panel
then click on display then go to
settings and the
advance try locate the dual monitor settings
Oct 31, 2008 | Computers & Internet
"no signal " on the screen
After half a day of tinkering around with my new Acer I fixed my problem, which I think is yours also. I connected it to my notebook, it read the signal 'D-Sub' or something like that, and after my notebook finished startup, it reverted to no signal. I tried it with my desktop and it worked just fine. The display will only show up on one output device. It worked fine on my desktop because I was unplugging my monitor in order to hook up the projector. Hooking the projector up to my notebook left the display panel still active and that was where it displayed. In case I'm not making sense, the solution is this: After setting everything up, hit Control+Alt+F1 to switch display from your screen to the projector. To switch back, hit Control+Alt+F3
Oct 15, 2008 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
HP Pavilion Dv2000
on your display properties, switch windows to appear on your laptop. and do not connect your LCD when booting your PC. there is an option in display property that says extened your windows to this display... that is your LCD.
Apr 10, 2008 | Acer TravelMate 2300 Notebook
LCD projector no signal message
you may need to go into display setting and check that these setting match the ones for the projector
Nov 27, 2007 | Acer Aspire 3000 Notebook
Connecting notebook to projector
Hi, it is possible that your notebook is set to a high resolution that your projector cannot handle. You may want to try to: 1) run your notebook as is (without connecting to the projector); 2) soon as windows booted up, right click on any clear area of your desktop and click on Properties; 3)Go to the Settings tab; 4) Set the Screen resolution to the lowest possible setting, towards left (less) and the Color quality to the lowest possible. Clilck Ok then reboot. Run once to see everything is OK except your icons are bigger now. Youo can try connecting your projector to see if it works. Hope this be of help to you. Cheers.
Apr 20, 2007 | Toshiba TDP-S8U Multimedia Projector
Dell Inspiron 2200 Notebook Logo
67 people viewed this question
Alun Cox
