Question about Samsung DVD-R155
Samsung dvd-r150 reset factory setting
I changed the region code on my samsung dvd-r150 but now I can't change it back. How can I reset the factory settings?
5 Suggested Answers
SOURCE: need setting to change regional code on samsung DVD P172
My samsung is a dvd1080p7
Posted on Apr 02, 2008
SOURCE: please can you help me
its a generic problem, open the dvd tray and keep it open, go to setup with remote and look for factory reset/default (might be inside preference settings) ok on factory reset..you might need password from your manual :)
Posted on Jul 04, 2008
  • 146 Answers
SOURCE: changing to multi region dvd
There are a couple sites I found that offer the codes for that player and the BD-P1000. I am not sure if I am allowed to post the links for those sites but the link to the site zimcloud posted is one of the places I saw it listed. You can google the model and region code and a list of sites come up.
Cheers
Posted on Jan 03, 2009
  • 189 Answers
SOURCE: Problems changing region code on Samsung DVD player VR 375
HELLO!
Give these a try!
Power ON
Press MENU
Enter code 57538
The current region code appears
For codefree/multi-region press 9
Press Open DVD door button
Power OFF and power ON
You could also try this!
Turn player on without disc inside Press MENU button
Enter your region code (See list below)
Highlighted 'region area number' will appear in the upper-left corner (on some players)
Press 9 to multi-region the machine
Turn machine off
Region 1 - 29334
Region 2 - 38767 (or 5 7 5 3 8)
Region 3 - 56732
Region 4 - 76884
Region 5 - 53814
Region 6 - 24462
Have a go and good luck! (:-)
Posted on Sep 11, 2009
  • 217 Answers
SOURCE: code for unlocking dvd regions samsung r155
hi,
1.Turn on R155 without disc inserted
2. Press and hold Play and Stop for 5 seconds then release
3. Press menu
4. enter code for current region as above i.e if you have a region 4 type: 7, 6, 8, 8, 4
5. The region is displayed in the top right.
6. You have about 5 seconds to enter the new region (1,2,3,4,5,6 or 9 for multiregional)
Region codes for Samsung:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8)
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
Thank u
Posted on Oct 07, 2009
Does anyone know how to unlock the region code for Thomson JL2313I DVD player
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in this key phrase "How to unlock the region code"; in the search box at the top left of the display window, to get gathered related posts.
Jan 11, 2017 | Thomson Televison & Video
Samsung LED model un50eh6000fxza just lost video and audio. Screen went black no audio.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jan 09, 2017 | Samsung Televison & Video
My samsung smart tv hdmi ports do not work anymore
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Truetech 10 inch under the counter tv is stuck on channel 2. I need 3. Channel buttons on tv & remote do not change 2 to channel 3. Unplugging, Resetting hasn't worked Any ideas?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jan 08, 2017 | Televison & Video
How to reset my tv
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done..
Jan 08, 2017 | Samsung Televison & Video
My sh100 is stuck on the menu screen when you turn it on
Do a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
WHERE IS THE RESET BUTTON ON MY TV
What is the brand name and model number of the TV. Can't say anything without these information. If the set is not too much older model, there will be no such button marked as "reset". For modern sets, if you have to do a reset, you should enter its service mode. It is somewhat skilled procedure.
I have a GPX TV/DVD combo Model # TDE2280B. I have only used it a few times -- now will not play a DVD even with a external DVD player connected to it -- "no signal" is the only message I get.
Have you tried resetting the set to factory default.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 06, 2017 | GPX Televison & Video
Change Panasonic DVD-S27 from region 1 to region 2
What is the full model and serial number please?
Jan 05, 2017 | Panasonic DVD-S27 DVD Player
Where is the set button on a samsung universal remote Bn59-00673
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
May 12, 2015 | Samsung Bn59-00673a Remote Control
Samsung DVD-R155 Logo
1,238 people viewed this question
Jerry Greenberg
Jerry Greenberg
