Question about Samsung SyncMaster 214T 21.3" LCD Monitor
Image blur Hi, When i open any image in my system, it looks blured. I am using samsung syncmaster monitor. Do i have to install any driver to solve this or change any settings? please help. Lee
  • leela_kb Jan 04, 2009
    I have already set the resolution you have mentioned 1440X900. Still i have the problem.
  • 130 Answers
Try unplugging and replugging the monitor cable from the monitor and the computer.
Posted on Jun 12, 2009
    Champion:
  • 220 Answers
You need to check that display resolution in your Display properties is set to the native resolution for wide monitor typically 1440><900 for the size you mention.
Blurred image is due to using 4 : 3 resolution setting of 1024 >< 768 on a 16 : 9 wide monitor.
Samir.
Please rate the solution and provide feedback.
Posted on Jan 03, 2009
Samsung syncmaster 914v monitor problem. Right side of display is darker image. Can see dots like a newspaper print or looking through a screen. When display is black it almost appears like an image is...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung SyncMaster 730B LCD monitor isn't backlit at all
Most failure in LCD monitors are due to cheaply made caps being use. If you are going to DIY repair, please read below, or if you are going to have it fixed then at least you will know if you are being ripoff or not.
Apr 22, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Blurred image in Samsung Syncmaster732nw monitor
For best pictures, you need to set your PC video resolution to the native resolution of this monitor, which is 1280x1024 @60Hz. Try that first before opening up the monitor to look for bad components.
Post back, see what usually goes wrong with SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Samsung lcd 913v self test ok, no image when vga connected
This problem often occurs in samsung SyncMaster LCD monitors.
The solution is open your look for the LCD monitor power supply module (which have PCB connector to the AC power), on that board look for capacitors, now look for broken one which upper part is bloated, like the image below:
If you find a damaged capacitor as in the picture then you should replace it with the same value.
Jan 22, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
Hi, my monitor is "Samsung SyncMaster 793df". Problem is i can't set right color and contract. how can i solve it?
If the monitor has a consistent tint throughout, try to adjust the color through the OSD (On Screen Display). If this does not resolve the problem, or your monitor seems to be missing a color, disconnect the signal cable from your computer and wait for the No Signal image to appear. If all colors - red, green and blue - are present in the No Signal image, the problem is not with the monitor, but possibly with the video cable or video card. - exert from samsung faq....
http://ars.samsung.com/customer/ctry/jsp/faqs/faqs_view.jsp?isINPUT=Y&SITE_ID=58&PG_ID=-1&AT_ID=48749&PROD_SUB_ID=0&PROD_ID=28
If you mean something else, go into a little more detail if you wouldn't mind... Also, another thought has popped to my mind, you do have the drivers for your monitor installed?
Jan 13, 2009 | Computers & Internet
Blurred images at start on samsung monitor
This is CRT Base Problem Simply Replace it
Thank You
Mar 09, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Computer Image
the picture quality is better on smaller monitor due to higher resolution i.e the image can only be reproduced at a maximum resolution as specified by the by the manufacturer. for instance 1366x768 for the 460p
Jan 14, 2008 | Samsung SyncMaster 460P 46 in. HDTV-Ready...
Blured image
Try an external monitor if the same persists then its the original drivers for the monitor that needs  to be replace normally Windows should adjust automatically.
Oct 20, 2007 | Computers & Internet
Samsung SyncMaster 214T 21.3" LCD Monitor Logo
232 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
