Question about Samsung 15.3" LCD Monitor
My samsung monitor was working just fine yesterday but today the screen is black and the green light is flashing....I have made sure that all the cables are properly attached...
    Problem Solver:
  • 8 Answers
Step one is to try hooking up your monitor to a different computer. If that does not yield a different result then it is likely going to be a problem with the power circuit in the monitor.
If your monitor is still under warranty then you should be ok, if not then you can contact Samsung for help by using THIS webform.
You may also be able to get this fixed at a local TV repair shop, but you best answer, considering the smallish size of that monitor would be to go buy a new one. Many decent LCD monitors can be had for about $100.
http://ars.samsung.com/customer/form/formmail/usa/input_SEA.jsp?SITE_ID=1&PROD_ID=28
Posted on Jan 02, 2009
Compaq 610
Need to replace the black light, that lights up the screen.
Oct 31, 2013 | Computers & Internet
Have A Samsung 940Bw connected via DVI connection and has worked fine for last 3 years. Monitor was on and working fine went out of room and came back to black screen and the blue light flashing on the...
First thing I would try will beusing this monitor with another PC using the same the same setup to see if it works OK. We need to narrow down the cause of the problem first since you have three parts that can be bad; Monitor, DVI cable, PC Video card/PC. It is just a process of elimination to locate the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 14, 2011 | Samsung Syncmaster 940BW LCD Monitor
Hi I wonder if you can help me. I have the flatron L1918S monitor and it was working fine yesterday, however today when i turned on the pc, the monitor flashed the green light on and then goes into power...
When after power up the computer press num lock key if num lock led is flash on and off when you press num lock key then your cpu is working fine.But if it stay constant then open cpu cabinet cover then reconnect RAM memory and processor and it's fan pull cmos cell from motherboard for 10 minutes then reconnect it then check.Make sure motherboard is not ground with cabinet. If num lock led is on and off then when you power up the computer press F8 key 5 to 6 times so you can see safe mode and other menu then enter in "Enable vga mode" then go to display property ->settings change screen resolution to 1024*768 then apply and ok. then check. If everything are fine in cpu then your monitor need repairing. Let me know if you need further assistance. Thanks for using FixYa.
Aug 25, 2010 | LG Flatron L1919S LCD Monitor
Samsung lcd monitor power button flashes and wont turn on or off
I have the same exact problem. The monitor seemed fine yesterday. Today, the power button light just flashes on and off, with nothing on the display.
Dec 05, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung 191T Blank
You need a fluorescent back light and inverter kit. Available on eBay.
Jun 10, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
Monitor flashes on when I turn computer on, then screen black
Your monitor power supply or inverter board have gone bad. Its not your computer video card
Apr 17, 2008 | Westinghouse LCM-19v1 Monitor
Monitor Flashes Gray, Then nothing
try to decrease the screen resolution. try to 640 x 480 then raise to 800 x 600. for old CRT monitor maybe have a problem with 1024 x 768. if decrease not work, then you might have a hardware problem, you need to purchase a new one. try the test first. maybe you can test with your monitor of your friends first :-), if work, you need to purchase a new one.
Feb 17, 2008 | Acer AL1916W 19" LCD Monitor
Sony FWD-42PV1 -
I diagnosed the same problem on my FWD-42pv1 as a problem on the Y-SUS board. The fuse on that board was blown, and the board itself was bad (replacing the fuse was not enough to fix it). The symptoms were exactly the same - the LED cycling red/green, and then finally stuck at red.
With a new Y-SUS board, the TV has been working fine for a couple months.
Jan 26, 2008 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Computers & Internet Logo
230 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
