Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
How i connect my laptop with desktop via LAN - Microsoft Windows Vista Home Premium with Service Pack 1: Windows
You can do this through USB Lan cable or Cross cable
With the help of Cross cable just give the autometic IP setting and you can access share document of any of your device.
Ashish Gupta
09837756825
Posted on Jan 02, 2009
How to connect a desktop and a laptop through lan
you will need to have a lan cable and also the need to create a lan network both computers
Jun 24, 2012 | Sony VAIO VGN-S460P Notebook
I am trying to connect my toshiba a15-5129 in my house it will not connect to broadband
Hi, we have two ways to connect to broadband, via wired or wireless, at the device manager please do check if the LAN drivers are enabled, if enabled, via wired connection, simply put the RJ45 jack from LAN port of your router to LAN port of your notebook, if configuration is already set in your Router LAN, it will just automatically connect. If connecting via wireless press wifi button to activate wifi connection then windows will pop for your access credentials. simply put the password for your connection once the name of the site displayed.
Jun 20, 2011 | Toshiba Satellite A15-S129 Notebook
I want to start inter net from my laptop what to do
Hello Punitrava, Hi, you can connect to the internet several ways, here are the common ones. 1. Via a free WIFI hotspot, find a WIFI area like in malls or coffee shops and enable you WIFI connection on your laptop. after enable the laptop detects the wireless connection and simply connect. 2. Via a USB modem, inquire about this on your wireless telephone company. 3. Via the Local Area Network like computer shops, insert any available LAN cable on your LAN connection, you need to consult the LAN administrator. 5. Via a DSL connection, just plug in the LAN cable from a DSL to your laptop. you need a DSL/internet account from your telephone company.
Jan 08, 2011 | Compaq Tablets & eReaders
DWA-160 adapter going slower than dial-up
nek arep baner yah mas kuwe ku sing madan larang lan bermerek terkenal...nek ora ngerti brarti kowe bodo nemen alias gatek
Aug 11, 2009 | Computers & Internet
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
How to connect a laptop having vista home basic with a xp desktop
Be advised that,
it makes not different to connect one PC/Laptop to another one via LAN because when you connect your system in lan networking you system will be automatically detected if LAN has been set up through a server.
And if not you need to do manually by assigning ID address on bot PC/Laptop.
For that,
first assign an IP address in either Laptop or desktop (IP address must be same category)
ex.
192.168.1.231 (first one)
and second one should be
192.168.1.here you can up (instead of 231) any number excep 0 but make sure not confliction between other system. means not duplication IP address on same LAN.
once you ae done with IP assigning
Go to
Star>Run>command and hit enter
once you see command prompt then
type there:
ipconfig and hit enter (it shows your ip address) if you wanna have more info then type ipconfig/all
once you are done with this then
you need to ping to your next PC.
for that
type in
ping 192.168.1.231 (means you need to type another PC's IP address here)
and hit etner
if you see like on image
then you are good to go.
Thank you
and rate all answers.
Jan 02, 2009 | Microsoft Windows Vista Home Premium with...
Shared internet connection help!!!
are you using window xp for both pc?
Aug 25, 2008 | Computers & Internet
I'm unable to surf the web on my PC via a LAN connection to my P660HW Wireless ADSL Modem Router. I can connect and surf the web via a wireless connection on my Laptop.
Hi
Check wether the network card driver is properly installed in your computer and try to change the lan cable and check.
Jyothish
Jul 13, 2008 | Computers & Internet
Apple user attempting to fix dad's dell laptop windows xp home edition
I'm confused because you say your trying to make a lan connection on the dell laptop but your connecting it via firewire into a DSL modem. doing this method would be a WAN connection and not a LAN connection. To make a lan connection you need to connect the laptop via network cable (or wireless connection) to a router that is connected to your actiontek dsl modem.
I can help you connect the laptop to the internet but 1st i need to know if your trying to connect it to a router or did you want to do a wan connection from the dsl modem.
Thanks,
Brad Nelson
Mar 15, 2008 | Actiontec (GT701WG) Wireless Router
Unable to connect via LAN with wireless router NETGEAR WPN824
I recently experienced this on laptop and desktop, using a lynksys wireless. I was able to go into each system to network connections, and tell it to connect. I haven't had a problem since........hope this helps you!
Dec 24, 2007 | Computers & Internet
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
71 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
