AP always restart
I need to reset an airlive WH-5400CPE because always restart AP time reconfigure ip address on the lan. I have also open it but I didn't found any botton. Please help me. Thank you.
  • 3 Answers
I checked it out and it seems you don't have to manually reset/reboot it. You just have to log on to the AP, then choosing REBOOT after you are done, then the changes will that place annd you should be fine.  Note: due to the built-in internal directional patch antenna, repeater mode and WDS option do not apply in WH-5400CPE.
I hope this helps you. Enjoy!
http://69.64.87.53/airlive_fileserver/uploads/English/support/SD1218435928270.pdf
Posted on Jan 04, 2009
I forget a pasward air live 5400cpe now what i do
you would need to directly connect your computer ( Laptop ) and access point.
check ip address of your access point in Command prompt = ipconfig
once you have your access point's ip, pull up a browser ( Internet Explorer ) and place ip address on the address bar and press enter. once your inside the GUI (Graphic User Interface ) of your AP, click wireless security so you can see your password.
May 31, 2011 | Computers & Internet
The router was reset. So, our AP does not work with it anymore. I reset the AP to restore it to its factory default settings and tried to follow the steps I made before in configuring the AP. but i can't...
Before you configure this device, note that when the AP is configured through an Ethernet connection, (via RJ45 Network Cable) make sure the manager PC must be set on same the IP network. For example, when the default network address of the default IP address of the AP is 192.168.1.1, then the manager PC should be set at 192.168.1.x (where x is a number between 2 and 254), and the default subnet mask is 255.255.255.0.
Open Internet Explorer 5.0 or above Web browser.
Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the address location. Please refer here to the Latest User Manual for Encore ENRWI-G Page 9 onwards describes the login details.
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Encore WIRELESS LAN EXTENDER
My modam siemens c2110 not open 192.168.1.1 &link no show.pleas
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access it then press RESET button for router for 10 seconds so all settings defaults .Then you can access it with above default ip. Then reconfigure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 13, 2010 | Computers & Internet
My G Mimo Plus adapter won't pull and IP address. Any suggestions?
Is there a RESET button on the back of the router, if so power it up and press the RESET button until all the LEDs flash and reconfigure the router.
Try a different LAN cable, the other could be faulty
Install the latest LAN and wireless card drivers (this problem sometimes occurs when you install a new router).
Check the LAN and wireless cards are functioning correctly in Device Manager.
Open the DOS cmd window.
Test the NIC - loopback test address - ping 192.0.0.1
Ping the router's IP configuration address
Type ipconfig to see what IP address you get (if any)
Type inconfig /renew all - this will (should) get a new IP address from the router's DHCP
Let me know how things work out.
Dec 24, 2009 | Belkin Wireless-G Plus MIMO Router with...
How to configure my tcp/ip TP-link access point
The router has both a "WAN" (Wide Area Network) side
and a "LAN" (Local Area Network) side.
On the WAN side, most ISPs (Internet Service Providers) will provide the values for IP-address, subnet-mask, and gateway.
On the LAN side, you should just use the "default" values.
Connect your computer via an Ethernet-cable to the router,
and the router will supply values to your computer,
so that your computer can communicate with the router.
Nov 06, 2009 | Computers & Internet
TALKING ABOUT THE ACCESSING THE IP ADDRESS ON THE DWL-2000A,I DON'T THINK I UNDERSTAND THE SOLUTION TO THE CONNECTION BECOS THERE IS ONLY ONE LAN PORT ON THE AP WHICH ONE CAN CONNECT TO THE MODEM. SO IF...
To connect the AP directly to your PC you sould need a "crossed" LAN cable.
On you PC you need to set a IP Address of the same subnet of DWL-2000AP (defaul IP is 192.168.0.50) like 192.168.0.xxx
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and select "Internet Protocol (TCP/IP)", click properties, now set followingIP address:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Confim clicking OK OK OK...
Now you can access you devices tipyng http://192.168.0.50 on your prefered browser. Default login is "admin" as username and empty password.
Let me upate.
Sep 13, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Connecting Compex 28g to mobile broadband and home network
please check following points:-
1) IP address (some wireless AP's follows ip address such as 192.168.1.1 for AP and 192.168.1.2 for 1st workstation, 192.168.1.3 for 2nd workstation and so on).
2) check connection options in IE. it should be lan setting and detect automatic setting and use automatic configuration script(put IP address of AP)
3) if DHCP is enabled then obtain IP automaticlly
4) check for any WEP security options i AP.
5) user must have internet access rights.
6) if Static IP is Used please give gatway ip (your AP's IP address) and same for DNS IP address.
then restart your system and enjoy internet.
May 01, 2009 | Compex NetPassage 28G Wireless Router...
Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Oct 30, 2008 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
Reset Airlive WH-5400CPE
I had the same problem and got the resettor software,it still did not reset the cpe, i took matters into my own hands and shorted the sw1 jumper on the board for about 30 secs.
There 5 small silver strips, 3 are right next to each other ,the other 2 are apart and also next to each other. Short the 2 that lie side by side for about 30 secs and your cpe is reset to factory default.0747e01.jpg
Jul 10, 2008 | Computers & Internet
Problem password airlive wh 5400-cpe
There should be a reset button in it. Have a look around, when you find it, press and hold it for 30seconds, after that it should return to default settings.
Mar 25, 2008 | Computers & Internet
Computers & Internet Logo
500 people viewed this question
David Payne
David Payne
