Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
How to connect a laptop having vista home basic with a xp desktop
How to connect a laptop having vista home basic with a desktop having windows xp via LAN
    Sergeant:
  • 183 Answers
Be advised that,
it makes not different to connect one PC/Laptop to another one via LAN because when you connect your system in lan networking you system will be automatically detected if LAN has been set up through a server.
And if not you need to do manually by assigning ID address on bot PC/Laptop.
For that,
first assign an IP address in either Laptop or desktop (IP address must be same category)
ex.
192.168.1.231 (first one)
and second one should be
192.168.1.here you can up (instead of 231) any number excep 0 but make sure not confliction between other system. means not duplication IP address on same LAN.
once you ae done with IP assigning
Go to
Star>Run>command and hit enter
once you see command prompt then
type there:
ipconfig and hit enter (it shows your ip address) if you wanna have more info then type ipconfig/all
once you are done with this then
you need to ping to your next PC.
for that
type in
ping 192.168.1.231 (means you need to type another PC's IP address here)
and hit etner
if you see like on image
then you are good to go.
Thank you
and rate all answers.
Posted on Jan 02, 2009
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Our laptop won't connect to our network set up on our desktop home computer. The desktop is running Windows XP Home Edition V2002, and the laptop is running Windows Vista Home Premium V2006. When we try to...
if you have wireless acces point or 802.11 known as wi-fi,
there might be a problem in your laptop internet protocol, you laptop have an ip address already.
you can fix it by using your desktop, open your desktop go to control panel/network connection/status/
details.
copy the details information and put it to your laptop internet protocol. you can found it in network connection properties you can see Internet Protocol (tcp/ip) open it configure it manually. the last number of the ip address must bigger than the desktop. ex, 192.168.1.2 in desktop. the ip address of the laptop must be 192.168.1.3.
Feb 02, 2011 | Acer Computers & Internet
In your laptop Open Control Panel > Network internet > Network and Sharing Center > Set up new connection or network > match with setting in your PC > Finish. Try to reconnect.
I have have downloaded the HP Laserjet 3015 Print driver on my Lenovo U330 Laptop with Windows 7 Ultimate. Unfortunatley, I've tried 2-3 times to with no success. Am I having a compatiblity issue with...
File name: s.gif upd-5_1_1_8232-pcl5_winxp-vista-x64.exe [1/1, 15.21M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Client operating systems supported:
  • Microsoft Windows 7 Starter, Home Premium, Professional, Enterprise, and Ultimate; x86 and x64
  • Microsoft Windows Vista Business, Enterprise, Home Basic, Home Premium, and Ultimate; x86 and x64
  • Microsoft Windows XP (SP2 and later) Home Edition, and Professional; x86 and x64
    *Note: Microsoft retired mainstream support for Windows XP in April 2009. HP will continue to provide best effort support for the current UPD and tools for the discontinued Windows XP operating system until 2011
Oct 25, 2010 | HP LaserJet 3015 All-In-One Printer
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Connection to server failed account ntlworld server pop.ntlworld.com protocol pop3 port 110 secure (ssl) no socket error 10061 error 0x800CCCOE. This message appears when I use my laptop which uses vista...
Verify the setting via Manage accounts on your XP machine (the one the email client works on) in whatever email client you use on it and verify and edit if need be the setting in your Windows Live Mail on your Vista home Laptop.
Jul 15, 2008 | Computers & Internet
Windows Vista home + Windows XP Professional Networking issue
Make sure domain settings to your server are correct on the notebook computer. These settings are located in the control panel of the system setting.
Whats the operating system of your server?
Make sure the firewall in windows security is turned off too. Sometimes that thing sneaks up on you.
I haven't used the home edition of Vista but another reason why it might not be working is because it isn't the business version. Microsoft might have added extra security to prevent the home version from connecting to a server. I know we use the business version of Vista at work and it is working that way on the intranet server without a problem.
I would check with Microsofts website on that.
Jun 21, 2008 | Microsoft Windows XP Professional for PC
Unable to cnnect internet on vista home basic
check the NOKIA site for compatibility issues for VISTA. VISTA has compatibility issues with many softwares (which may include the improper driver for your N 72)
May 24, 2008 | Computers & Internet
Down grade to windows xpsp2
Only OEM editions of Windows Vista Business and Vista Ultimate can be downgraded to Windows XP Professional. Microsoft offers no downgrade rights for Vista Home Basic or Home Premium.
Sorry
Dec 01, 2007 | Acer Aspire™ T180 PC Desktop
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
76 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
