Question about Lexmark X5470 All-In-One InkJet Printer
My lexmark X5495 always prints banner
Everytime i load a pdf and try to print i go into my settings on this infernal machine and NOTHING is set to print a banner. its all set to plain. but it always brints in banner mode and screws all of my documents up. even when i print 1 page it prints 2 but one has the document loaded on it while the other is blank. there is nothing in the troubleshooting to solve this. PLEASE HELP
    Scholar:
  • 107 Answers
Not sure which OS, you're using, but try this:
Go to Start > Printers > right-click your PDF printer and go to Properties
Go to Printing Preferences and ensure in all possible locations there that you don't have "banner" selected.
Posted on Jan 03, 2009
Cant get laptop dell inspiron m5040 to print from lexmark x5495 printer
Use an updated driver. You can download it here: http://bit.ly/Qb8DWE
Oct 03, 2012 | Lexmark X5495 Printer
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
Lexmark X5495 printer cannot communicate with the printer, I can scan images from the same printer, but cant print. Tried to unplug the cables, restarted the systems, uninstalled and re-installed the...
If you can scan the USB port, it should be OK. If "copy" works correctly and you have recently installed drivers, try resetting your computer and selecting the printer as "default." Check if there is an impediment on the printer panel, blank cartridges or another error. The printer can scan but can not print if it has empty cartridges. Study the user manual on http://publications.lexmark.com/publications/pdfs/2007/5400-plus/v6592051_en.pdf
Nov 04, 2017 | Lexmark X5495 Printer
Hi, I have lexmark printer, model X5495, and I am having problem with the machine. The alignment is on, and whenever I tried to make copies, the paper is all cramped up and got stuck. I cannot find my...
Try removing the cartridges from the printer. Close the cover. Remove the sheets of paper. Unplug the printer from the power source. Replug after 30 seconds. When the printer's ready, reload the cartridges. Load some paper, don't overload. Try printing again. If problem continues, I strongly suggest you contact Lexmark technical support to further investigate the problem. You may be having a hardware problem.
Here's the link for the Lexmark X5495 User's Guide: http://bit.ly/c5QWkq. Just download it and it's for free. Thank you for choosing Lexmark.
Aug 25, 2010 | Lexmark X5495 Printer
My Lexmark x5495 will not print. I get the message enable bidirectional communication. I am running XP operating system. What is the solution?
Go to Control Panel > Printers and Faxes > right click on the Lexmark 5400 Series print object > Properties > Lexmark 5400 Series Properties window pops up, click on Ports tab > place a check mark in Enable bidirectional support by clicking in the box beside it. Hit Apply and click Ok to save the settings. Try to print. If problem persists, disconnect the printer usb cable from computer, uninstall the software completely by clicking on Windows logo Start menu > All Programs > Lexmark 5400 Series folder > Tools > Uninstall. Restart pc. To reinstalI, I recommend you use the software you can download from the Lexmark website. Just click on this link: http://bit.ly/cgn74X. Download and install the software. Follow the instructions. Try to print again. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 04, 2010 | Lexmark X5495 All-in-One &USB...
The printer acts like it is rinting but nothing
In that case, it looks like your print head is blocked. Try using the print head cleaning options in the printer menu.
If that doesn't work, try a new cartrige.
Mar 13, 2010 | Lexmark X5495 Printer
I can't get my printer to print. Every time i press print it tells me that its started printing then says printing complete and nothing comes out
i can't get my printer to print. e very time i press print it tells me that it's started printing then says printing complete and nothing comes out.
Feb 01, 2010 | Lexmark X5495 Printer
Lexmark X5495 printer will print hard copies but will not print from the computer.
check settings to the prtr
start,accesories,controlpanel,printers,rt clk on default printer and select properties an dfollow the prompts,,,
Dec 18, 2009 | Lexmark X5495 Printer
Lexmark X5495 - useless
I've had a problem like this before too, it's was down to two things which might be the same for you!
1) Is your printer plugged into a Power Surge Protector? if so then remove it from that and plug it into a normal plug, the surge protector sometimes doesn't allow the correct amount of power to reach the printer which causes an issue.
2) Your paper feed rollers, I had to clean mine with white spirt to remove the paper dust from the rollers, once done feeds paper everytime since!
If this has helped you then please rate me!
Aug 23, 2009 | Lexmark X5495 All-in-One &USB...
Printer won't print 17''x76'' long Banner on Canvas
What is the page setup in the Indesign Program?  Sounds like is is trying to print to the standard paper size of 8.5 X 11.  See if the program allows you to change the page set up to 12"X66" to match the banner.
Hope this helps...
~enov8
Feb 16, 2009 | Apple Computers & Internet
Lexmark X5470 All-In-One InkJet Printer Logo
200 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
