SOURCE: Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
SOURCE: whirpool washer LSN8244AQ0 motor spins but agitator does not move.
Ok this is a old school machine. Have a look at the drawing below. So no agitation or spin? How about the pump, does it drain? Now if it drains and thatis it then item 13 below is a coupler that is probably out. You can pull the machine out and tilt it back and using a flashlight examine for black dust and touch to see if it is soft in spots and the two white flanges are intact. You may have to remove the pump and motor to inspect.Use part 285753A .
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
I removed the front cover and the belt looks fine. The motor is inop. I can move it manually by turning the belt but it wont spin in the drain cycle. The pump is working and the lid switch it working.
