Dropped in river several months ago and when I turn it on the blue WB ligh is on but camera won't do anything else.
SOURCE: Canon EOS Rebel XS turns on, but nothing else works!
Take the lens off and the CF card out. Just with the battery in, see if the display works. If not, could be a faulty camera. If it does, switch off, insert the CF card, switch on. Do you see the display now? If not, CF may be faulty, replace it. If it does, switch off, add the lens, switch on. Does the display come on now? If so, looks like it is fixed, if not, looks like the lens is faulty - try removing the lens and cleaning the contacts on the lens and the camera body with a pencil eraser, do not let any debris fall into the camera body (hold it opening down is best).
SOURCE: Error 99 in Canon EOS Rebel XS 1000d
Have you been to the support section of Canon's website to find out what "error 99" means?
SOURCE: New Camera, no picture on screen
you can use live view, to preview the picture before its taken....
check the manual to turn on live view
then press the center ok button to turn on live view
this is for cannon 1000d....hope this works
SOURCE: Canon Rebel XS displays busy signal after I take a
Is your card nearly full? Is your battery fully charged?
SOURCE: Camer won't turn on.(Cannon EOS Digital Rebel XT)
A dead camera is impossible to tun diagnostic checks on without specialist tools, so yes, your camera will need to go to a Canon service centre for diagnosis and an estimate. If you decide not to go ahead with the work then you'll be charged for return shipping and a fee for the work carried out to make a diagnosis.
If the warranty expired fairly recently, then it may be worth contacting Canon before getting the estimate: it's not unknown for them to offer goodwill repairs for major faults which occur prematurely, but you need to be aware that your model was only designed with an approximate four year minimum lifespan.
