Question about Nokia 1600 Cellular Phone
The mobile says insert sim every now and then
The mobile says insert sim everytime it is switched on, and even sometimes when it is working properly; and it also says "temporary error:44" at the time. It starts working again when it is shaked vigorously.
  1. keypad problam
Posted on Jan 02, 2009
  • karpagavinay Jan 02, 2009
    key pad number 147* is not working
Sim not working
Did you mean your phone shown no sim card inserted even your sim card present on your phone?
Yes,Means,There are three possibilities to get this type of issue.
1.There may be a problem in your Sim card so try another one.
2.Check your Sim whether it's properly inserted or not
3.Your mobile is locked to particular network provider.
If your problem persists,After trying first two ways means definitely Your mobile phone is restricted by some network so try to unlock your mobile phone.For unlocking you can approach your service provider or else try to buy an unlocking service from any one of the online unlocking service provider like
Unlocking4U.com
Aug 11, 2014 | Nokia C2-01 3G Mobile Phone Bluetooth...
Not recognize sim
Did you mean your phone doesn't recognize your sim card even your sim card present on your phone?
Yes,Means,There are three possibilites to get this type of issue.
If your problem persists,After trying first two ways means definitely Your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit SuperUnlockCodes.com I hope it will be very useful to you.
Jul 03, 2014 | Cell Phones
Insert sim card
Try to keep the following two steps when you get this type of error.
1.Check whether it's your sim card is properly inserted or not
2.Your mobile is restricted by some network.So try to unlock it.
If it's network locked means try to unlock your HTC Salsa mobile phone using Unlocking4u.com Here you can unlocks your mobile at low cost.
Oct 03, 2013 | HTC Salsa Smartphone
SAMSUNG MOBILE MODEL: GT-E1200T SIM LOCK
my samsung GT-E1200T please sim unlock solution
Jul 12, 2013 | Samsung Cell Phones
Do you get this error message?As far as I know there are three chances to get this error..one is the sim may not have been inserted properly...try to insert it in the correct position.There may be an error with the sim try to insert other sim cards into the phone.Another chance to get this error is when you try to insert a sim other than the locked network.If your mobile is locked with a particular network then it will work with only that and will not be able to recognize/accept other networks.Inorder to unlock your phone you can either approach the network provider or third party unlocking vendor like Mobile-unlocker.com and remove the network lock.
Even after all this the problem persist it may be due to some hardware problem try to get in touch with the nearby mobile store.
Jun 25, 2013 | Cell Phones
What is 44'H ME Error
my mobile showing 44'H,ME error...if i place the reliance sim...and its working properly with voda phone sim..my phone model is sumsung SGH T219s...please wht could be the problem
May 07, 2012 | Cell Phones
How to switch from offline to online
Offline mode only appears if the mobile phone is not getting the signal from its service provider.
*make sure that the sim is properly connected*reseat the sim card from the mobile phone*check account status for signal and connection availability*power cycle mobile phone
1. turn off mobile phone2. remove phone battery3. remove memory card4. remove sim card5. wait for 2 minutes before plugging back anything6. after 2 minutes, plug back battery7. insert memory card properly8. insert sim card properly s well, make sure that the sim is not dirty as well9. turn on mobile phone10. check the signal bar, it should be with signal this time and not offline
*after power cycling, phone should be working properly now unless the sim card is really faulty. you check if its faulty by calling your mobile service provider*
Dec 10, 2011 | Nokia E75 Cell Phone
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
I've update my se k800i, after finishing the step of updated.i switch on the phone and appear "insert correct sim card".i've tried my the other one sim card.also cannot work.what should i...
1st, might your mobile is unlock via patch only,a temporary unlock,it means everytime you program or update your mobile,the patch will be lost & this will be lock again,which means its not a permanent unlock...
if you want it permanent,go to any mobile service center and tell them to unlock it permanently.
now if it is permanent,you can update your mobile all you want...
hope this solution helps...please rate me... thanks.
Jun 03, 2011 | Sony Ericsson K800i Cellular Phone
Nokia 1600 Cellular Phone Logo
170 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
