Question about Car Audio & Video
Code input proceedure for car cd/radio
Hi, i have the code, but require the proceedure of resetting it please. Clarion model pm-2308u-a
  • 1 more comment
  • basin Feb 25, 2009
    Hi i also need the code for this model. I was given a unit from a deceased estate and require the code.If you could help with the code would be much appreciated.Believe the unit is from a Mittsubishi Lancer.
    cheers
    Steve.
  • Anonymous Mar 21, 2014
    NEED CODE FOR 0074618 PM-2308U-A
    CLARION CAR RADIO PM-2308U-A TRIED TO ENTER CODE BUT WILL NOT ENTER ON SCREEN
HI if you contact clarion via email they will send you a print out on the procedeure.
Cheers
Steve
Posted on Mar 28, 2009
Turn the ignition to ON or ACC and power the unit.
Press the CLK button for 2 seconds until a 0 shows then press the seek >> button till you reach the first number you need to enter then briefly press the CLK again. Repeat this till all code is entered then press CLK again and it should now display the time instead of CODE. If it still says CODE you may have entered it incorrectly.
Good Luck
Posted on Feb 24, 2010
Code clarion pm 2308u
go on net to all the w's .radio codes and go from there.
Jan 20, 2014 | Car Audio & Video
Battery flat on car caused AM/FM CD Player to require a code to be entered. Second hand car so I do not have the code. Is there an override code? PM-2308U-A, P/N 4301-4227-1, Appreciated
if it is the factory radio then go to a dealer that services your make of vehicle. They should be able to find the code by looking up the serial number on the back of the radio
Feb 07, 2011 | Car Audio & Video
Clarion Radio code required
have you tried calling a dealership????
Mar 22, 2010 | Car Audio & Video
I need a stereo code Peugeot 206 Clarion cd/radio serial no: CL041010207605 Model: PU 2325A(B) I can source it via web site at £20, prob cheaper to replace the unit. Q: Can I get a cd to put in the...
A CD input is not the method used as the code is manually inputted into the radio using the push buttons on the front.(The method / instructions are below )
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
If you have this barcode serial number then
POST ANOTHER QUESTION
quoting it.
If you do not have this number then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Clarion PU2294 Code Entry Instructions
After switching on the set the display show ' CODE IN '
Enter the code using station preset keys 1 - 6
Upon last entry the set will operate.
Oct 10, 2009 | Clarion DB538RMP CD Player
Clarion radio code
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
T
If not then it will only be available from your Main Dealer or a Decoding
May 04, 2009 | Clarion DXZ545MP CD Player
Code for Clarion PM-2308U-A
my radio is 3316, if you pull the radio out it should say the code on it. hope that helps.
Apr 21, 2009 | Car Audio & Video
I need the unlocking code for a Clarion Radio
Apr 20, 2009 | Clarion CDC655Z CD Changer
Clarion car radio code requied please! PU-2294B
i was playing around with one of those code generators just the other day and after some messing around it turned out the code to enter was the last four digits of the number below the barcode; if there are 2 barcodes, use the bottom one
Feb 25, 2009 | Car Audio & Video
Car Audio & Video Logo
435 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
