Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
Garmin nuvi 200 cannot access tools/settings/map/map info
Cannot access the settings in map info to fix no detailed maps found that support routing
5 Suggested Answers
SOURCE: GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
MY GARMIN NUVI 200W NOT WRONG AND SAY NODETAILED MAPS FOUND THAT SUPPORT ROUTING. THE NUVI CANNT BE USED WITHOUT THEM
Posted on Sep 22, 2008
bestdarngood
  • 3037 Answers
SOURCE: No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
Posted on Feb 28, 2009
SOURCE: garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
Posted on Apr 02, 2009
OAKside
The downloaded map file (ex: "Garmin_RMU_CNNANT2010C.exe") contains all of North America, and you must select the correct subsection (ex: "Lower 49 States+PR") that you purchased, which is listed on your Garmin myMaps page (My.Garmin.com).
I am a GPS newbie as well and selected "all of North America" when installing my free nuvi 205 map update. A mistake that's too easy to make, esp. considering Garmin still has very little info about selecting the correct map subsection listed on their support site.
You do NOT need to re-download the huge map file, thankfully, but you must re-install (30+ min) to choose the correct map subsection.
"Bad on Garmin, IMHO for not making important details like that clear to us new owners." My thoughts exactly.
Posted on Apr 25, 2009
RPFinney
  • 385 Answers
SOURCE: Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
Posted on May 19, 2009
Updated Garmin Nuvi 200 with Garmin Express. Now the Garmin reads "No detailed maps found to support routing". I pressed on the screen until this mesage left the screen and returned to the regular start...
Time for an update. Go to Garmin.com and get it done. If you haven't done this for a while you might get a new OS too. The older models use a lot of the memory for the updates and might need to download a smaller range map.
Nov 02, 2013 | GPS
No detailed maps found that support routing the nuvi cannot be used without them
you maps are turned off. go into Tools then Settings. Look for the Map menu. Then Map Info. Make sure you have a check beside the map you want to use. If no map is listed then the next call is the Garmin.
Cheers
Jul 15, 2010 | Garmin nuvi 205W GPS Receiver
My garmin nuvi 200 it say no detailed maps
my garmin 200 nuvi say no detailed maps found that support routing
May 21, 2010 | Garmin nuvi 200 Car GPS Receiver
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Apr 22, 2009 | Garmin nuviĀ® 200 Car GPS Receiver
My garmin just worked yesturday and now reads no detailed maps found that support routing.
check to make sure you have a map set selected ?
settings -> Map --> map info - make sure there is a checkmark next to the map data set (info for a nuvi 350 but it might apply for you)
Mar 18, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi says, "no detailed maps found to support routing."
steps below:
(Tools).
Touch Map.
Touch Map Info.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
No detailed maps found that support routing.
- Jim
SHARCNET-USA
Jan 11, 2009 | Garmin nuvi 200 Car GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
You can download new maps..........free......................but..........
I had this problem last year with my garmin 200 and when I called they said that I was out of the 60 day time window for a free map upgrade but they would give it to me anyway. They gave me detailed instructions on how to download a new map free of charge but they didnt explain which selection replaced what I already had on mine.
As a result, I downloaded the wrong maps and have much less detail. Even though its the "2009" version, its less acurate than my old maps were. But its worth a shot, better than paying for them.
Oct 28, 2008 | Garmin nuvi 200W GPS Receiver
Updating maps
Press the power bar in the upper right c orner for 10 sec. and You will go into servicemood. Ther You can reset and run memorytests, Otherwise Use the lttle pihole under the tape on the bottom side
Aug 31, 2008 | Garmin nuvi 200W GPS Receiver
GPS Logo
188 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
