Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
The picture tube of the television was loosen
The first of the television screen was hit by a child's toy and mess up the picture (blue and pink lines are on the screen). Also the standby/timer light is blinking in the television is not on. The television has been repaired before.
  • 4 Answers
If this is an lcd tv, the toy has broken the LCD panel and would need to be replaced. The cost of the panel would exceed the value of the set. If you have homeowners insurance, you may want to contact them to see if it's covered. Sorry for the bad news.
Posted on Aug 05, 2010
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
The picture is is now in pink
If Sony KP-51ws510 it is an common issue with the picture tubes but there may be a simple way to adjust something in the set to correct this--these had problems with the 3 picture tubes where it can go to excessive red, green or blue.
Confirm model and issue and I will assist.
It only requires a screwdriver and the back does not have to be removed in this case.
Mar 20, 2012 | Sony KP-51WS510 51" Rear Projection...
I have blue arched lines and blue screen
HI:
Your problem is the blue CRT or picture has gone bad, you will need to have the picture replaced, there are three tubes in this model rear projection television. Red, Green, and Blue. Replaceing the blue tube is the only option for normal operation to resume. It may be hard to find the tube, but you can try contacting this website for the part www.vdc.com, they manufacture and usually have stocks of sony picture tubes and rebuilt ones as well. The company's name is Video Display Corporation...
Jul 14, 2010 | Sony KP-57WV600 57" Rear Projection...
Have Sony Model# KP-57HW40 Big screen rear projection tv..Has blue wavy lines across screen, and sometimes flashes blue, can you give me assistance??
Blue Picture Tube , bad Video IC on Blue CRT board.Or Blue screen drive control to tube needs to be adjusted down some.
Most Likely Bad Tube!
Jul 12, 2010 | Sony KP-57HW40 57" Rear Projection...
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Sony KP-53HS30 started with Pink and Blue picture and timer blink
You probably have one or more bad CRT's causing the problem. Due to the age of the set and cost of repair, I would not invest the money needed to repair the set properly. I would replace all three CRT's and the cost would run over 1000.00 up to 1300.00 .
With the cost of new sets today, you could replace it.
I hope this helps,
Skyassoc
Aug 05, 2009 | Sony KP-53HS30 53" Rear Projection...
My tv was dropped and now the color is messed up how can i fix it
Unfortunately, this can't be fixed without replacing the picture tube. The drop caused a piece called the shadow mask inside the tube to warp or break loose. When that happens, the red, green and blue beams in the tube don't hit the right places on the screen. There isn't any way to repair this kind of damage.
If you had professional movers doing the job, their insurance should cover some or all of the cost of repairing the TV (replacing the tube, that is) or replacing the set. I wish I could give you better news.
Nov 22, 2008 | JVC AV-32D305 32" TV
My screen have some red lines
I will assume from you description that this is a rear projection crt(picture tube) tv. if this is true I have good news/bad news.
faint red horizontal bowed lines in the picture indicate the screen(G2) voltage for the red tube is too high.Slight lowering of the G2 adjustment will eliminate these lines. I stress SLIGHT because too much adjustment will mess up the gray scale .
The bad news the red crt made be bad. if the adjustment works but in the future the problem reappears then suspect the red crt.red crt replacement is probably not economical to repair.
Jun 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Pink picture with wavy green and blue lines
start with convergence ic's probably stk 392-130 big black chip's on an alluminum heat sink. mark ALL connections with majic marker. check for bad solder connections. for god's sake be carefull
Oct 19, 2006 | Sony KP-53S65 53" Rear Projection...
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
140 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
