Question about Uniden Cordless Phone
Handpiece Volume Uniden XSA955
I have a Uniden XSA955. The handpiece volume seems to vary from high to low without pressing buttons. In both cases if I press the volume increase button to show volume status it shows high/maximum.
Any suggestions.
Jeff Kukura
3 Suggested Answers
  • 9 Answers
SOURCE: base seems ok but cannot get display on handpiece.
uniden will sometimes take 24 hours to charge to work....if the display never works, then it is the phone...take it back.
Posted on Jun 12, 2010
  • 225 Answers
SOURCE: my handpiece on base station
Hello.To help, I need the model number of the base unit and handset that is not displaying in English.
Posted on Feb 08, 2011
How do you remove a recorded program from my panasonic DMR-BWT760 recorder
On handpiece, select Direct Navigator, scroll to title to delete, select Option button on handpiece, scroll to Delete Title and press.
Dec 23, 2017 | Panasonic Televison & Video
How do i turn the handpiece volume up
Try * and # keys or check for adjusting keys on the side of the phone.Thanks!
Jan 03, 2012 | Cell Phones
I have Uniden DCX700 phone- how do I turn the ringer on and off?
The DCX700 is an expansion handset for several different Uniden phones (DCT746, DCT748). To change the volume of the ringer, press the Vol + or Vol - button with the unit in Standby (not making calls). There are three ringer volumes: Off, Low and High. Pressing the Volume buttons will let you cycle through the list. The volume buttons are to the left of Talk below the LCD screen.
You can temporarily mute the ringer by pressing Mute while the phone is ringing.
The manual for the DCT746 is here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DCT746Mom.pdf . All Uniden cordless phone manuals are available in numerical and alphabetical order here: http://www.uniden.com/scat/cordlessphones_mnl . The manual for the DCX700 handset (with registration information) is here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DCX700om.pdf .
I hope this helps.
Sep 21, 2011 | Uniden DCX700 2.4 GHz Cordless Phone
The volume on my Panasonic cordless handpiece is low model number KX-TC1060ALW
Possible that the earpiece speaker is bad and so must be checked and replaced. it is better to open and clean the earpiece and the check for sensitivity of the earpiece before you change. If not a problem in the board- AF section- could also cause similar issues.
Jul 05, 2011 | Panasonic Lands Phones
How do I turn ringer off on my cordless Uniden EX18560?
Press and hold the cid/menu button, press the down arrow button to move the selector to RING VOL, press select/channel button to cycle through the three ringer volume levels(HIGH, LOW, and OFF). As you cycle through the three choices the phone will sound the new volume level. When you get to the volume you want, press the end button to save the new setting. I have include a link where you can download the manual.
http://www.uniden.com/pdf/EXI8560om.pdf
Mar 12, 2011 | Lands Phones
Base seems ok but cannot get display on handpiece. LED shows that it is charging & has been for many hours.
Jun 12, 2010 | Uniden Cordless Phone
I want to turn off the answering service.
From the base, press the on/off button.
From a handpiece - open the menu and select "Ans.Setup", then "Ans. On/Off".
Mar 30, 2010 | Uniden DECT 6.0 Cordless Phone ID
I have a Uniden DECT 6.0. How do I delete the
This probably applies to your model:-
From the expansion handpiece - while the message is playing - hit the 4 button - or 4:delete button.
From the base unit - while the message is playing - hit "delete".
You can only delete all messages at once from the base unit.
Mar 29, 2010 | Uniden DECT 6.0 Cordless Telephone...
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Dec 30, 2009 | Uniden DXA15588-2 Twin Cordless Phone
Programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
Uniden Cordless Phone Logo
37 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
