Question about Onkyo TX-DS595 Receiver
No sound from speaker
I have no sound coming from left spk a or b swap spk round spk ok was working fine before not sure if i have changed something in the amp to make this happen
    Brigadier General:
  • 8,546 Answers
Isolate the wiring, too. It's a binary problem. Should be easy. Or try running your suspected speakers on other channels to eliminate amplifier bugs.
Posted on Apr 24, 2009
Ok, so I have had creative inspire T3030 2.1 speakers for more than a year now, but recently I noticed slight cracking and popping sound coming out of the left satellite speaker. I tried swapping them and...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 12, 2011 | Creative Labs Inspire T3030 Computer...
Samsung s 3310 speaker/ringer solution
...samsung s3310 but has no speaker problem pl solve this ear speaker fault plz help s3310 spk no working sam 3310 ear spk is ok but no sound ,i hope is head fone...
Feb 09, 2011 | Cell Phones
My samsung s3310 speaker doesnt work
i have samsung s3310 but has no speaker problem pl solve this
Sep 16, 2010 | Samsung Cell Phones
Technics Integrated amplifier su-v85a speaker volume fluxuates and speaker left shuts down some times what is the problem?
test you speaker maybe there is a bad connection some where is the spk. box its self ,try changing speakers left to right .
it the spk. are ok open amp see all the connections within the amp .
if this dose not work contact me by mail: starilaz@net.hr
Oct 12, 2009 | Technics SUV500 2-Channel Amplifier
No left channel sound
check wiring. if ok, swap speaker channels if ok, swap rca plugs, if ok. Bad channel on amp.
Jun 29, 2009 | Technics SA-DA10N 5.1 Channels Receiver
Satellite 5205-s505 speakers aren't working, headphones OK.
Start- Control panel- Sounds and Audio Devices- In the device volume section click Advanced- Click Advanced again and check if In the other controls section 1 PC Spk mute is checked if so uncheck it If that does not work please let me know so I can help you further
Dec 09, 2008 | Toshiba Satellite 5205-S503 Notebook
My Onkyo TX SV 535 Surround Sound wont work
Speaker relays have oxide on the contact points. Open up all the speaker, spk, relays and remove the oxide layer formed on the 12 contact points. Those 3 relays are on the spk terminal board. You can located it easily. It just mounted next to spk output, a horizontal board.
Aug 13, 2017 | Onkyo TX-SV535 Receiver
No Sound
carefully plug back the minijack for the speaker at the out or spk,
normally the sound card has three ports 1. for MIC 2. LINE IN 3.OUT (SPK) - SPEAKER.
carefully plug the minijack for the speaker into the third one - OUT (SPK) - SPEAKER.
in pluging it in, first put on a media clip on the windows media player and carefully plug in the minijack for the speaker and surely you will hear sound.
UZOWUANYA
e-mail: uzowuanya@yahoo.ca
Feb 11, 2008 | Dell Dimension 3000 PC Desktop
Speakers not working correctly
pls swap the spk pin in to your sound card jack socket . bye
Sep 22, 2007 | Logitech X-530 Computer Speakers
Onkyo TX-DS595 Receiver Logo
185 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
