Question about Maytag MSD2754G Side by Side Refrigerator
Water in Freezer bottom
I have a side by side maytag refrigerator hat is 3 years old and it is collecting water in the bottom of the freezer. The only thing I could find was to unclog the drain tube because it is frozen over. I did this about 6 times and I still get the frozen tube and water. It appears to be putting off to much water and it freezes over the tube and spills onto the freezer floor. Thanks, Ryan
  • 1 more comment
  • dhebert Jan 17, 2008
    Hello....
    I have the same problem, but have not been able to find how to access the drain tube.....
    Please help....I have tried to find a diagram as to how the drain system is installed, but nothing on line....
    My model no. is PSB2151GR
    Your help is appreciated
    dhebert@pacbell.net
  • grriceman Jun 17, 2008
    I have the same problem...how do you clear the drain line?
  • Anonymous Mar 31, 2014
    about every 3 to 4 weeks water pools in the bottom of the freezer because the drain hole is frozen closed
I did the Drano as well as baking powder/vinegar mixes with water. What finally got it free was taking a plastic step inflatable pump thing and pushing some air into it.
Posted on Mar 16, 2012
Drain line is blocked check bottom tray if is collecting water if not drain line blocked
Posted on May 13, 2007
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
My Maytag side by side refrigerator has water coming out of it. From time to time, you can see water on the floor which has come from both the bottom right and left side of the refrigerator. I...
We have the same issue on our Maytag Side by Side - MSD2734GE. Empty the freezer. At the back of the freezer are two panels in the back. It is only necessary to remove 3 screws. The first 2 screws hold on the very bottom panel. Remove the back panels and look at the drain located at the bottom. You will notice a thin piece of metal covering a drain hole. Remove the screw holding the metal in place. Then remove the ice build up around the drain hole.
Sep 01, 2010 | Maytag MSD2734GE Side by Side Refrigerator
Water on freezer bottom. I have a Maytag refrigerator, side by side, Model MZD2768GEW, seven years old. Recently I have found about 1/3 cup of frozen water on the freezer bottom. It is not comming from...
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | Maytag Freezers
Water collects at bottom/Ice forms in top
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
There is water collecting at the bottom of the Freezer. It is coming out of the vent area inside the Freezer near the bottom. Can you help identify?
Check the defrost drain at the bottom rear of the freezer. If the drain is clogged or frozen, the water has to go somewhere during defrost.
Nov 14, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water colecting on floor of freezer in fridge-freezer (Hoover floorstanding model 3 years old). I can not find a drain hole - water apears to be running down from cabinet behind bottom drawer.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Mar 24, 2009 | Maytag MSD2754G Side by Side Refrigerator
Maytag MSD2754G Side by Side Refrigerator Logo
706 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
