Touch screen is not responding to touch. Cannot get to my number pad to make calls
SOURCE: LG Secret touch screen, can not use left upper,
I have the same problem sometimes, when it happen I press the touch media key in the middle right side of the phone, and enter to the pictures aplication and exit touching the screen, this appear to recalibrate the touch pad most of the times.
SOURCE: LG CU920 VU Touch Screen Not Responding
I had the same issue and was pissed, not to mention i didn't have a warranty and it was only a couple months old. I actually bought another phone and because I had nothing to lose, took my phone apart and replaced the touchscreen myself for about $30. If you have ever changed out a PC part, you could replace this screen. It's not really that difficult and there are guides out there. The screen itself is just a thin piece of plastic that lays over the lcd screen and is kinda "glued" into the frame of the phone. If you look at ur phone and follow the frame around, that's the piece ur replacing - but you have to disconnect all the wires from the inside. Now mines works like a charm -- and I'm stuck with two phones :~( PS: STOP USING THE STYLUS!
SOURCE: how to make the LG KS360 fully touch screen
What is inrt file settings, and how do you acces them?
And where do you find your serial code and Pg number?
Pleas help!!!!! i really want this!
SOURCE: my LG phone's screen is black and wont let me see anything
there is nothing wrong with your screen, the problem is
from the flex that connects your screen to the phone's main board. This
flex must have worn out that's why your screen is not displaying any picture.
The
problem is common with flip and slide phones. The flex gets worn out as
a result of constant opening and close of the flip or slide phone.
I
would urge you to replace the flex and I am assuring you that your
screen will display picture again. You might also be lucky to find out that the
flex is not well fix, that is, it may have loosed contact.
If
you cannot change the flex yourself, maybe you should take the phone to
a local repairer within your vicinity, so that the flex can be
fixed/replaced.
Good luck.
This will reset all user-defined settings on the device.
