Question about Mitsubishi VS-45607 45" Rear Projection Television
Picture is really light in color screen is white
When we turn on our tv it is really light in color and sometimes you can slap the case and it will fix itself. sometimes if you turn it on it will be okay but after 10 mins. it will go light
    Sergeant:
  • 233 Answers
It sounds like you have bad solder joints in the tv. If you resolder the boards in the tv, it sounds like it will be fine. When you are slapping the tv, it is temproarly making contact again and fixing the picture..
Posted on Jan 15, 2009
Why does my KD-32FS170 32" Sony Trinitron screen have blue hues
If you turn all of the color out of the TV, the picture should be black and white. If that picture is not a true black and white picture, the TV will produce a color picture that has that behind it. It takes the proper mixture of red, green and blue light to produce white. This is something that is done inside the glass picture tube.
In your case, one color (blue is stronger) and the others are weaker.
It probably had not been used for a while. SOMETIMES, the weaker colors will get stronger with use. Adjust the brightness and picture controls to get the closest you can to a black and white picture, and then add the amount of color that seems right to you. Use the TV and hope for the best. It will improve, but 2%, 10%, or 50%; I do not know. The proper repair is to replace the glass picture tube, which is not an option at this time. So, turn it on, play games, and HOPE for the best.
Dec 04, 2014 | Sony Televison & Video
My sharp 52 inch started out messing up by a few times a week I would turn it on and the screen would be all white with a faint really light colored picture but mostly all bright white it did that for a...
There might be a problem with the flex wire connecting the screen to the Circuit Board or the screen itself is defective. Sometimes it is the docking of this connector which might became loose over time.
Nov 06, 2017 | Televison & Video
RCA rear projection tv picture bowed to middle. Red Green Blue colors have been seperated on screen.
If I had to guess I would say it's either the DLP chip or the prism. Simply put the lamp lights the DLP chip which directs the light into a prism and then onto the TV screen. The prism or prisms are responsible for aligning the colors correctly. The DLP chip is essentially a million little moving mirrors which direct light
If you're at all comfortable with electronics you might want to open the TV up to take a look. You might get lucky and find something obviously wrong with the TV. Sometimes adhesives melt and parts slip out of place. If your DLP chip is blown there isn't much you can do. You're probably right that this would cost a lot to fix and not be worth it.
Jul 24, 2012 | RCA Televison & Video
32" LCD tv w/built in DVD mounted on wall. screen will not hold picture - looks like vertical or horizontal hold needs adjusting, but cannot figure out how to adjust. happens when using DVD or VGA...
Vertical and horizontal adjust went out with black and white TV pretty much.I remember those days too...what would kids nowadays do???lol.Anyhow,the fact that it clears up sometimes when you slap it should mean that the screen is fine.Something on the circuit board may need repair.Unfortunately,I have searched for diagrams for TV's online many times and only authorized shops have the access required.I just checked westinghouse,not even a way to sign in if I were a reapir shop.So,needless to say, a shop will have to check it out.Sorry That's all I can suggest and good luck!
Aug 05, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
Jul 24, 2010 | Sharp 65DR650 65" Rear Projection...
Lamp light on front of tv stays on, it is amber in color
Hi,do you mean tv is showing an amber picture? If you do,it could be an issue with the color wheel or dmd board.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.This is how the DMD works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 02, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Hitachi S57500 projection tv turns itself off
Hi, I`m afraid it`s not good news, you have a bad green picture tube, video-tek
Feb 10, 2009 | Hitachi 57S500 57" Rear Projection...
No Color on my Audiovox AVT-1498
That model has a history of bad solder connections in various circuits. I would not be surprised if that is the case with the color circuitry. You may get the color to come and go by slapping the sides of the TV or lifting one corner about 1/2 inch and dropping it. If it does, it is a bad connection and possibly fixable. If no change is noted, it could be a bad semiconductor or capacitor, etc., causing the symptoms. For that size set, it would probably be cheaper to replace with a different brand. Toshiba has a nice 14" model IMO.
Feb 11, 2007 | Audiovox AVT1498 TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
