Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I bought A 65" Mits and had it two days approx. 2hrs. of run time
Turned on football and noticed the screen looked like it was trying to auto focus and next thing i heard a big pop sound then screen shut off and red light came on so i unplugged it for 5 minutes then tried it again there wasn't any sounds but the screen wouldn't turn back on i tried this unplugging and plugging back in several more times still no picture or sounds
  • 179 Answers
Check the lamp. it sounds like it failed. you will probably see the broken glass inside the lamp housing
Posted on Jan 02, 2009
Why are my photos out of focus??
Check your settings - try taking sots with the different focus settings and compare. If all photos show some identical signs, you need a fix on your camera. If, for one photo taken with the auto focus settings, look different, you need more practice with your camera.
Aug 20, 2014 | Canon EOS 60D Digital Camera
Mitsubishi WS-65611 Repair kit from TV-Repairkits.com no fix.....
I have a few ideas but they all will require some more information from you. I know these sets very well-if you fixed the convergence problem my hat is off to you--it can be a do it yourself job but not the most easy set to do it on.
Let me assume you adjusted the convergence in the customer mode--it does on any of the HD models have to be adjusted in the regular and then the HD modes.
The only other thing here that may be the problem is FOCUS. A simple way to determine this is to remove the back cover--turn the set on and call up the advanced convergence grid---then cover the lens for each tube one at a time--with red and blue lens covered are the lines in sharp focus or look blurry?
Repeat this with only red or blue not covered and see what you think--if one of the tubes is out of focus you will see it there--
There is also a TECH menu for adjusting the convergence-like the customer menu but it saves the adjustments into the set's memory--you will need to hit menu and a four digit code based on the actual model number of the set.
Check to see if focus is or is not your problem-easy to tell--green, red, blue lines will either be sharp or out of focus--if out ask and I will tell you the simple way to adjust that.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 22, 2009 | Mitsubishi WS-65611 65" Rear Projection...
My quantaray 18-200 o.s for canon makes a dmall
this is start up,this is not a problem just noticeable.
Oct 28, 2009 | Quantaray Cameras
White Spots Streaks on DLP Screen
If you bought the set new you might just want to contact the manufacturer - if they are decent, they might just try to help you out with your dilemma.
Apr 02, 2017 | Mitsubishi WD-65833 65" HDTV
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Mitsubishi Rear Projection 65" tv picture becomes blurred bouncing right to left and color is red & green. TV is 8 years old approx. Any suggestions. Have not had any problems prevoiusly. First it woudl...
Sounds like possible solder connections on the convergence ICs. If so, you will see the red, green, and blue not lining up on ever input and even the mits menu. If you can bump it to correct, its just a solder connection, but if its out all the time then the ICs need replaced. This is a difficult repair only recommended for skilled technicians (40 solder connections + possible re-alignment needed)
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Olympus FE-280 not working properly
the lens could be the problem.. probably need to send to repair before the warranty runs out
Aug 28, 2008 | Olympus FE-280 Digital Camera
Mitsubishi WS-65908 picture problem
since this happened after you moved i would look for loose connections on the convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
