Hard disc not being detected
When pc is started, only intel logo is displayed. no furthuer action. i can not even go into bios settings. sometimes it usually starts and after sometime it hangs where it is and manytimes it does not .i guess my samsung hard disc not being detected....plz help me out..
  • 51 Answers
This is not a problem of your hard disc. Just remove your RAM, clean its connection with a dry cloth and refit it. And dont forget to rate my solution !!!
Posted on Jan 02, 2009
Error Message PXE-MOF: Exiting Intel PXE ROM. what does this mean?
That means your hard disk is not being detected. PXE is a network boot, which is typically used in business environments. Check your BIOS settings and ensure your hard disk is being detected. If it is, make sure your boot order is set correctly. Network boot (PXE) should be set to the last item in the sequence. If the hard disk is properly being detected and an OS is present, you should never see PXE.
If your hard disk is not showing up, power your PC down (unplug the power) and check the cables to make sure they are seated.
Mar 17, 2013 | Acer TravelMate 5730-6204 Notebook
No Bootable Device
Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 25, 2012 | Acer Aspire One PC Notebook
My system is turn off and turn on no loading os and bios is not working motherboard is intel d102ggc2
Have you tried pressing F2 when you powered on the PC?
Ensure that the monitor displays the signal of PC and there is no issue with video signal. If there any issue, check with RAM.
1.If no, just press it to view the bios setting. Go to the third option below.
2.If yes and no display of bios, may be your BIOS ROM chip failed. Before that take the C-mos battery out and try again. Almost try to replace it or you must go for a new motherboard.
3.If yes and getting into bios, check for the hard disk detection. If it is detected, try again for booting. If it is detected and not booting, try to format. If it is not detected, try changing it into another SATA / IDE port. Still it is not detected, replace the hard disk.
Aug 19, 2011 | Intel D102GGC2 Motherboard
How do u fix a laptop when it is not finding the harddrive
It looks like you have a hard drive issue try on boot up pressing F2 into BIOS it should recognize it there if it doesn't I'm afraid you will have to take it to a trusted repair shop, sound like your hard drive is possibly defect
When you turn on your computer, the BIOS does several things. This is its usual sequence:
  1. Check the CMOS Setup for custom settings
  2. Load the interrupt handlers and device drivers
  3. Initialize registers and power management
  4. Perform the power-on self-test (POST)
  5. Display system settings
  6. Determine which devices are boot able
  8. Is this the screen that your are getting on start up
  9. Look at the following example of a BIOS sreen after pressing F2
  11. Hope this helps you further diagnose your problem
Mar 02, 2011 | IBM Computers & Internet
I have a dv2000. It turns on, but see no bios screen.
TRY TO GO THE BIOS SETTING THEN LOAD DEFUALT.. IF THE LOGO SCREEN NOT SHOW SOME PROBLEM FOR THE DISPLAY THE DEFAULT SETTING IS THE LOGO SCREEN WILL SHOW ON START UP THE SCREEN..
CHECK THE DISPLAY,,,, INVERTER, OR VGA CABLE,, VIDEO CARD..
Jun 25, 2009 | HP Pavilion dv6000z Notebook
I have a gateway laptop model MA7and it wont start up.
It is not a hard drive issue. If hard drive is a problem system wont boot till motherboard processor. Try to reinstall your OS. It will fix your issue.
May 14, 2009 | Gateway (M520HD80G) Hard Drive
My computer stopped suddenly and did not detect hard disk
restart your cmos by removing the battery on your motherboard and if that doesn't work update your bios.
Dec 20, 2008 | Intel D845GVSR Motherboard
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
Computers & Internet Logo
310 people viewed this question
David Payne
David Payne
