Question about Teac SL-D80 "Nostalgia" Music System Shelf System
Jvc-rs11 have old school stereo--sounds soooo good. can i hook my cd player to it?? only has tape1 and tape2 and phono inputs.
Im trying to hook my denon stereo to my tv... can you help me??
What inputs does the TV have?
Otherwise experiment with these options:
DENON---------->>-------TV
Stereo jackplug phones out->>-RCA phono inputs.
RCA phono outputs->>-RCA phono inputs.
Stereo jackplug->>-AV.RF converter RCA phono inputs->>-ANT.in.
RCA phono outputs->>-AV.RF converter RCA phono inputs->>-ANT.in.
Nov 29, 2017 | Denon Audio Players & Recorders
I have an old Kenwood that has CD, Phono and 2 vidio hook-ups. I suspect the "video" means a VHS tape player, will my DVD player work.on this unit.
You could have named the model to make this easier.
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify and frequency-correct the tiny current produced by a Phono cartridge. Look up RIAA equalization.
All other analog stereo IN's and Outs are Line Level and GENERIC, meaning anything BUT PHONO, regardless of what the silk-screened labels say. So, yes, your DVD player's analog audio should work.
Sep 02, 2011 | Kenwood Audio Players & Recorders
I connected a JVC component turntable to the CD input then tried the Aux input on a Yamaha RXV663 HD tuner and the audio volume in this 7.1 system was almost non existent. There was barely any base coming...
Yeah, phono a preamp.
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
Jul 25, 2011 | Audio Players & Recorders
How do i connect my pioneer reciever to my dvd player?
Hi, Not to worry there are just two ways to listen to a dvd player with any sound system. The first and simplest is to use the " AUDIO OUT " from the rear panel of the dvd player these should be marked red and white as well as labeled L/R. Use readily available R.C.A. cables to connect to the rear panel of the Pioneer. You will see such labeling as " PHONO, AUX,TAPE1,TAPE2,DVD,LD,MD" and so forth. Using any of these EXCEPT " PHONO " will get you sound. PHONO input is too different to use. Just make sure you have the same "SOURCE " selected from the front of the receiver when it is turned on. Example if you have dvd player plugged into the " TAPE1" be sure that is selected as the source etc... That should get you to where you want to be. Thanks for choosing FixYa,I hope we have been of assistance,Good luck-Prodzilla
Apr 15, 2011 | Pioneer Audio Players & Recorders
Connected new polks to cambridge audio amp a1 (about 30 watts per channel) and play cds through a panasonic dvd/cd player, but i can't turn up volume past 1 without it sounding too loud. sound is ok, but...
Plug the player in somewhere else besides the PHONO input.
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it because old-school turntables require it to preamplify the tiny current produced by a Phono cartridge.
I imagine if you REALLY listened hard to the result you have you would find the bass is WAY too.
Google 'RIAA curve' to understand why.
http://www.graniteaudio.com/phono/page5.html
Mar 28, 2011 | Audio Players & Recorders
I hooked up the ion LP Dock to an analogue amplifier (which is hooked up to my LCD tv and outputs the sound through some bookshelf speakers) via the Phono input connections as per the instruction manual...
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
BUT, modern turntables like your come with their own preamplifiers, so they MUST be connected to a garden variety Line Level input like AUX (anything BUT Phono or it will overload).
http://www.needledoctor.com/Ion-LP-Dock-Turntable?sc=7&category=16189
"LP DOCK also has a line-level output for connecting to any home stereo with an AUX input"
As far as WHY your amplifier isn't making da music, that could be whole 'nother problem.
We'd need more details about it and the speakers to go there.
Feb 27, 2011 | Universal Electronics Ion LPDOCK USB...
How do i assign a record player to ''aux ''input terminals of a denon avr 1507 amplifier
Depends on the record player (turntable). If it's old-school it will need a PHONO preamplifier to raise the level and frequency-balance the output according to the RIAA curve. Otherwise it will be uselessly low in volume and tinny sounding.
Phono preamps are available at a lot of electronics stores online. Google it. If you have an old school receiver with a PHONO function you could use IT for the TT and send its output to the Denon.
If it's a newer TT it may have its own internal (selectable) preamp. Then it would drive any standard Line Level audio input.
Apr 26, 2010 | Audio Players & Recorders
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
JVC 5-Disc Player XL-F115
You won't get any sound unless you connect your CD player to an appropriate input on your amplifier (any but phono or tape/md) and connect your speakers to this amp.
Shout if you need more help.
Dec 30, 2007 | Audio Players & Recorders
Teac SL-D80 "Nostalgia" Music System Shelf System Logo
467 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
