Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
How do I access the ink cartridge to change it?
I can't change the printer cartridge. The drawings are confusing. I can open the front but can not locate the cartridge to change it. Where
  • Anonymous Jan 31, 2009
    I can't seem to get the 21 and 22 replacement cartridges in my F380 Printer
Open the front of the printer, cartritge should locate on its own to a position directly in front of you,printer must be switched on.When carriage stops plase your finger on top of the cartridge and press down,firmly,and pull towards you.it is easy!
Good Luck.
Posted on Jan 07, 2009
HP 6700 printer change ink cartridge
http://images10.newegg.com/User-Manual/User_Manual_28-415-214.pdf
Open ink access door.
1. Make sure the printer is turned on. Never turn off the printer when ink cartridges are missing.
2. Open the ink cartridge access door. [This is the panel that is to the left of the touchscreen. To open, put your fingers on the upper left hand side of the panel (by the logo: HP OfficeJet 6700 Premium), You should be able to gently pull the panel so that it opens out.]
NOTE: Wait until the print carriage stops moving before proceeding.
3. Press the front of the ink cartridge to release it, and then remove it from the slot.
4. Remove the new ink cartridge from its packaging.
5. Using the color-coded letters for help, slide the ink cartridge into the empty slot until it is securely installed in the slot.
Replace the
Aug 18, 2012 | HP Officejet 6700 Premium E-All-In-One
How to replace ink
Hi Good day!!!
to change your ink cartridges follow this steps
1. Switch on your printer by pressing the power button.
2. Open the cartridge access door and wait for the cartridge carrier to move to the middle.
3. Press the tab in front of the empty ink cartridge and remove it from the slot.
4. Remove the plastic wrapping from the replacement ink cartridge and take off the orange tab. To do this, carefully twist the tab and snap it off.
5. Place the new cartridge into the slot you removed the old cartridge from; then push it down until it clicks into place. The label must be on top of the cartridge, and the plastic tab should be at the back.
6. Close the cartridge access door, and your ink cartridge will be ready for use.
Don't forget to vote thanks!!!
Nov 02, 2010 | HP Officejet 4355 All-In-One InkJet...
How to change the ink cartridge in a Canon iP1900 printer please
1•Protect your desk, printer stand or work surface by placing an old newspaper in front of or next to the printer. The newspaper will provide you with a place to work without getting ink anywhere you don't want it. It seems as though no matter how careful or neat you are, a little bit of ink always manages to escape when replacing an ink cartridge.
•2
Prepare the new ink cartridge for installation. Remove the replacement cartridge for your Canon printer from all of its packaging. You may need scissors to remove the heavy wrapper. Leave the protective orange cap or tape in place for now. Set the new cartridge aside on the newspaper.
•3
Remove the old ink cartridge from the Canon printer. With the printer on, open the front door or panel of the printer. Wait a second or two and the ink cartridge holder should move to the opening where it is accessible. If it does not move, shut the door, turn the printer off for a moment, turn it back on and try again. Lift the small lever that secures the ink cartridges within their holder. On most Canon printers, it is colored green and located on the right side of the ink cartridge holder. Gently lift the old ink cartridge out of the printer.
•4
Place the new ink cartridge in the printer. Remove the plastic cap or tape protecting the ink cartridge, being careful not to touch the black and gold "sensor" area of the cartridge. Gently but firmly push the new cartridge into the empty slot left where you removed the old ink cartridge. The label should be facing outward. You should feel the cartridge pop into place. Then push the lever back down that you lifted in Step 3. Close the printer door. Use paper towel or wet wipes to clean any ink from your hands.
Aug 18, 2010 | Canon Office Equipment & Supplies
Printer stopped printing; amber teardrop is flashing; no paper jam; cartridges should not be empty. Shouldn't there be a notice of low ink before it just stops printing? Or, the printed pages be faint? All...
The top access door on the printer might be open, or there might be something wrong with the print cartridge.
  1. Check to make sure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door opens, the print carriage moves so the yellow arrow on top of the print carriage points to a drawing of a cartridge inside the cover. Each drawing describes a symptom.
Jan 09, 2010 | HP DeskJet 5550 InkJet Printer
Blinking orange light on hp 932c
Solution
  1. Check to ensure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
Solution two:
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
Solution three:
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Turn the printer off, then on again.
4. Replace the ink cartridges.
5. Close the top access door.
Solution Four:
Issue
The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
2. Insert the module into the back of the printer.
3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
Jun 17, 2009 | HP DeskJet 932c InkJet Printer
How do I change the ink cartridge in my HP photo smart C3150/ I opened the front cover and there is ink everywhere
You open the front door and the cartridges will move to the right. Then lift up and pull out the cartridge(s) one at a time. To install reverse the process. Also if you look on the inside of the door, you'll see a little drawing showing you how to change cartridges.
Nov 30, 2008 | HP Office Equipment & Supplies
I have forgotten how to change ink cartridge
There is a door on the front of the printer on the right corner. There is a little tab thingy on the side of the printer that you use to pull the door open. This you can do from the front, you don't need to move the printer around to get access from the side.
Pull the door down and tada, there are the ink cartridges. What a pain in the ****, took me a good 1/2 hour to find the information on the internet.
Hope this helps everyone.
Tracey
Nov 27, 2008 | Office Equipment & Supplies
How do I access the ink jets?
You must open up the printer. The lift point is in the front between the paper output and glass scanning surface. You should see and indent there . When you lift it up (it does weigh a slight bit), the printer heads should move to the access position. There is a lever on top of each cartridge to unlock it front the carrage.
Oct 06, 2008 | HP PSC 750xi All-In-One InkJet Printer
Opening cartridge area
Just in front of the machine on your right...open the grey panel or follow the instruction manuel on www.brother.ca
Aug 18, 2008 | Brother MFC 240C All-In-One InkJet Printer
No power ON
Here is what HP suggests: Issue The top access door on the printer may be open, or there may be something wrong with the print cartridge. Solution 1. Check to ensure that the top access door is firmly closed. 2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom. Here is a link to describe the pictures at the top of your printer: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=e&product=304442&rule=36405&docname=bpd09173 It might be that the cover's tab is broken (the tab is what tells the printer that the cover is closed)
Mar 26, 2007 | HP DeskJet 5652 InkJet Printer
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
