Question about Compaq Armada 110 Notebook
Need to clean the keyboard of Compaq Armada 110
I've never cleaned a laptop keyboard before. This is not a new one...it's not a new laptop, but it's the only one I can afford and the fan is going on alot as it warms up on the upper left part of the keyboard. Also it has slowed down alot. I can't seem to find a free manual online that I can look at and just print the pages I need to know how to successfully open this laptop and clean out the keyboard. What would be the best tool or sol'n to clean it with? and do I just use a screw driver on the lower back swivel or closing part of the screen, remove the screen and then separate the top framing around the keyboard by lifting it up? Also, I was looking at the only free online service manual for the Compaq Armada 110, but it kept asking for me to load a removeable drive (memory stick) with a disk. There was no way of being able to look at the service manual online and choose the page(s) that I need to print out. Also, I was looking online to add memory as this only has 10kb I think. The site had the info. of what could be placed in the laptop to add memory and how much it costs, but it only showed the new presario memories to order and place in my cart. This was a U.S. company that costs 1/3 the price of the memory for shipping. Is there any site in Canada that you know of? I figure the computer has slowed down due to a very dirty keyboard, etc. or not enough memory. Although that doesn't make alot of sense to me as I've transferred any pictures or letters etc. onto a memory stick, removing junk from the trash can and the cookies from history that I don't need. Sorry so wordy I don't know how to say this stuff in short form. Is there any advice or info you can help me with? Thank-you in advance, Gnome
Getting the keyboard out of an Armada 110 is fairly easy. First, you will need to carefully unclip and remove the plastic panel right above above the keyboard (the one with the speaker holes, switches and lights) This is easier to do if you lay the LCD panel right back as far as it will go. Then simply use a very small flat blade screwdiver, place it between the top row of keys and the panel then gently unclip it - much easier to do than it sounds - really. Once the panel is off, you will see two black philips head screws. Each is about 4cm in from either end of where the panel was. These hold the keyboard. Simply remove them and the keyboard can be removed. NOTE: don't be too over enthusiasic about just yanking the keyboard out otherwise you could break the flexable connector - gently does it. If you are just going to clean the keyboard, I would suggest you leave it connected as you can still lay it face down over the mouse pad out of the way while connected. While you have the keyboard out, and if you're game, I would suggest removing the panel (which also contains the CPU heatsink) below the keyboard and blowing the dust out of this area too particularly around the fan. The fan on the 110 is prone to injesting hair which seems to get tangled around the fan and will eventually stop it turning so if you see any, try to pluck them out with a pair of tweezers. Once you are happy that everything is sweet you can put it back together. (Note: I would also remove the old heat transfer compound from the top of the CPU and heatsink and replace it with some new stuff while you have access- just in case). You will note the the keyboard has 5 prongs on the connector side, these need to be slid into the slots in the case correctly otherwise things won't go back together properly. Then replace the screws and the plastic panel.
Hope this helps
Posted on Jan 07, 2009
    Problem Solver:
  • 7 Answers
Ok there should be 3 little black sliders near the top of where the keyboard ends. they should push down once you push all three down the keyboard lifts up. i hope this helps? other than that.. an air compressor?
Posted on Jan 02, 2009
My soft hyphen button isnt working
thats maaybe a technicly problem maaybe the keybord has a problem need a technicly preparation
Dec 12, 2012 | Compaq Armada 110 Notebook
Compaq armada 110 user manual
Hi Misa,
Here's the user guide in pdf.If you're using Windows XP here's the user guide,and for Windows 7 here it is.
Hope this helps.Thanks!
Please rate this answer.
Dec 11, 2011 | Compaq Armada 110 Notebook
Compaq Armada 110 works only, when AC adapter (PSU) is connected. I changed a new battery (refurbished) and now fully charged, but when unplug AC cable power will be lost. It was same behaviour with the...
OK, check the connection IN the laptop make sure they are actually making contact and are actually working. Now IF that is all in order, then I suspect, that your Battery Charger/Internal Power Supply, has faulted, the External and Internal supplies are separate, with exception for tap off to battery charger.
I have had this many times in my shop, you can most likely buy the Power supply sub board assembly and replace it.
Below is a service manual that will show you what to do and the part numbers. Most likely Ebay will be your best bet, or go straight to Compaq or Compaq dealer for the spare parts, or use the 'net.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+110
If you don't wish to DIY, then please get a "Quote" from a Compaq repair Centre
Oct 15, 2010 | Compaq Armada 110 Notebook
Compaq armada 110 battery not charging at all laptop works on power supply perfectly but when cable removed no charge in battery, new battery purchased same problem how can i resolve please
I'm sorry to here this but in this case you must bring the laptop in the manufacturers service center because they have to replace batt terminals for it to charge them again. It happened to my cousins laptop.
Apr 06, 2010 | Compaq Armada 110 Notebook
When i write jimmy for example it incorrectly
Hi there, At a guess I would say that the "Num Lock" is on, To enable/disable the keypad, press "Fn"+"num lk". cheers
Apr 02, 2010 | Compaq Armada 110 Notebook
Memory
you should first download this manual. i believe you need to remove the keyboard....which is fairly simple if you have a small screwdriver.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+E500+and+Armada+V300
Jan 22, 2008 | Compaq Armada E500 Notebook
Laptop cpmputer keyboard
They needs to be replaced or clean! at authorised service station!
Dec 08, 2007 | Compaq Armada M700 Notebook
Compaq armada 4131T
hi,i presume that u cannot punch in the password as the keyboard is not working, except the Enter key, u can do two things, reset the bios, or repair the keyboard, by removing it and cleaning the contacts, to reset the BIOS, locate the small lethium battery, remove it and keep it outside for some time, then put it back,that will reset the BIOS.. try either of it.. let me know...
Dec 04, 2007 | Compaq Armada 4131T Notebook
Compaq Armada 110 Notebook Logo
959 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
