Question about Yamaha HTR-5560 Receiver
Receiver makes clicking sound when I push power, but does not turn on.
My receiver has been having problems for the last few days. I first noticed when I was listening to the radio and out of the blue, the receiver shut itself off. Then, a few days later when I tried to turn it on it turned itself immediately off. Over and over I pressed the button until finally it received power and came on. Last night when I tried to turn it on it made a clicking sound but their is nothing on the screen that comes up and it does not have any sound. The warranty is expired and I took it apart, but I can't tell what is wrong with it.
  • 4 more comments
  • themush Nov 09, 2007
  • Anonymous Nov 25, 2007
    Receiver does not power - just relay clicks every time I press Power button.
  • Anonymous Dec 18, 2007
    Please describe the specifics of your problem below. We'll add
    your post as a comment to techsavy's Receiver makes clicking sound when
    I push power, but does not turn on. problem, and notify you when a new
    solution is offered.
  • tulipf Dec 21, 2008
    I am having the same problem. Did you figure out what was wrong with the receiver? I am having Panasonic XR-25 6.1 channel receiver.
  • Anonymous May 05, 2009
    I have a Harmon Kardon receiver that clicks repeatedly when I press the power switch on. It would do this for several seconds then the receiver would eventually turn on and I would get the amber power light to go green. Every thing seemed to work with the exception that my right rear speaker channels would cut out for days at a time then for no apparent reason I'd get them back. Now the power button does not work. I get nothing but clicking indefinately. I opened up the back of the unit and found a small black relay (I think) that is making the noise. Suspect that the relay is protecting the unit from some other problem but don't know what it is. Any ideas?
  • Anonymous May 24, 2009
    Receiver makes a clicking noise when attempting to power the unit on.
techman
  • 3130 Answers
SOURCE: Double clicking sound- no power
The relay contacts are most likely bad in the relay and will most likely happen again. If you know how to solder, take out the relay and look up the numbers on the internet and see what you can find. If not, try to find where the manufactuer is located and call them to see where you can get a new relay. Good Luck
Posted on Mar 28, 2007
  • 7 Answers
SOURCE: Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Posted on Jun 05, 2007
SOURCE: yamaha av receiver rx-359
go to best buy and buy a new recever
Posted on Apr 10, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX V2400 keeps shutting off
When it shuts off, does it display anything on the front like "ck speakers" you could have a shorted wire or bad speaker. Sounds more likely than a bad receiver. Yamaha is pretty bulletproof in "self preservation" circuitry! about the only thing that takes them out is lightning and major power surges. I have been selling and installing Yamaha receivers since 1995 and have only ever seen one with a problem that was unrelated to power. and I've done hundreds. If your not using HDMI, and the Video portion of the receiver, I would definately keep the unit $ 1500.00 is no cheap receiver. Try disconnecting the speakers, then turn on the unit with a source connected like cable/sat/fios on then crank the vol and let it set, if it cuts out, yes you've got a problem internally, however, I would stronly suggest metering all of the speakers and wires for shorts. There is an internal fuse as well right near the power cord, you have to pop the top to get to it, If you have a multimeter check the fuse with resistance tone. If you get tone, you have a good fuse if not If you need to replace it. They can be found at Radio Shack etc. If the fuse is OK, chances are you've got bad transistor(s) and needs to go to service. Repair should be under 200, well worth it. If you have further questions, post a comment and I will get back to you ASAP. Hope this helps
Posted on Jun 06, 2009
SOURCE: YAMAHA HTR 5560 KEEPS TURNING OFF
Since this is only happening when running DVD I would troubleshout surround sound speakers/ subwoofer or whatever speaker you are using when watching DVD and is not in use when watching TV:
1.) Make sure the speaker wire is not shorted at speakers as well as at receiver. Depending on method used to connect the receiver and speakers you may have short circuit even when you think you connected receiver and speakers properly.
2.) Make sure the polarity of the speaker wire matches the receiver.
Posted on Aug 08, 2009
Hello: I would like to know if you could tell me if there is a way to get this receiver to work again. As it does not turn on when powering it up.
It sounds like the power supply has gone out on it, I am having no luck in finding a replacement part for you though, sorry.
May 12, 2016 | Yamaha RX-SL100 Receiver
How to I tell if my receiver is dead?
It sounds like it is dead, check the manual.
Be sure you have mains power to the receiver, it sounds like that failed. A loose plug or blown fuse could cause that type of problem as well. Here are a few links that may help.
Redirect Notice
Redirect Notice
Yamaha RX V373BL Owner Manual
Mar 02, 2015 | Yamaha RX-V373 5.1 Channel AV Receiver
Audio Receiver only makes one "Clicking" sound when I push the power button
Definitely sounds like a relay... How old is your unit? Sometimes they get stuck and need a good cleaning with DeOxit. Good luck!
Aug 21, 2017 | Yamaha HTR-5940 Receiver
When i push power button clicks on immediately
I had this problem also and discovered an easy way to trick it into powering on: Click the power button, then within 1 second of the receiver powering off, click the power button again. The receiver should stay on this time. This works with both the button on the receiver and the remote control.
I would like to know what causes this problem and whether or not I should be concerned about damage being done. I assume this is a power protection. I haven't tried plugging this receiver into a different power socket to test, but I don't think the power plug is the problem. Note: I have the subwoofer plugged into the power plug on the back of the receiver.
Feb 23, 2010 | Onkyo HTR500 Receiver
The receiver turns on riefly and then makes a
The clicking noise is the protection circuit., sounds like you have a grounded speaker wire, but you say the speakers are not connected so the amp may be toast. Is there any smell of burnt wires? This is ussuallt noticable near the circuit board if something failed!
Jul 07, 2009 | KLH Audio Players & Recorders
Will not start up, no response after three attempts.
HI, theses popping sounds were capacitors exploding among other components as well. this is usually caused by a malfunctioning power board that has allowing way to much current in. the main has been fried in this case.
remove the cover and look for a fuse by the power cord solder(connection) point. if there is no fuse in the section, this will confirm major burn out.
Replace the entire main and power Assembly in this case.
May 22, 2009 | Yamaha RX-V663 Receiver
Sounds like a fualty push button - try connecting/soldering on a new one of a different type!
Jul 04, 2008 | Audio Players & Recorders
Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Thanks,
Larry
Jan 20, 2008 | Sony STR-DE845 Receiver
Sudden failure to power up
I've had this happen a number of times with my receiver. This trick from the Troubleshooting guide in the owner's manual usually does the trick: To reset If an unusual condition in the display window or malfunction occurs, reset the unit as follows. 1 Press the POWER button to turn off the power. 2 Press the POWER button while pressing the ENTER button. Everything stored in memory after purchase is canceled. If the power cannot be turned off in step 1 because of a malfunction, reset by disconnecting the AC cord and carry out step 2.
Aug 01, 2006 | Aiwa AV-D77 Receiver
Yamaha HTR-5560 Receiver Logo
1,100 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
