Question about Sony DVP-NS575P DVD Player
Sony Ns575p wont eject DVD
Won't open/eject the DVD it starts to play, I tried it on the control and the dvd system itself, also tried turning off the DVD player and unpluging it still not ejecting dvd?
    Top Expert:
  • Sony Master
  • 14,553 Answers
Someone is going to have to open the unit to look to see if mechanism is jammed or out of alignment or if the disc is not in the proper position---either mechanism or a jam is most common here.
Posted on Oct 22, 2012
SOURCE:
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
SOURCE: DVP-NS305 DVD Player
Your system is in child lock mode. I had this exact problem this week. You need to put the system into standby mode and then press return, then enter then on/off and it will be unlocked.
Posted on Sep 04, 2007
SOURCE: sony dvd player cant eject disk
Actually if all you want is the dvd, there is a plastic cover on the underside of the dvd player below the dvd tray. Open it from the tab like a door and inside the slot you'll see a little black lever that you have to move with a small screwdriver or something like that....then slide the lever over towards the power button. If you don't feel comfortable doing this next step please bring it to some one that is familiar withit or a repair shop !!!!!!!!PLEASE UNPLUG BEFORE MOVING ON!!!!!!!!! Now if ya wanna fix the "LOCKED" error and unplugging it doesn't help, you have to take the top case of the dvd player (six screws and slide it back.....the case might get caught on the plug on the back so slightly lift it above it. Then once you have the cover off, with the front of the dvd player facing you...unplug the connector that is on the left hand side of the dvd tray that connects to the circuit board with firm and straight up pressure.....pull (it is ok to pull from the wires, just grab in the middle). Now you might have to plug in the power for the dvd player with that connector unplugged but do so with caution!!!!!......if ya want just put the cover back on without the screws on and just press power a couple of times.....then remove the power cord from the wall, take your case off, reattach the connector.......you'll here it kinda snap back in, make sure you put the connect back on the same way, it really only goes in one way, the prongs are more to one side. then slide your cover back on making sure you lift the back of the cover over the power cord on the back and the put your screws back in and your done.......this should solve both your problems. I think my kid was messing around with mine too!!
Posted on Oct 27, 2008
  • 254 Answers
SOURCE: DVD stuck in sony blueray player bdp s300
Step1There are a few ways to get your dvd/cd drive release itself. The first thing you should try is shut your equipment completely off for a couple of minutes allowing it to cool down. Once you turn it back on try to press the release button on your equipment. Step2If that does not work try to use a very thin flat tip screwdriver. Insert in on one of the sides of the dvd/cd drive and try to pull it out softly while pressing the eject button simultaneously. Do not force it out but give enough pressure while pressing the eject button. Step3More than likely inserting a screwdrive should release the dvd/cd drive. You can also try a butterknife as well just don't use to much force. Something else to check for is to make sure the power is acutally on for the device. If you are trying to open a drive that is not even on it will never open up for you.
Posted on Apr 03, 2009
SOURCE: Sony SLV-D360P player DVD won't eject, says "Lock"
Hold down the
Posted on Aug 27, 2009
Refuses to eject says locked
You have the child lock turned on. See page 28 of this manual.
Apr 22, 2013 | Sony DVP-NS575P DVD Player
Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
Sep 26, 2011 | Bose 3 2 1 GS Series II DVD Home...
I have a Sony DVP-NS57P DVD player, The disc doesn't spin unless I give it a light touch; then it spins, reads and plays fine. If I stop it, eject it and reload it, the same thing happens again and I...
Problem seems with spindle motor that needs little bit lubrication of WD40 contact cleaner spray.
Let me know if you are willing to take apart dvd player and have WD40 spray.
Thanks.
Jul 29, 2011 | Sony DVP-NS575P DVD Player
Our new sony dvd player only plays dvd's in black and white. can't find ntsc button on the remote. need help
almost dvds are recorded in Ntsc & please chang your tv color system so you can see the color because through menu you can olny chang the color system for vcd from your dvd player
Apr 17, 2010 | Sony DVP-NS575P DVD Player
Sony DVP NS575P will not play pc burnt DVD
John~ check formats with dvd player can be found in mannual - then burn dvd to suit mp3 or mp4 would normally work~ you can go to Realplayer.com to get tool to download on pc to this job. also try
Divx .com / utorret.com
or if you can get a Silvercrest dvd player this can also play pc dvd.in may different formats.
Phil
Aug 08, 2009 | Sony DVP-NS575P DVD Player
Cd/dvd player only able to play dvd's
Get a hold of your manufacturer and verify the warranty on your cd/dvd player. I do know that if the cd's are not finalized then cd/dvd players will not be able to read them. If under warranty your manufacturer can replace it or troubleshoot the problem with you over the phone.
Aug 07, 2009 | Sony DVP-NS575P DVD Player
DVP-NS575P fail for DTS system
I have an Transistor(Radio) of Sony but it does not play the AM signle
May 12, 2008 | Sony DVP-NS575P DVD Player
Jammed sony dvd
Unplug the power cord for at least 30 seconds, then try again.
Jun 10, 2007 | Sony DVP-NS575P DVD Player
Sony DVP-NS575P DVD Player Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
