Lines on TV Screen
I was getting blue circular lines in the screen when there was a solid colour on the screen. Now there are both blue and red circles. Is this a sign that the bulbs are burning out?
  • 19,396 Answers
Depends on the TV model, if this is a rear projection TV with CRT lamps, that means that either CRTs are not aligned (fault on convergence board) or one or more CRTs had blown.
Posted on Jan 02, 2009
How can I get rid of the coloured lines?
you should do the following tasks:
Press the left side of the TV with your hand, if the colors got disappeared, fortunately the flat cable inside the TV causes the problem. But
If the problem still insists, the panel board inside the TV got corrupted and you must change it with a new one.
May 03, 2014 | Computers & Internet
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Screen shows blue patches on white also red lines on dark colour
Replace the video board, if you can find one. Letting it cool down will not help any.
Nov 13, 2008 | Televison & Video
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv Screen Problems
as you see green screen with lines through it
lines you are seeing is called retrace lines.
the problem is due to green video output section failure
please check the followings as given
  • supply to green video output & video output itself
  • components in green video output circuit
  • crt base loose.
  • connector loose in video ckt.
  • signal from signal processor to  green video section is absent.
hope this will help.
good luck.
Oct 15, 2007 | Televison & Video
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
