Question about Sanyo ECD-T1550 CD Player
Help...sonyo ecd t1550 wont stay open
Keeps opening and closing
  • 11 Answers
SOURCE: I have a Sanyo ECD-t1550 and the display is very
might be cause its tilted upwards.. and the sun is glaring it.. try putting lower in your dashboard.
Posted on Jan 17, 2010
0 characters
1 Points
I have a Sanyo ECD-t1550 and the display is very faint. Any suggestions
Jan 16, 2010 | Sanyo ECD-T1550 CD Player
I have a Sanyo ECD-T801 CD player
try to wipe down the lens cuz probably when ur daughet put the penny inside it she may touch it so u can wipe with some Kleenex or something smooth then see !
Feb 07, 2009 | Sanyo ECD-T801 CD Player
My Sanyo ECD-T801 CD player isn't working.
Yep! That's your Problem. You will need to Remove the Head Unit and Remove the Top Cover and Try to Remove that Penny. Will not be Easy Depending on where it is at inside. Please Rate My Response! Thanks!
2000 suburban sunroof wont close
My sunroof did not close all the way, but would work back and forth. I postitioned the sunroof half way, disconnected the battery for 1 min then tried it again. The system that keeps track of where the sunroof was positioned got reset and it now works great.
Feb 03, 2009 | Rosen inVUE II Video Ent. Sys '00-'02...
Wont stay open
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
May 25, 2008 | Pioneer DEH-P9600MP CD Player
There is a sub preout on that deck, the light i belive if for when sub mute is on
Jan 03, 2008 | Sanyo ECD-T1550 CD Player
you can try the following:
With the car off but iginition switch "on" ,press multicontrol until "face auto open"option comes. select "off" and see the result.
Press RESET with the iginition "on".
the default setting will be "auto open ".so select it "off".
Dec 03, 2007 | Pioneer DEH-P5800MP CD Player
Error 2 on Display
Mabye. I would suggest either opening the unit up and cleaning thr "laser" (optical pickup) with a q-tip. Or try using one of those cleaning cds that have the little cleaner fabric on the inderside... if that doesent work something is most like wrong with the cd machanism wether its not spinning the cd or just not reading it due to a defective laser.. ampman!
Sep 05, 2007 | Sanyo ECD-T1550 CD Player
Dual XD7600 Head Unit Problems
Sounds like the flexible connector that connects to the drop-down front panel is bad, broken pattern lead.
Aug 07, 2007 | Dual XD7600 CD Player
Screen will not open
I have the same problem and found it is the ribbon cable to the faceplate holder. As the plate folds down it breaks the connection in the bad part of the cable and the deck doent see the faceplate, thinks it's been removed and begins to close. As it is closing the ribbon cable straightens and makes connection again. Hope this helps. Kkarma
Dec 12, 2006 | Pioneer Premier DEH-P960MP CD Player
Sanyo ECD-T1550 CD Player Logo
23 people viewed this question
Top Sanyo Car Audio Receivers Experts
xxxxxx xxx
Are you a Sanyo Car Audio Receiver Expert? Answer questions, earn points and help others
