Question about Onkyo DX-C390 6-Disc CD Changer
RCA 5CD changer. CD is stuck behind changer carousel.
Cannot remove the CD. Carousel drawer is stuck open and will not operate at all.
5 Suggested Answers
SOURCE: cd stuck in
take the cover off and take the CD out
Posted on Jun 19, 2007
RFICKES
  • 51 Answers
SOURCE: Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
Find the screws that hold the to of the case to the chassis. They should be on the bottom, and back. Once they're removed, gently pull the top off. You may have to fish under the carousel to get the CD, but if you're gentle, you should be okay. Make DARN sure the power's unplugged, and keep your tools away from the power supply, just in case there's some residual energy left. Good luck!
Posted on Jan 04, 2009
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Posted on Mar 04, 2009
SOURCE: a cd has gotten stuck in my Sony 5 cd/dvd carousel
As long as the cd hasn't caused any other damage to the electronics or mechanics of the player, it should be an easy fix. First, open your carousel then unplug the player to avoid shock. Remove the top lid of the player via the screws on the exterior holding it in place. From there, the stuck CD should be right there for you to reach in and remove. Hope this helps!
Posted on Mar 26, 2009
  • 382 Answers
SOURCE: jvc xl-f254 cd changer for home. 5 disc
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Posted on Jan 29, 2010
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
If anybody can help me please I need to know how to repair the carousel before the CD changer he does not spin thank you
Most of the carousels are driven by a small motor through a gear train, but some are belt driven. You would have to look underneath the carousel to determine what the mechanism is. If it's belt driven, make sure the belt isn't slipping. With the changer unplugged, find the carousel motor, then gently turn it by hand (make sure you are turning it in the correct direction) to check for excess friction, broken gears, jamming by a foreign object, or slipping. If you hit a hard stop while turning the motor DO NOT FORCE IT. Investigate the stop; it's probably your problem. Some changers rotate the motor in one direction to turn the carousel and in the other direction to clamp the CD in the spindle mechanism. If the spindle clamp is hung up, this will prevent the carousel from turning.
Jun 16, 2015 | Audio Players & Recorders
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
Player was moved discs fell forward. Now when the player comes on it makes a horrible sound. Can't get door to open
you're going to have to open the player by removing the top cover and returning the discs to their correct places on the carousel. If you've coded the discs' locations and disc names it will be a pain to have to re-code them, I don't know if the memory will clear if you take the discs out and power the unit up and it finds they're not there.
I believe the discs being out of place are what is preventing the door from opening. It's operated by a motor located under the right front of the carousel, and the only way to get it it is to remove the carousel.... which isn't hugely easy but it can be done, you'll have to take the top stuff off inside, unplug at least several of the cables etc so you can move the top board out of the way. Make sure that all the discs are back in their places on the carousel, OR removed, before you turn the unit back on.
Dec 02, 2010 | Sony CDP-CX400 400-Disc CD Changer
Table Error--carousel will not turn
pull off changer cover, theres 9 screws .looking from the front of the changer, look to left side,thats where there are belts for drive mech. the back one is for the carosel, it might of broke or came off. had the same problem belt came off. works good as new. hope it solves your problem
Nov 27, 2009 | Sony CDP-CX400 400-Disc CD Changer
Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Nov 19, 2009 | Sony CDP-C265 CD Player
A cd has gotten stuck in my Sony 5 cd/dvd carousel player. Appears that the label on the CD had gotten soft (sticky) and when the carousel rotates it stays stuck underneth the top while the carousel moves...
Mar 24, 2009 | Sony CDP-CE375 5-Disc CD Changer
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Cd stuck in
Oct 06, 2006 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX-C390 6-Disc CD Changer Logo
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
