Question about Fujitsu (G281065802)
Plasma monitor won't stay powered up
My plasma monitor keeps shutting down and I can unplug the power cord and plug it back in and it will power back up. This used to work for days, now it only works for about half an hour.
0 characters
1 Points
Reset 90-0667-05 to vt100
If you log on to SP1 using VT100 and you get garbage the port is properly set for CPSS and you will have to use a craft interface to log on talking CPSS to the node. The S1 switch on the control card is to reset the database on the node, but you can also use this to reset the SP1 port back to very careful doing the following procedure as you can delete the database. Power down the node and press and hold in S1 then power up the node still pressing in S1, look at the the display it will after going trough it's start up process display a "0" ...release S1 and press S1 again....this will reset your SP1 to VT100 and you will be able to log on again. "0" reset SP1 and if it display a "1" and you carry on you will delete the database. As I warned you the "1" will delete the database, if for some reason you are stuck on "1" just power done the node without pressing S1 and it will restore as previous setting....good luck!!!
Sep 16, 2014 | Alcatel Newbridge MainStreet 3600...
Check fluids and filters, make sure there is no restriction on tubing, air intake. some times take out the filters etc. then reinstalling them will help. Also unplug for a while then plug it back in and see where that takes you.
Apr 22, 2014 | AirSep FreeStyle Portable Oxygen...
What's your problem?i am facing oblem power alarm and i can not get dial ton on my newbridge 3600 can any body help me to resolve this problem how can i check that
Is this connection between a LGS and LGE card?? if so then the only problem can be on the configuration on the two cards, both needs to be configured for "RE" remote extention.
Jun 23, 2012 | Alcatel Newbridge MainStreet 3600...
We connect 8 analog lines to a 3612 on one end compressed lines to 16 k each accross a data circuit then break them back out on a 3612 on far end. Calls will be up for a minute or 2 then drop. Call...
There are many reasons why the call will be dropped. The call will be dropped when you aggregate link between the nodes fails, if this is not the case monitor the connections on the node and see if the connections stays up. If I would guess it could be the PABX that is dropping the calls and not the nodes.
May 23, 2011 | Alcatel Newbridge MainStreet 3600...
DVR fans won't spin
You are going to need to test the voltage going to the fan with a metter. It should read 12 volts DC or slightly higher. If it does you need to replace the fan.
Jul 28, 2010 | Bosch Multiplexer
Etherlite 160 will not come up on the LAN
I am not sure if it work, why don't you check if it is the port problem by switching the wire or plug other computer to that port. If you can get online then it is not the port problem, slowly add 1 computer at a time to see if there is limit on number of computer you can connect.
Secondly, check the setting on your router, is there restriction of how many computer can get the ip.
If you type ipconfig /all on dos of each computer connect, you get the gateway, can you ping the gateway on each?
Jul 20, 2009 | Digi EtherLite 160 Multiplexer
How do i remove Nmti if it affects port or frame relay resource
Hi Christina,
The problem come up or happened because the link (E1/T1...) problem or 3600 series going down e.g power down etc. The effect of it sometimes influenced the circuits mainly the circuits made by nmti software via hyperterminal, 4601A even 5620 NM (integrated NMTI).
To solve the problem first you have to clear or de-configure the configuration/cross-connect via nmti and than you connect again the circuits. Please using Alcatel 5620 NM GUI to make cross-connection or circuits (Circuits Switch Data).
Mar 22, 2009 | Alcatel Newbridge MainStreet 3600...
Power Consumption Operational Value?
This is what you want to know. Copy and paste this address.
Dec 30, 2008 | Alcatel Newbridge MainStreet 2902...
Do not no how you put code in digibox
arnet a700c digi digital video broadcasting a700c 0708td 09408
Dec 02, 2008 | Concentrators & Multiplexers
Newbridge 3612
yes, you can shut down and relocate with no adverse affects.
Apr 28, 2008 | Alcatel Newbridge MainStreet 3612...
Fujitsu (G281065802) Logo
87 people viewed this question
Top Fujitsu Concentrators & Multiplexers Experts
Len Conradie
Level 1 Expert
Michael Thomas
Michael Thomas
Are you a Fujitsu Concentrator and Multiplexer Expert? Answer questions, earn points and help others
