Question about Linksys Wireless-G Broadband Router
I have just purchased the linksys wireless router and hooked it up according to the instructions numerous times. After putting the installation disk in it stays i am not hooked up properly when i know i am. what is up. i do have internet operating just not wirelessly
  • tccarl02 Jan 03, 2009
    THE WIRELESS-G ROUTER KEEPS TELLING ME I'M NOT HOOKED UP PROPERY WHEN I KNOW I AM.
  • 50 Answers
Hi
Please refer the link http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US/Layout&cid=1166859678292&pagename=Linksys/Common/VisitorWrapper
it will provide EasyLink Connect tool. EasyLink Connect is a first-time setup application that automates the setup of your Linksys router, including:
  • Cabling Instructions
  • Internet connection configuration
  • Wireless connection and security setup
  • Other devices and computers addition
Please Vote if this is helpful
Posted on Jan 02, 2009
How do I change from wired hookup to wireless? Bob
Instructions
Things You'll Need
Broadband modem
Router compatible with modem
Internal or external wireless network adapter
Phillips screwdriver
Suggest Edits
  1. Prepare the Network
  • Purchase and setup a wireless broadband router by interfacing it with your wired computer. Choose a router that is compatible with your broadband modem and that supports the wireless network type you desire.
  • Enable WPA or WPA-2 security, and change your router's default password. Give your SSID or wireless network a memorable name.
  • Connect your modem to the WAN (wide area network) port on your router.
  1. Install an Internal Card
  • Purchase a wireless network card that is compatible with the router you purchased and with your computer. For example, if you bought a 802.11 b/g router, do not purchase an 802.11 n adapter.
  • Shut down your computer. Remove all cables and peripheral devices.
  • Remove the left side panel while facing the front of the case. You may need to remove screws or to manipulate latches and notches. Consult your case or computer manufacturer's documentation if you are unsure of how to remove the panel.
  • Clip the metal part of the anti-static wrist bracelet to a metal object, and ******** the bracelet.
  • Locate an available PCI or PCI-Express slot. Unscrew the screw that secures the slot cover that corresponds with the slot, then remove the slot cover.
  • Line up the wireless adapter's pins with the slot. Insert the card until it clicks into place. Do not force the card into the slot, or you may damage the card's connectors. If you feel resistance, remove the card, line up the card with the slot again, and reinsert.
  • Secure the card with the slot cover screw. Reattach the side panel, and replace any screws you removed earlier.
  • Reinsert all cables, and plug in all peripherals. Boot the computer.
  • Allow Windows the opportunity to detect the card. It should automatically install the drivers for the card. If you have updated drivers, insert the disk and install according to on-screen instructions.
  1. Install an External Card
  • Boot up your computer.
  • Insert your external wireless adapter into the appropriate slot. For example, if you purchased a USB slot, insert it into a USB port.
  • Complete Setup
  • Double-click the network icon in the task bar.
  • Highlight your wireless network. Windows will display the name you entered when setting up your router
  • Click the "Connect" button.
  • Enter and verify the security key you created when setting up the router. Click on "Connect."
If you have further query then try to let me know. Thanks for using FixYa.
Aug 27, 2011 | Cisco Linksys Wirelessn Router Black...
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
Laptop says no internet connection
First you need to ensure proper connection and filtering. Make sure the source cable is plugged into the Linksys router first. Direct connections must be made to the router, meaning the cable to your main computer should come from the router, not the main source.
Next make sure that the connection is made. You should see a light on the router indicating proper internet connection. Once this is accomplished, connect your main computer and you should have access to the internet on it.
Now comes the easy but somewhat tricky part (tricky only because icons can vary a little). If you haven't already done so, run the setup disk for Linksys. It's has simple, easy-to-follow instructions to set up your network. Now for the laptop. On the blue bar at the bottom of the laptop screen there should be an icon indicating internet connection. Click on that icon to show available wireless networks. Most likely your Linksys router will show up as a secure network. When you click on that connection it will ask you for a WEP key. That key is usually a 10 digit alpha-numeric key written on the back of the router. Sometimes it's on the box the router came in. Sometimes it requests a 12 digit WEP key, in which case simply add two zeros to the front of that same key. If you set up a password for your wireless network you will need that as well.
NOTE: if you have neighbors close, you should always secure your network with a password.
You may need to shut down and restart the laptop in order for the changes to take place.
It sounds confusing, but once you start you'll find that it's actually fairly straight forward. I hope this helps. Good luck!
Jan 12, 2010 | Linksys Wireless-G WRT54GS Router...
How do I hook up my Linksys wireless-g bradband router to my computer?
first connect a straight cable from the router and computer.... then install the CD given by the linksys router.... follow the instructions as given at the time of installation.
Jul 04, 2009 | Linksys Wireless-G Broadband Router
I was given a linksys wireless-g model wrk54g router but it didn't come with an installation disk. I have a Thomson speedtouch modem ST530 V6. Right now I am hooked up thru ethernet and getting internet...
was the router used by previous users? or did you buy it? if it was used then it was probably configured for different ISP. You don't need any CD. Just connect to the router via your browser (probably http://192.168.1.1) and adjust settings in WAN section.
Mar 15, 2009 | Linksys Wireless-G Broadband Router
Trying to install linksys wirelee i put cd in the pc nothin comes up on screen
Auto run might be turned off. Click My Computer then click what ever driver you have the CD in ( D: E: ect.) Then find the installation or setup icon. Then follow instructions. It will install drivers then walk you through hooking up the router.
Mar 15, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
New Laptop Connection
Are you connecting and configuring using wireless or cable?
Sep 07, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless G Router (WRT54G2 V1)
Go to linksys.com. Go to support. Type in your router model number. The software will appear on the screen for you to download.
Aug 05, 2008 | Linksys Wireless-G WRT54G Router
Set up wireless router to laptop
Go to ADDRESS BAR TYPE IN 192.168.1.1
Leave user name open, password is admin go to the set-up tab and there you go
Aloha
Kahuna
Jun 11, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
124 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
