Question about Optimus Televison & Video
Batteries I have an old Optimus mini portable tv cat. no 16-176 it says use 4 AA alkaline batteries. I want to know if I can use rechargeable batteries and whick one would be the best to use with it? I had lost my tv for about 2 years and just found it. I will be getting a lot of use from it now but the batteries die too fast and I can't afford to keep buying them. Thanks for the help, Pat
jackboy
  • 2985 Answers
SOURCE: clock battery won't recharge
Change to Ni-Mah rechargeables at the highest capacity you can find. If still in trouble it will suggest the internal battery has died - and a replacement is a repair job which will be pricey if feasible So just live without that feature.
Posted on Aug 29, 2007
SOURCE: nikon coolpix 5600/4600 - won't turn on
I had the some problem... found a fix on another thread here on fixya...
hold the power button and at the same time press the play button.
Mine turned on after about 3-4 seconds of holding them down together!
Posted on Sep 09, 2008
  • 6 Answers
SOURCE: Batter Life
This isn't a solution but is a confirmation. Battery life in this camera is terrrible, especially with alkaline batteries. The rechargable NiMh batteries do better, but even there life is substandard. When setting up the camera on the munus, you have to choose a setting for either alkaline or NiMh batteries. This seems to have some effect.
I have found that with new alkalines, the camera will even shut down so fast that it leaves the lens extended. The only I could find to get the lens back in was to put in freshly recharged NiMh batteries, and then push the power button to close. Then the camera was back to its voracious "normal."
Posted on Sep 24, 2008
welcomejee
  • 10594 Answers
SOURCE: Camera keeps shutting off.
Please use Sony Cyber-shot batteries for DSC-H2 model camera.
Posted on Nov 18, 2008
  • 3567 Answers
SOURCE: Help with getting Yamaha 1981 Special running after winter.
Drain the old gas out of the tank to start with. Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Be sure the bolts are tight. INSTALL AN IN-LINE FUEL FILTER. Let the float bowl fill then start the engine. Set the idle speed with the idle screw. This process should get you back on the road.
Please rate this solution. Thanks!
Posted on Apr 11, 2009
I cannot switch the camera on
sure your batteries are still tip top?
Try two new AA sized NiMH rechargeable batteries or if you have some new alkaline batteries, put them in. the alkaline batteries won't last long, but it it could hint if the camera is still working and worth buying new rechargeables.
AA manganese (Zinc-Carbon) batteries cannot be used with this camera.
Nov 27, 2013 | Vivitar ViviCam 5100 Digital Camera
Does powershot A470 use AA rechargeable battery?
Yes. You can use either rechargeable (NiMH) batteries or disposable (alkaline and lithium) batteries.
Apr 02, 2011 | Canon Cameras
Does this camera operate on regular AA bateries. Put 2 brand new ones in and it will not power up. The manual says Kodak does not "support" Alkaline batteries....
Probably this old chat may help you to resolve your problem.
From site:
http://www.digitalcamera-hq.com/products/kodak-easyshare-c663
Kodak EasyShare C663 Specifications
  • 6 megapixels
  • 3x optical zoom / 5x digital zoom
  • autofocus
  • auto exposure
  • JPEG file format
  • ISO 100-400
  • 2 AA batteries
  • movie mode w/sound
  • 2.5" LCD screen
  • Part Number:C663
  • Release Date:Jan 12, 2006
chrissy66 (12/10/2007)reply to this comment (by James DeRuvo - 12/12/2007)Sounds to me like your lens may have come out of alignment. Was it dropped recently? Since your camera is still under warranty, the best thing you can do is have Kodak should fix it. If your camera is out of warranty, or if Kodak refuses to repair it for free, the one thing you can try is to try resetting the camera.
Kodak is also of the opinion that lens errors also occur when you use batteries not recommended by Kodak.
I recently chatted with a kodak specialist about this issue and he recommends changing your batteries to NiMh rechargeable batteries. These are the batteries that the camera is designed to use and using other types - like alkalines, can often cause the lens error to occur. If that doesn't work, then the camera indeed does need repair.
Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your Digital Camera - and you can recharge them up to 1000 times in our rapid charger.
Oxy-Alkaline Digital Camera Battery (AA Size).
CRV3 Lithium Batteries: A non-rechargeable battery designed specifically for today's feature-rich cameras. This battery is the obvious choice for speed performance, and long life. It delivers faster flash recycle times and lasts up to 10% longer than our previous design!
Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger,
Jan 06, 2011 | Kodak EasyShare C663 Digital Camera
Battery exhausted, change them, take one photo, and camera says battery exhausted again. I have this camera one year and this is the first time this has happened.
Good quality rechargeable batteries are a must for these cameras. What I would suggest is AA' NI-MH rechargeable batteries the type that come already charged and when used and recharged will hold their charge up to 80% for a year. These batteries you will find will outlast any AA Alkaline type. If you are using a no name department store AA Alkaline type battery it's a wonder it even turned on.
Dec 22, 2010 | Nikon COOLPIX L100 Digital Camera
Is it necessary to use Kodak AA alkaline batteries in the camera or will other AA alkalines work?
Other battery will work in your camera as long as it is AA alkaline.
You can also use rechargeable battery with different brand.
Apr 13, 2010 | Kodak EasyShare Z915 Digital Camera
Just bought a second hand Canon Powershot SX100 IS.
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Mar 08, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
IT HAS BRAND NEW AA BATTERIES IT WILL TURN ON BUT THEN TURN OFF
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though brand new and right out of the package, they may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Modern rechargeable batteries (I'm not talking about old NiCad's, those are awful) can hold over five times the amount of power of an old fashioned alkaline battery. Also keep in mind that rechargeable batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Oct 26, 2009 | Cameras
My Kodak EasyShare C180 Digital camera, came with "Kodak" batteries after those died, I inserted new batteries, and now everytime I try to turn the camera on, it doesn't respond. I have tried Lithium...
hi i just to have silimar problem with old panasonic, kodak and polaroid cameras.
try to use Duracel alkalines, not the cheap ones with out alkaline those are for remotes and clocks. flashlights.
if you are using rechargables make sure they are 2700mha AA NiMH or higher. lower won't work(there is another kind of rechargeables batteries those don't work on it).
for the lithium i never used them. they were kind of expensive compare to alkalines.
If i help. please rate me :)
Oct 08, 2009 | Kodak EasyShare C180 Digital Camera
Types of batteries.
You can use AA disposable batteries (alkaline or lithium) or rechargeable (NiMH or Nicad) batteries. Lithium batteries last much longer, but are generally quite a bit more expensive than alkaline batteries. You should never mix old and new batteries or different types of batteries. If you use Nicad batteries, it is recommended that you use a Nicad conditioning charger to extend the life of the batteries. Note: If you use rechargeable batteries, you will need a battery charger. The camera's AC power supply does not recharge batteries.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
What is the difference between the available AA battery chemistries?
AA batteries are available in four basic varieties: Alkaline Nickel-Metal Hydride (NiMH) Nickel-Cadmium (NiCad) Photo Lithium (Li-FeS2) Alkaline and photo lithium are non-rechargeable, while NiMH and NiCad are rechargeable. Each has advantages and disadvantages. Non-Rechargeable vs. Rechargeable: Rechargeable batteries are desirable from an environmental standpoint because they are reusable. Self-discharge refers to the fact that batteries lose energy when unused and even when not in a camera or other device. Rechargeable batteries tend to have relatively high self-discharge rates, approximately 1-2% per day for nickel-based batteries. Non-rechargeable batteries generally have very long shelf lives and extremely slow self-discharge rates. This makes non-rechargeable batteries a better choice for infrequent usage. Non-rechargeable batteries are available fully charged in stores all over the world, which makes them a convenient choice for travelers or customers who have dead rechargeable batteries and no time to recharge. Photo Lithium Batteries (Li-FeS2) (non-rechargeable): Photo lithium batteries will yield the longest battery life of any AA battery, surpassing NiMH by 50-100% and surpassing alkaline by 100-500%, depending on the load. While they are more expensive than alkaline batteries, their additional energy capacity makes the cost the same or less per shot than alkaline batteries. Nickel-Metal Hydride Batteries (NiMH) (rechargeable): NiMH batteries are the lowest cost overall solution for users that take a lot of pictures (more than the equivalent of a roll of film per month) or use a lot of high-power features. The largest disadvantage to NiMH batteries is their fast self-discharge rate of 1-2% per day whether the batteries are in a camera or not. NOTE: NiMH batteries need to be completely charged and discharged a few times when new to achieve their full capacity. Rechargeable batteries will eventually fail. If you have been getting acceptable battery life and then see a decrease in life, either quickly or slowly over time, a worn-out battery may be the cause. Storing or charging the batteries in high temperature conditions will accelerate this potential failure. Alkaline Batteries (non-rechargeable): Although the cheapest and easiest to find, alkaline batteries yield the worst performance of all the chemistries in a digital camera. They lose capacity at high power drains and at low temperatures. Skiers and other winter outdoor enthusiasts may find them unsatisfactory. Alkaline batteries are frequently available in two types: High drain (ultra, titanium, maximum etc.) Regular The high drain versions are a premium product designed to operate better under heavy loads than the standard product. However, there is a trend of major brands to increase the performance of their standard battery to b
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Televison & Video Logo
15 people viewed this question
Top Optimus Televison & Video Experts
Electro Med Services...
Are you an Optimus Televison and Video Expert? Answer questions, earn points and help others
