Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My Book (G:) icon is different
The My Book icon under "My Computer" folder was a blue "WD" when it was first installed. I have loaded some pictures and music onto the external hard drive since. Now that I have shut down and restarted my computer, the My Book icon itself is just a window with little icons. I have a PC. I want to know if there is something wrong.
  • Anonymous Mar 02, 2009
    When I try to do this, it says there is already a autorun that is read only on the drive.  But,  I do not see the file if I look in My Computer
    Scholar:
  • 58 Answers
no you there iss no big problem.
The icon of your hdd iss created from the autorun.inf
http://www.fiveanddime.net/notes/hd-icons.html
Change hard drive icons Change hard drive icons:
To change the icon for your hard drive, create the
following file in notepad:
[autorun]
icon=C:\WINDOWS\SYSTEM\Pifmgr.dll,36
Notice it's two lines.
If your hard drive is C:
click Save As... and navigate to C:
and save it as autorun.inf
enclose it in quotes so Notepad won't put a .txt
on the end of it
The path specified is the typical Windows path
yours may vary, but you'll have that dll file.
The 36 at the end is the number of the icon I chose.
(Icons in a file are numbered, starting at 0.)
To see the change, open Windows Explorer; click
F5 if needed to refresh.
To preview your icon options, select an icon on
your desktop, right-click and select
Properties, then Change Icon. You can also select
any other .dll file in your computer, although most
won't have icons.
The common Windows icons are in
C:\Windows\System\shell32.dll
(xp = C:\Windows\System32\shell32.dll)
You can also point to a single icon.
Using the example above:
[autorun]
icon=c:\windows\cursors\myicon.ico
I have three hard drives and nine partitions; under
WinMe, I had to move the icon/dll to each
partition and edit the autorun.ini, i.e.
C:\Windows\System\Pifmgr.dll,32 became Pifmgr.dll,32.
WinMe also wouldn't let me change the icons
for the primary partitions of the first two
drives, but did let me change the
primary partition icon of the third drive.
Posted on Jan 02, 2009
  • 3 Answers
An addition.
When I try to do this, it says there is already a autorun that is read only on the drive. But, I do not see the file if I look in My Computer - Guest
I had the same problem, the file is a pain in the *** to replace. This was my solution:
START -> RUN -> cmd \\opens command line
cd/d [drive letter]: \\changes active directory to root of target drive
DEL /F /A:H autorun.inf \\deletes autorun.inf; /F - negates read-only; /A:H - negates hidden
...to reiterate, assuming your drive letter is, let's say G: (like in the original question) the solution should look like this:
C:\Documents and Setting\[yourusername]>CD/D G:\
G:\>DEL /F /A:H autorun.inf
(Only the bold text is what you should be typing.)
After you do this, follow no_pc-gst's instructions to choose a new icon.
the standard Hard Drive icon is:
icon=c:\windows\system32\shell32.dll,8
Posted on Aug 09, 2009
WD My Book- Model: WD5000po32 I can't find the software. I was told to go into WWW.WDC.com I still can't find the backup software.
WD SES driver (32-bit) download, and WD SmartWare Disk Image for Windows,
http://wdc.custhelp.com/app/answers/detail/a_id/5419/
Western Digital My Book Essential WD5000po32 unplugged from computer, and power off.
1) Under the Download heading to the far right, left-click on the blue -
WD_SES_Driver_Setup_x86.zip
A small window will come up on the right -
Opening WD_SES_Driver_Setup_x86.zip
Make sure there is a green dot in the circle to the left of - Save File
If not, left-click in the circle.
Now go below in the small window, and left-click on OK.
Another small window will come up on the left.
In the heading of this window tells you where the file will download to.
{Note* You can change where the file will go to. I am not including this information at present, so as to not confuse }
In the wording of the heading may be Desktop, or My Documents, or Downloads.
{If your computer has Vista, or Win 7 on it, it will be Desktop, Documents, Downloads }
Desktop: The file will be on your desktop screen. (WD_SES_Driver_Setup_x86.zip )
My Documents: Left-click on Start > Then on My Documents.
(Vista and Win 7: Left-click on the Windows logo button, then on Documents )
Downloads: Left-click on Start > Then on My Documents. DOUBLE-click on Downloads.
{Windows logo button, Documents. DOUBLE-click on Downloads}
When you see the file name, DOUBLE-click right on it.
The file is a Zip file. A Zip file, for one, is used to send large amounts of information over the internet.
The file has to be 'unzipped'.
After you double-click on the file, you will be taken to the Unzip Wizard.
Click on Unzip on the right side.
In the next window, (Installation Wizard), go to the far left side, and click on Extract All Files.
Click on Next, Next, and Finish at the bottom.
Now go back to the folder the zip file was in. There will be the yellow folder icon with a zipper on it, and the name of the file, and a yellow folder with the name of the file.
DOUBLE-click on the yellow folder with just the name of the file next to it.
In the names listed DOUBLE-click on WD SES Driver Setup (x86)
The SES Driver Wizard will lead you through installing.
(Left-click on Next, Next, Install, and Finish)
Same procedure for the second file - WD SmartWare Disk Image
For additional questions please post in a Comment. (Believe upper right of your page. FixYa is undergoing improvement changes )
Regards,
joecoolvette
Sep 11, 2011 | Western Digital My Book Essential Edition...
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
When i plug in my western digital my book home edition to my pc it shows no folders in it like there is nothing there can you please help
Try connecting it to a different USB port on your computer.
Try connecting it to a different computer.
If it still is under warranty, W.D. will repair/replace it (but won't try to "rescue" your data).
If the warranty has expired, W.D. has a 'Customer Loyalty' program; buy a new W.D. disk-drive from their web-site, and enter the serial-number of your current disk-drive, to get a discount on your purchase.
Or, disassemble the enclosure.
Separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a 'slave' in a desktop computer, to see if the files can be accessed _not_ through that adapter.
Note that you could put a different, compatible, disk-drive into the enclosure, to build your own external storage device.
Oct 26, 2010 | Western Digital My Book Home Edition 500...
Just plugged in new wd 1tb hardrive to windows xp computer blue light flashing on book front but no icon on computer
Brand new?
Did you follow the instructions in the booklet that were packaged with the external disk-drive?
Did you try connecting the unit to a different computer?
Did you take it back to where you bought it, and ask them to demonstrate attaching it to one of their computers, as a demonstration that it works, or to prove that it is "defective" and the seller must replace it?
Nov 11, 2009 | Western Digital My Book Essential 1TB...
WD My Book 1TB not recognised by belkin modem router USB storage
Hi
i am fairly certain The WD my book external hard drive needs to have the correct software to be able to use and because routers dont have a CD drive i dont think you will be able to do it.
Apr 27, 2009 | Belkin N1 Vision Wireless Router
My Book Essential Edition, can't get data but know is there hope
Hi There, Don't know if this will help ?. I have My Book Ess-Edit 500. I bought it six months ago. (it has a blue light which moves up & down when on) Anyway here goes. you don't have to safely remove my book as it turns on & off with your PC. Was your pc on when you pulled the plug? IF SO YOU MAY BE IN THE S***. with my book turned on, Try from start xp / flag Vista. / Computer/ highlight WD mybook / right clik open, in list you should see whats on your my book, folders & so on.
(you seem to be looking for your pic's). highlight folders/ right clik open/ you can restore a file from the list by, again highlight/ then right click/ from list pick (send to) Documents. From there you can copy / paste to pictures. Hope this helps ? Steve 105
Mar 05, 2009 | Western Digital My Book Essential Edition...
How do I get started???
Hi firewolf708,
You’re going to love your WD 750! The way WD set up your drive is like a spare hard drive. To access it you will click on My Computer, and you'll see your C:\\(local Drive) and your WD 750 might be called X:\\(My Book) . (X = new letter of drive possible E: or F: and so on) All you have to do is click on that My Book drive and you have one very large folder to start copying and pasting into. It's just that simple. A good plan for navigating to it on a continuous method is, when your are at the My Computer screen that shows you both your C:\\ drive and your X:\\ drive right click the X:\\ drive and mouse over Create a Shortcut. Once the system creates the shortcut you receive a message that it can't create a shortcut in that area, but it can create one and send it to your desktop. You want to click on yes, and when you go back to your desktop, you'll find a easy icon that you can click to access that drive with a few clicks.
Have Fun!
Mark
Dec 31, 2008 | Western Digital My Book Essential Edition...
Wd passport file customizing
If you open the Computer directory and identify the drive letter for the WD Passport drive, right-click on the drive folder and select properties. The properties tool for the drive will open showing several tabs. Select the Customize tab and you will see a heading for "use this folder type as a template" with a drop down menu. Here you can select different categories for the folder and apply it to subdirectories also by checking the box below. This should give the folders more of a vista look! If you want to personalize further and add your own images to the folder icons you can also do this here. If you don't select the apply to subdirectories option you can manually apply different styles to different folders in subdirectories. If you don't like the way things have turned out you can also restore the default settings.
Hope this answers your question.
Have fun
Dec 06, 2008 | Western Digital Computers & Internet
I cannot access western digital 1000 gb
Here is a tedious solution that works. Use MioNet and move all the files you want to keep to another drive or another computer, then delete everything from the MyBookWorld. Remove MioNet from all computers. Next access the drive's built in Shared Storage Manager with a web browser. Check the pdf manual on the install disk to find out how. Create a new shared folder and then move everything you want on the drive into the new folder WITHOUT using MioNet. Map the shared folder as a network drive for easy access. Never, ever, EVER use MioNet again and all should be good. The drive works, the MioNet software does not.
Feb 19, 2008 | Western Digital 500GB My Book World...
Win98se i did it ... HERE'S HOW
OK, I bought this Western Digital MyBook 500 GB Essential Edition too, and could not get it to work with Windows 98 SE.
I followed the above instructions, but my version of windows was missing even the drivers suggested above! UGH!
HOWEVER, I found ANOTHER SOLUTION. I installed USB 2.0 drivers for mass storage and the the MY BOOK icon popped up on my Windows 98 SE machine. Hurray! Hurray! Hurray!
Here are the drivers from this british webpage:
http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
Good luck to all you frustrated folks scooping your info off Windows 98 machines!
Dec 29, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
2,586 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
