Question about Linksys Wireless-G WRT54GS Router (e125894)
I have a time warner cable modem model U10CO18 and i want to connect it to a linksys wireless-g broadband router with speedbooster model wrt54gs ver.6 i dont have cd-rom or user manual i was wondering if anyone can help
  • 298 Answers
I have a step by step guide here on how to setup a linksys router with cable internet. just click this link.
I hope this helps. But if you still have a problem just reply to this post.
Posted on Jan 03, 2009
I need a simple set-up manual for model # WRT54GS router
Your Internet service provider is comcast cable company.
You need to open the setup page of the router and change the Internet connection settings manually.
Connect the computer to the router and modem to the router.
Open the setup page of the router using 192.168.1.1
Click on MAC address clone. Enable it and click save settings.
Power cycle the router and your main computer will be online.
Then you can change the wireless settings manually.
Click Linksys router setup steps
Jan 04, 2012 | Linksys Wireless-G Broadband Router
My router stopped communicating with modem
LinkSys Wireless-G WRT54G 2.4 GHz Broadband Router with 4-Port Switch:
Go to LinkSys Login. wrt54g_back-panel_mini.gif Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
There are two ways to reset the Router's factory defaults:
The Internet port is where you will connect your broadband Internet connection.
Please Rate Me
Nov 17, 2010 | Linksys WirelessG Broadband Router with...
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
How do I remove linksys broadband WRT54GS Wireless-G router from my pc. and revert to just my Motorola, SB5101 surfboard cable modem. Tried simply removing the router and pluging the modem back in, but no...
Hi intriguedkiw;
Yes this is fairly simple. Open up your network connections and delete the icon for the local area connection to the Linksys router, and click on Add new connection to create a new connection to the Cable modem. The add wizard will walk you through connecting to the modem, just fill out the questions correctly, and you should be good to go.
Good Luck,
Mark
Please dont' forget to leave a rating.
Feb 19, 2009 | Linksys Wireless-G Broadband Router
Help
You do not need the manual or CD
1. Turn off both the linksys and your modem
2. Turn on your and wait for the usual lights to turn solid
3. Turn on the Linksys and wait 30 secs
4. Press the button on the front to the left. It does not look like a button but flashes while it is finding an ip address
5. now connect with an Ethernet Network Cable and make sure the internet is working
6. Next Setup the Wireless Encryption, if you don't know how to do this, post and I will help
7. Disconnect the cable and Connect Wirelessly
If you have limited connectivity then next try this: http://www.howtofixanything.co.uk/howto-269.html
Jan 02, 2009 | Linksys Wireless-G WRT54GS Router...
I want to connect a linksys wireless router
please visite this URL:
http://www.thinkbroadband.com/hardware/reviews/2002/q3/bto-linksys.html
Regards,
Azeem
Voice : 00923004167636
e-mail : toazeem.pk@hotmail.com
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Cd rom download
the links below will show you how to manually install the device on your network
Setting up your Linksys router for Cable ISP
Setting up your Linksys router for DSL ISP
Setting up your Linksys router to have wireless security.
if you have other questions just let me know.
Nov 01, 2008 | Linksys Wireless-G WRT54GS Router...
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
When i connect my router to my computer i have no internet
Eric, I have a wireless G and have had loss of my IP address. Call Linksys Tech and they will help you restore it again. They did that for me once and they were very helpful.
Apr 22, 2008 | Linksys WIRELESS-G WRT54GS 802.11G...
Linksys Wireless-G WRT54GS Router (e125894) Logo
203 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
