Question about Averatec 3200 Notebook
Averatec laptop is overheating. Power button disabled. Screen dar
I have unplugged the laptop, but the hard drive continues to whir and heat. I cannot get the screen to appear, but I can't turn off the hard drive either.
  • 495 Answers
Please refer to link below for complete solution:
http://kablammo.strongerthandeath.com/2006/01/31/averatec-3150-overheating-solved/
Posted on Jan 02, 2009
  • Manoj Rout
    Manoj Rout Jan 02, 2009
    It usually turns out to be
    the fan, either failed (least likely) or chock full of dust. Most of
    their units place the fan sucking staright up close to the bottom
    louvres. Lap use or even setting on a table can start sucking up stuff
    into the fan. Isn't long before the low power fan doesn't run properly.
    With the temp utility you can watch, under compute load, how fast the
    temp does rise. Very rapid. Newer units have a sticker placed directly
    below the fan blocking the direct suction louvres to prevent the fan
    from sucking debris into it. It then pulls the air from all over the
    case and works fine keeping the fan relatively clear of dust and such.
    You will have to check your fan and as mentioned above clean it out and see if it does resume full speed operation.
  • Manoj Rout
    Best products to avoid your laptop being overheated.
    1) The Vantec LapCool3 USB Notebook Pad is a valuable attachment
    that sits under your laptop to draw air away from the fans on the
    bottom. It silently removes hot air from your system, and attaches to
    your computer with a USB cable
    2) For a super-quiet and contemporary look, you'll want the Antec Notebook Cooler.
    Quality materials and the heat-resistant coating make this one built to
    last; you'll barely hear the fans on this model, and it also uses the
    USB port for power. An added bonus is the three-year warranty.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, remove likewise the battery. This is to address the immediate concern of overheating and continous hard drive whirring. Therafter, will address the other concerns.
Good luck and Thank you for using FixYa. Happy New Year.
    President:
  • 2,110 Answers
Press and hold power button for 10 sec to shut down fully...
Laptop will not start up
Try holding power button down for 10-15 seconds
Mar 02, 2015 | Computers & Internet
My averatec computer makes a whirring sound
That sounds as if the cooling fan is working very hard. This normally means that the cooling ducts are full of dust and other rubbish. You may be able suck most out with a vacuum cleaner or blast with an air duster. Failing that, it's taking it apart (you will need a manual) to clean the heat sink area around the cpu.
Jun 16, 2014 | Averatec 3200 Notebook
Compaq 615 froze with no display and fan whirring.
1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
2. Shut down the computer if it is running.
3. Press the power button to turn on the computer.
4. Press f10 when the HP/Compaq logo displays.
5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
6. Select HDD Self-Test options .
7. Press enter to display a list of HDD/Self-Test options.
8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If test reports pass then perform installation of OS
else hard drive has gone bad
Apr 16, 2010 | Compaq Computers & Internet
My lenovo y530 pretty much just died. i have had problems with overheating before, but it wasn't hot this time. I had just turned it off and needed to restart it (have had wifi connectivity issues), so i...
unplug power supply remove battery and let set for a bit.replace battery and try to turn it on..you probally have corrupt the hard drive..if all indicator lites are flashing then its working and maybe the screen has been corrupt or broke.if you have a desk top monitor around you can hook it up to your laptop and see if you can see anything on that,and if so you can go in and check all the drivers are working properly especially the monitor and graphics..yes a desk top screen will hook rite up to a laptop.
Jan 02, 2010 | Lenovo IdeaPad Y530 Notebook
Gateway laptop - whirring, buzzing sound
if it's a continuous whirring sound it is most likely the cooling fan. this is normal. as the computer gets older this will get noticably louder as the fan has to run faster to prevent overheating.
Aug 14, 2009 | Gateway Computers & Internet
I have an averatec 3200 laptop.no display
Yes..most probably its HDD. Remove the hrddisk and try booting. If it displays, no HDD.then the prob lies with HDD.
Jun 07, 2009 | Averatec 3200 Notebook
Laptop fails to boot. no post beeps no video Power light comes on Hard Drive light comes on briefly and the Drive can be heard spinning up then stopping. Laptop was originally purchased in North Korea
Clean first its ram module edge connector with soft eraser. But disengaged first its battery, power source and completely shutdown.
Then put it back and try to boot. If this doesn't help let me know . Leave a comment.
Apr 23, 2009 | Computers & Internet
Averatec 6200 laptop
bad power plug or power pack buy labtop cooler u can set it on on ebay 15
Jan 10, 2008 | Computers & Internet
Averatec 3200 batery overheated wouldn't go off/now wil not come on
you may have fried the battery test if u can, but if it overheated u could of fried any of your hardware components which would also caused the screen of death
Nov 25, 2007 | Averatec 3200 Notebook
Averatec 3200 Notebook Logo
54 people viewed this question
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
