Question about Toshiba Satellite M50 Notebook
Toshiba Satellite M50 Sound
Have no sound Volume control set OK States this device is working correctly.In Control Panel "Sounds & Audio devices shows low sound on volume cannot alter slider.nil sound syst speakers or headphone
  • 1 more comment
  • xayle188 Mar 25, 2009
    i need tohiba setellite m50-mx2 sound and modem drivers
    so please help me...
    Thanks in advance
  • penguinchief Apr 17, 2009
    My laptop has no sound but everything seems to be allright. Drivers okey, i just reinstalled the OS. I cannot alter the slide bar in control panel to change my volume (it is set to minium low)
  • Anonymous Mar 21, 2014
    control panel shows sound on
I want to display my volume icon
Dear Costmer,
please Followup ,
To enable the display of the Volume icon, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Sounds and Audio Devices.
  3. Click Show volume control on the taskbar.
  4. Click OK.
When you have the new desktop features of Windows XP enabled, follow these steps:
  2. Click Sounds, click Speech, and then click Audio Devices.
  3. Click Sounds, and then click Audio Devices.
  4. Click Show volume control on the taskbar.
  5. Click OK.
amit.mishra.lenovoservice@gmail.com
Feb 13, 2015 | Toshiba Satellite Computers & Internet
I resently lost sound of my first laptop toshiba satellite 1135 s1553 part 633436644k, rebooted windows,checked trouble device manager etc. but of no avail,then some body told me use usb sound card,
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope it helps you
Mar 04, 2012 | Toshiba Satellite 1135-S1553 Notebook
My toshiba satellite a105-S4234 laptop says it does not have an audio device but no yellow marks through the device manager sound and audio files. Help
reinstall drivers
Jan 18, 2012 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
I HAVE A PROBLEM WITH TOSHIBA HARMAN/KARDON SOUND. I HAVE INSTALL SOUND DRIVERS AFTER THE OTHER BUT THERE IS NO SOUND STILL. PLEASE HELP ME WHAT DO I DO NEXT
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
Oct 31, 2011 | Harman Kardon HK695 Computer Speakers
I do not have sound on my laptop, its a toshiba satellite m-105 s-3011
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
also
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 08, 2011 | Computers & Internet
My sound in the laptop is not working?
also
hope this helps:
Jul 13, 2011 | Toshiba (4CH-VOUT) Sound Card
No sound
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
don
Feb 16, 2011 | Toshiba Satellite U305-S2804 Laptop
My Toshiba Satellite A135-S2386 laptop all of a sudden says "no audio output device is installed" any help on how to fix this would be appreciated! I have gone to device manager, however states there is...
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 13, 2010 | Toshiba (4CH-VOUT) Sound Card
My speakers won't work. It says, "no audio devices are intalled. when I go to my device driver, it says it's working properly.
Go in the control panel and click on the sound icon and make sure that your sound card is the default sound device.
Aug 06, 2009 | Toshiba Satellite L305-S5907 Laptop
Toshiba Satellite M50 Notebook Logo
276 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
