Question about SanDisk Sansa Clip MP3 Player
SANSA Clip not recognised
I went to settings ---format--- After which my laptop does not recognise the sansa.Thru Windows media player i cannot find my SANSA to do the sync
I need help
  • Anonymous Jan 02, 2009
    I went to amost every site and i stile can'nt find it. And my compturer will not recsoniz me.
  • Anonymous Jan 06, 2009
    My computer will not recognize the sansa clip when connected using the USB port. I am not able to find it in my computer or in other area. The sansa clip reads connected but the computer doesn't.
    Problem Solver:
  • 14 Answers
DON'T USE THE WMP (windows media player) It screws with some things; too complex.
(to clear or 'erase' skip to format -below)
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
Most other problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Posted on Jan 05, 2009
It wont read in windows media player but i unplug it does but every time i plug it in it just makes it slow
If you recently updated the software online it may have changed the USB setting on your sansa. Go into settings - USB mode and select MPT. Windows media player should then recognise your sansa. Hope this helps.
Jun 02, 2011 | SanDisk Sansa Clip MP3 Player
I am running Windows XP. I have 2 problems. (1)I rip CDs using itunes having set the default format to MP3. Then I use windows explorer to move the albums to the music file of the sansa clip. However, some...
1) You need to set the "tags" in the music files ... artist, album and song name. I would suggest opening up the files in MediaMonkey, which will let you edit the tags.
2) After you download the podcasts with MediaMonkey, you need to find out where they exist on your disk. Then, copy them to your Clip using Windows Explorer.
Jan 27, 2010 | SanDisk Sansa Clip MP3 Player
My brandnew sansa clip is recognised by my
you should update new firmware first at http://forums.sandisk.com/sansa/
if it still doesn't work, change another one.
Good luck
Jan 12, 2010 | SanDisk Sansa Clip MP3 Player
Computer won't reconize my sandisk mp3 player
Hi, just had the same problem after restoring my system.
You must disconnect and update your Windows Media Player to Number 11. My reinstall left me at WMP 9 and it wouldn't recognise my Clip. Go to the Windows website, follow the download instructions, and you should be fine. When you plug in the Sansa Clip or MP3, it should recognise it right away. Hope this helps!
Feb 01, 2009 | SanDisk Sansa Clip MP3 Player
SANSA 4GB PLAYER
Have you tried updating your Windows Media Player to number 11? this has the drivers for SansaClip. Go to windows website, download WMP 11 and then plug in Sansa and uyour computer should recognise it. Good luck.
Jan 19, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip not recognised after formating
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 18, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip installation
What you need to do is update your Windows Media Player. I believe it has to be WMP10 and higher. Let me know if that works. Oh and you also need at least Windows XP Service Pack 2. so update your windows software
Nov 08, 2008 | SanDisk Sansa Clip MP3 Player
SANSA
My computer not recognise sansaclip
Jun 24, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player
check drivers in xp or windows
do u have drivers cd ,
download drivers n install it.
ur's kishore chowdary +919441133420
May 18, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip synch problem
Make sure the songs you are trying to sync do not have DRM-encryption on them. Converting to mp3 format is the best way to make them sync-able. Otherwise, you can find DRM removal software.
Also, reformat the player in Windows Media Player 11 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Your player should be sync-able in WMP-11 now.
-Tha Mp3 Doctor
Feb 27, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
124 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
