Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
Display pixelized my laptop screen seem to be pixelized. i can still see everything and it all works it just doesnt look like it should. its a hp pavilion zv6000.
    Scholar:
  • 28 Answers
Pixelated is a pretty generic description so doesn't help a lot, however, it could be you started your notebook in Safe mode, where Windows defaults to a low graphics setting for maximum compatibility with all hardware. Or, maybe you changed the video display settings yourself? Your native screen resolution is probably 1200 x 800, check the display setting to see if that's what it is set at now. Also check the HP.Com web site to see if they have a video display driver you can download, maybe your driver got deleted or somehow corrupted.
Posted on Jan 02, 2009
HP dv7 Display toggle problem
Use a registry cleaner like Advanced System Care, (that one is free and works).
Nov 16, 2013 | HP Pavilion Computers & Internet
Display goes black but comes back momentarily when the lid switch is toggled
if the pink tinge forms like lines that means that you have some dead pixels on your screen, so you have to change it,
if the pink tinge is all over the screen, then may be some pixel are dead or it can be a connection problem between the screen and the motherboard, and it's fixeable, tou have to open it and check the connection.
Oct 29, 2011 | HP Compaq nx7010 Notebook
Blotted screen in my hp laptop
1.Locate the problem pixel. Display a true black image on your HP's monitor. You can do this by playing a DVD on your HP laptop, and pausing it on the black screen just before the movie starts. Once you bring up a black image on screen, the stuck or dead pixel should be visible.
2.Try applying direct pressure to the problematic pixel. After you've located it, turn off your laptop. Place a soft cloth or rag over the pixel to avoid damaging your screen. A soft chamois works well. Using the tip of a pen, apply gentle pressure to the pixel. You don't need to press hard, as too much pressure can crack or scratch your screen. While applying pressure, boot up your laptop. This should force the pixel to begin working properly.
3.Tap the pixel. With your Toshiba booted up and an image on the screen, gently tap the pixel with the rounded end of a pen cap. Tap hard just hard enough to see a small white flash on the screen. Tap your HP's screen until the pixel begins working properly.
4.Download a stuck pixel program. Several programs, including JScreenFix, UDPix and Pixel Protector, are available for download and can help fix a malfunctioning pixel. These programs display rapidly changing colors and images on your screen. The flashing colors and images can force the pixel to begin functioning properly.
5.Contact HP. If none of the above methods work, your screen may have a pixel that is truly dead. If that's the case, the only option is to replace the display completely. Contact HP customer support at www.hp.com to find an authorized repair service near you.
Sep 19, 2011 | Computers & Internet
I have a dv2000. It turns on, but see no bios screen.
TRY TO GO THE BIOS SETTING THEN LOAD DEFUALT.. IF THE LOGO SCREEN NOT SHOW SOME PROBLEM FOR THE DISPLAY THE DEFAULT SETTING IS THE LOGO SCREEN WILL SHOW ON START UP THE SCREEN..
CHECK THE DISPLAY,,,, INVERTER, OR VGA CABLE,, VIDEO CARD..
Jun 25, 2009 | HP Pavilion dv6000z Notebook
Dell inspiron 1501 display almost blank
Try changing the memory stick, if still doesnt work, it means the invertor of the screen is gone.
Feb 16, 2009 | Dell Inspiron 1501 Notebook
Problem conecting hp laptop to sony bravia 52" hdmi tv
u need 2 change ur pixels 2 1024 by 768 in display settings then click the screen with 2 on and extended ur display to it ,then open windows mobility center and click connect display this will open a screen with 3 options chose the bottom 1 use external display only or sum think like that this should work once u have ur display showing on ur tv then click connect display again and chose the top option and u should get ur display on both screen let me know if this solves ur prob it worked 4 me regards davy ps if u plug in and loose control of ur lap top i think uv already selected use external display only try changing ur pixel 2 1024 by 768 and try again if not u need 2 plug into different tv nd change this if u have any more probs with this let me know this prob had my head dun in 4 days tryed the tech guys nd they said my tv port was broke liers(there a wast ov time)
Jan 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Laptop screen
When you see your screen pixelized, it may be a hardware issue, but before concluding it as a hardware related, I request you to try downloading and installing the latest video driver software and if you wish you can even update your computer with latest BIOS update from the concerned website.
After installation, please restart the computer as the changes made will be updated once you restart the computer.
If the issue persists even after installation of BIOS update and Display driver software for your computer, now it can be concluded that the issue is hardware related and your screen has to be replaced with a new one.
Thanks,
Sharath
Jan 02, 2009 | HP Pavilion dv6000z Notebook
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
Desktop scree showing white bright spots
The bright spots which you are seeing my be the failed pixels on the screen.
Once connect the external monitor to the notebook and check the display on the external display.
If you don't have external monitor, then restart the notebook and Press F10 or F2 key to Enter into BIOS. If the screen is same with bright pixels in the BIOS screen, then the it is confirmed the issues is with bad pixels.
If your notebook is under warranty, then HP will arrange for mail-in.
Note: There is Pixel policy from HP, go through thebelow URL:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00288895
Aug 03, 2008 | HP Compaq Presario v3000z Notebook
Screen problem...NVIDIA graphics card?
i suggest if it under warranty, to return it and/or get it fix before warranty expired. If it under warranty, no point to have headache over.
May 13, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
108 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
