Question about HP Officejet 5610 All-In-One InkJet Printer
Copying from HP 5610 All-in-One Printer
How do I get my HP 5610 to copy a stack of papers so that they come out double sided? So that the printer uses both sides of the paper, like a book - to save paper.
  • gajetgirl Jan 04, 2009
    Thanks for trying leroyal, but when I right click on printer icon in control panel, advanced is not an option. Only Properties or Printing Preferences etc. Any other words of advice? I have XP home ed.
Can I do double sided printing like Company ID Cards on the 5610
Posted on Feb 07, 2009
  • unclebutta
    unclebutta Aug 15, 2011
    Gajetgirl--I just had the exact same problem and tried the recommendations, but couldn't find "advanced" or "features." I right-clicked on the printer, chose "Printer Preferences," then "Finishing" tab and found the option "Print On Both Sides (Manually)" with a checkbox next to it. However, checking this option did not change anything, sadly. Note: I was angry because the 5610 manual/book says NOTHING about printing 2-sided copies and says "See onscreen HP Image Zone Help"...but the HP Image Zone Help says "For two-sided copying directions, see the manual." !!!!! I wish someone from HP could explain (1) why that happened and (2) why the manual or printer doesn't have simple steps for two-sided printing (without needing the computer.
    Genius:
  • 2,120 Answers
Right click on the printer icon in control panel, click advancd, choose manual 2 sided printing.
Posted on Jan 02, 2009
  • Leroy Elliott
    Leroy Elliott Jan 04, 2009
    Try features
  • unclebutta
    Gajetgirl--I just had the exact same problem and tried the recommendations, but couldn't find "advanced" or "features." I right-clicked on the printer, chose "Printer Preferences," then "Finishing" tab and found the option "Print On Both Sides (Manually)" with a checkbox next to it. However, checking this option did not change anything, sadly. Note: I was angry because the 5610 manual/book says NOTHING about printing 2-sided copies and says "See onscreen HP Image Zone Help"...but the HP Image Zone Help says "For two-sided copying directions, see the manual." !!!!! I wish someone from HP could explain (1) why that happened and (2) why the manual or printer doesn't have simple steps for two-sided printing (without needing the computer).
How do you print from dark to darker using HP officejet 5610 printer ? When I am photo copying, the result of a copy, is hard to be read.
there is a setting on the control panel for "Best Normal or fast"select best for high quality, Normal for normal and fast for draft copies.
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Black lines down the paper when copying
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab31
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 5610xi all in one printer, Lines in the copy
Are these dark lines or 'white' lines where ink isn't being applied to the paper where it should? And are they horizontal or vertical lines on the page?
If vertical lines on the page, follow these instructions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
May 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Trouble scanning and copying
Hi Crisann,
Can you explain from where r u copying, is it from the scanner glass or is it from the document feeder.
Please reply ASAP
BYE
Santhosh
Jun 04, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
242 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
